Добавлено: Пн сен 24, 2007 09:23:23
SOUND
Action
Sends pulses to a port pin.
Syntax
SOUND pin, duration, pulses
Remarks
Pin
Any I/O pin such as PORTB.0 etc.
Duration
The number of pulses to send. Byte, integer/word or constant.
Pulses
The time the pin is pulled low and high.
This is the value for a loop counter.
When you connect a speaker or a buzzer to a port pin (see hardware) , you can use the SOUND statement to generate some tones.
The port pin is switched high and low for pulses times.
This loop is executed duration times.
The SOUND statement is not intended to generate accurate frequencies. Use a TIMER to do that.
See also
NONE
Example
'name : sound.bas
'copyright : (c) 1995-2005, MCS Electronics
'purpose : demo : SOUND
'micro : Mega48
'suited for demo : yes
'commercial addon needed : no
$regfile = "m48def.dat" ' specify the used micro
$crystal = 4000000 ' used crystal frequency
$baud = 19200 ' use baud rate
$hwstack = 32 ' default use 32 for the hardware stack
$swstack = 10 ' default use 10 for the SW stack
$framesize = 40 ' default use 40 for the frame space
Dim Pulses As Word , Periods As Word
Pulses = 65535 : Periods = 10000 'set variables
Speaker Alias Portb.1 'define port pin
Sound Speaker , Pulses , Periods 'make some noice
'note that pulses and periods must have a high value for high XTALS
'sound is only intended to make some noise!
'pulses range from 1-65535
'periods range from 1-65535
End
Упс! Я ОЧЕНЬ разочарован в способностях автора данного поста. По крайней мере, можно было пустые строки убрать...Недоумевающий Сэр Мурр
Action
Syntax
Remarks
Pin
Duration
Pulses
See also
NONE
Example
'name : sound.bas
'micro : Mega48
End
