Форум РадиоКот • Просмотр темы - ПЛИС, разъемы, микросхемы
Текущее время: Сб апр 20, 2024 18:23:43
 Заголовок сообщения: ПЛИС, разъемы, микросхемы
СообщениеДобавлено: Вт июн 13, 2017 20:22:42
Рейтинг продавца: нет оценок
[Всего оценок: 0]
Добрейшего времени суток!
Предлагаю на продажу:
1. Плис Altera Cyclone III 12шт
СпойлерThe EP3C10E144C7N is a Cyclone® III FPGA consists of 10320 vertically arranged logic elements (LEs), 414kb of embedded memory and 23 18 x 18 embedded multipliers. The architectures include highly efficient interconnect and low-skew clock networks, providing connectivity between logic structures for clock and data signals. The logic and routing core fabric is surrounded by I/O elements (IOEs) and phase-locked loops (PLLs). The low-power Cyclone® III FPGA family is the third generation in the Altera® Cyclone FPGA series. With its unprecedented combination of low power, high functionality, the Cyclone III FPGA family broadens the number of high-volume, cost-sensitive applications that can benefit from an FPGA. The Cyclone III LS variant extends the family with higher density, higher memory, smaller packages and security features to protect your intellectual property (IP).
• 2 Phase-locked loops
• 70 Differential channels
• Hot-socketing operation support
• Routing architecture optimized for design separation flow with the Quartus® II software
• Ability to disable external JTAG port
• Error detection (ED) cycle indicator to core
• Internal oscillator enables system monitor and health check capabilities
• High memory-to-logic and multiplier-to-logic ratio
• High I/O count, low-and mid-range density devices for user I/O constrained applications
• Remote system upgrade without the aid of an external controller
• Dedicated cyclical redundancy code checker circuitry to detect single-event upset (SEU) issues
Полупроводники - Микросхемы\Программируемые Пользователем Вентильные Матрицы (FPGA)
Технические параметры
Количество Выводов 144вывод(-ов)
Уровень Чувствительности к Влажности (MSL) MSL 3 - 168 часов
Упаковка Поштучно
Количество I/O 94I/O
Стиль Корпуса Микросхемы Логики QFP
Количество Логических Блоков 645
Семейство ПЛИС Cyclone III
Полное Количество Бит RAM 423936Кбит
Минимальное Напряжение Питания Ядра 1.15В
Максимальное Напряжение Питания Ядра 1.25В
Напряжение Питания I/O 3.3В
Максимальная Рабочая Частота 437.5МГц
2. Плис Xilinx Spartan 24шт
СпойлерXC2S100 Xilinx Spartan-II 2.5V FPGA Family
3. Микросхема flex 10K fpga 30K 18шт
СпойлерFPGA - Программируемая вентильная матрица FPGA - Flex 10K 216 LABs 147 IOs
ХАРАКТЕРИСТИКИ
Максимальная рабочая температура + 85 C
Упаковка / блок QFP-208
Торговая марка Altera Corporation
Вид монтажа SMD/SMT
Упаковка Tray
Серия EPF10K30 FLEX 10K
Размер фабричной упаковки 24
Минимальная рабочая температура - 40 C
Продукт FLEX 10K
Коммерческое обозначение FLEX 10K
Рабочее напряжение питания 5 V
Количество логических элементов 1728
Количество блоков логических массивов (LAB) 216
Количество входов/выходов 147 I/O
Общий объем памяти 12288 bit
Количество вентилей 69,000
Рабочий ток источника питания 10 mA
4. Плис fpga XCV300E Xilinx 8шт
СпойлерFPGA - [PQFP240]; Семейство: Virtex-E; Вентилей: 411955; Ячеек: 1536; I/O: 158; Uпит: 1.2...3.6 В; Примечание: IC FPGA 1.8V C-TEMP 240-PQFP; Траб: 0...85
XCV300E Xilinx VirtexTM-E 1.8V
5. Драйвер интерфейса RS232 - ADM232earn более 20шт
6. Микросхемы lt1529it 10шт
СпойлерLDO Regulator Pos 3.3V 3A 5-Pin(5+Tab) TO-220
7. Разъемы 40 pin более 100шт
Цены на все позиции договорные!
Санкт-Петербург, пр. Косыгина д7
Почта по России, по тарифам.
 Заголовок сообщения: Re: ПЛИС, разъемы, микросхемы
СообщениеДобавлено: Пн июн 26, 2017 16:02:42
[Всего оценок: 0]
Карма: 11
Рейтинг сообщений: 13
Спартаны с виртексами сколько стоят?
R2AIV 73!
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 61
