Страница 7 из 23
Re: TI MSP430 Launch Pad
Добавлено: Ср сен 26, 2012 17:17:11
polli123456
В энергии стандартная библиотека, вот пример из неё:
LiquidCrystal Library - Hello World
Demonstrates the use a 16x2 LCD display. The LiquidCrystal
library works with all LCD displays that are compatible with the
Hitachi HD44780 driver. There are many of them out there, and you
can usually tell them by the 16-pin interface.
This sketch prints "Hello World!" to the LCD
and shows the time.
The circuit:
LCD pin Connect to
01 - GND GND, pot
02 - VCC +5V, pot
03 - Contrast Pot wiper
04 - RS Pin8 (P2.0)
05 - R/W GND
06 - EN Pin9 (P2.1)
07 - DB0 GND
08 - DB1 GND
09 - DB2 GND
10 - DB3 GND
11 - DB4 Pin10 (P2.2)
12 - DB5 Pin11 (P2.3)
13 - DB6 Pin12 (P2.4)
14 - DB7 Pin13 (P2.5)
15 - BL+ +5V
16 - BL- GND
Library originally added 18 Apr 2008
by David A. Mellis
library modified 5 Jul 2009
by Limor Fried (http://www.ladyada.net)
example added 9 Jul 2009
by Tom Igoe
modified 22 Nov 2010
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(P2_0, P2_1, P2_2, P2_3, P2_4, P2_5);
void setup() {
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("hello, world!");
void loop() {
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis()/1000);
Пример в CCS
http://mcudu.blogspot.com/2011/02/wh0802a.html
и продолжение с библиотекой здесь:
http://mcudu.blogspot.com/2011/02/blog-post.html
p/s делал и то и другое, работает всё.
Добавлено: Чт сен 27, 2012 08:36:09
andrey_vsk
Эти библиотеки и пробовал. Удалось все таки запустить его, сначала в IAR, потом в energia. Только не пойму одного, косяк оказался в плохом контакте на ноге контрастности, хотя при этом даже она регулировалась, квадратики то исчезали то появлялись при регулировке, заметил подергав руками провод, перепаял, все заработало на ура.... 2 дня убил на это...
Добавлено: Чт сен 27, 2012 12:17:16
polli123456
Я контрастность (3 вывод) всегда сразу подтягиваю к земле через 2.2к или 3.3к (что ближе под руку попадёт), к плюсу не подтягиваю (давно когда-то косячила, так и не делаю).
Добавлено: Пт ноя 02, 2012 11:19:18
morpheus
У меня такая вот проблема:
#include "msp430.h"
int main(void){
WDTCTL = WDTPW + WDTHOLD;
P1DIR = 0;
P1DIR |= BIT0;
while (1) {
if (P1IN & BIT3) {
P1OUT = BIT0;
} else {
P1OUT &= ~BIT0;
Предполагается что при нажатии а кнопку P1.3 загорится светодиод 1.0, однако происходит что-то странное: светодиод загорается без нажатия на клавишу, а при простом прикосновении к железной крышке кнопки или к пину 1.3 на мк. при нажатии на клавишусветодиод гаснет. Тестировал на 2х ланчпадах, на обоих такая фигня. В чем может быть проблема?
P.S. Компилятор mspgcc и IAR
Добавлено: Пт ноя 02, 2012 11:22:24
prinv
Подтяните P1.3 резистором к 0
Добавлено: Пт ноя 02, 2012 11:29:45
morpheus
prinv писал(а):Подтяните P1.3 резистором к 0
тогда не понятно, почему это не сделано создателями платы? И в стандартной прошивке с термометром кнопка вполне функциональна без всяких резисторов?
Добавлено: Пт ноя 02, 2012 11:30:41
prinv
Это программно делается, я летом разбирался - сейчас поищу.
Добавлено: Пт ноя 02, 2012 11:41:16
prinv
Вот
здесь всё про кнопки и про подтягивающие резисторы расписано.
Добавлено: Пт ноя 02, 2012 12:24:55
morpheus
prinv писал(а):Вот
Большое спасибо!
Добавлено: Пт ноя 02, 2012 16:43:07
YS
Стоит заменить на
, так оптимальнее, хотя по сути то же самое.
Добавлено: Пт ноя 02, 2012 20:33:24
prinv
Не соглашусь/
P1DIR |= BIT0 универсальнее, т.к. P1DIR = BIT0 подходит для конкретной ситуации и может быть не применимо в другой, потому что обнуляет биты, не связаные с BIT0
Добавлено: Пт ноя 02, 2012 20:50:19
YS
Вот как раз именно для этой ситуации этот метод и подходит. Два в одном - и затираем ненужное, и устанавливаем бит. Не надо писать две строчки там, где можно обойтись одной.
Добавлено: Сб ноя 03, 2012 08:18:15
prinv
Я считаю, что лучше не изменять те биты, которые не влияют на выполнение поставленной задачи.
Добавлено: Сб ноя 03, 2012 13:58:36
YS
В каждом участке кода надо использовать наиболее оптимальный подход.
Вот этот кусок
if (P1IN & BIT3) {
P1OUT = BIT0;
} else {
P1OUT &= ~BIT0;
лучше переписать так:
if (P1IN & BIT3) {
P1OUT |= BIT0;
} else {
P1OUT &= ~BIT0;
А на этапе инициализации проще как раз одним махом задать полное значение порта.
Добавлено: Сб ноя 03, 2012 14:24:45
DX168B
YS писал(а):Вот мне на работе приходится ковырять PIC, так я плююсь от их даташитов после Atmel, ST и TI.
О дааа.... К примеру, даташит на PIC16F1825 мне на столько вынес мозг, на сколько не смогли бы даже текущая девушка с бывшей, вместе взятые.
Добавлено: Сб ноя 03, 2012 17:16:37
HHIMERA
DX168B писал(а):YS писал(а):Вот мне на работе приходится ковырять PIC, так я плююсь от их даташитов после Atmel, ST и TI.
Ох уж эти сказочники!!!
Даташит, как даташит... всё там ясно и понятно...
16-й он и в Африке 16-й... только с дополнительными инструкциями... и периферией...
А что вы, собственно, хотели... если малоногий чип напичкан... по самое не хочу???
Да по сравнению с ним... MSP430 и Атмега16 выглядят как погрызанные злыми собаками колобки!!!
Добавлено: Сб ноя 03, 2012 19:33:08
DX168B
Мне почему-то даташит на STM32F407 куда более понятен, ежели на этот PIC.
Скажите к примеру, почему я не могу вывести ШИМ канал Р2А на ногу RC5? И где делся бит P2ASEL?
Причем, вывод Р2В сконфигурирован и исправно работает на ноге RC4.
На этот вопрос мне не смог ответить даже представитель самого Микрочипа.
Когда столкнешься подобными багами при некоторых обстоятельствах, тогда это тебе не покажется сказочками.
Добавлено: Сб ноя 03, 2012 19:54:10
YS
Чую, не зря я PIC не использую для себя.
Ну а на работе - там политика партии такая.
Добавлено: Сб ноя 03, 2012 20:06:40
DX168B
Я как-то к PIC тоже не очень. Просто проект такой, под который только он и подходит. И тут такая бяка вышла. А без двух полумостовых модулей ШИМа никуда не деться. Сейчас надо разбираться, какая альтернативная функция заняла эту ногу. На мегах и АРМах все куда проще.
Ну, тот МК совсем новый и сырой еще. По этому и проблемы всплывают. У нас на работе в основном Меги и STMы. Ну и плисами немного балуемся.
Добавлено: Сб ноя 03, 2012 20:23:55
HHIMERA
DX168B писал(а):Скажите к примеру, почему я не могу вывести ШИМ канал Р2А на ногу RC5? И где делся бит P2ASEL?
А если его нет... то что куда выводить???
DS41440C-page 120
For this device family, the following
functions can be moved between different pins.
• RX/DT/TX/CK
• SDO1
• SS (Slave Select)
• T1G
• P1B/P1C/P1D/P2B
• CCP1/P1A/CCP2
Это он из скромности...
Бывают ляпы и у Микрочипа в документации... и злокопипаст бывает... но в целом - всё дело просто в привычке...
