Страница 225 из 386
Re: Вопросы по С/С++ (СИ)
Добавлено: Ср июл 29, 2015 08:53:45
WiseLord
Да, я тоже подобным образом делал:
#define CONCAT(x,y)			x ## y
#define DDR(x)				CONCAT(DDR,x)
#define PORT(x)				CONCAT(PORT,x)
#define PIN(x)				CONCAT(PIN,x)
/* KS0108 Data port*/
#define KS0108_D0			B
#define KS0108_D0_LINE		(1<<0)
#define KS0108_D1			B
#define KS0108_D1_LINE		(1<<1)
#define KS0108_D2			B
#define KS0108_D2_LINE		(1<<2)
#define KS0108_D3			B
#define KS0108_D3_LINE		(1<<3)
#define KS0108_D4			B
#define KS0108_D4_LINE		(1<<4)
#define KS0108_D5			B
#define KS0108_D5_LINE		(1<<5)
#define KS0108_D6			B
#define KS0108_D6_LINE		(1<<6)
#define KS0108_D7			B
#define KS0108_D7_LINE		(1<<7)
static void ks0108SetPort(uint8_t data)
	if (data & (1<<0)) PORT(KS0108_D0) |= KS0108_D0_LINE; else PORT(KS0108_D0) &= ~KS0108_D0_LINE;
	if (data & (1<<1)) PORT(KS0108_D1) |= KS0108_D1_LINE; else PORT(KS0108_D1) &= ~KS0108_D1_LINE;
	if (data & (1<<2)) PORT(KS0108_D2) |= KS0108_D2_LINE; else PORT(KS0108_D2) &= ~KS0108_D2_LINE;
	if (data & (1<<3)) PORT(KS0108_D3) |= KS0108_D3_LINE; else PORT(KS0108_D3) &= ~KS0108_D3_LINE;
	if (data & (1<<4)) PORT(KS0108_D4) |= KS0108_D4_LINE; else PORT(KS0108_D4) &= ~KS0108_D4_LINE;
	if (data & (1<<5)) PORT(KS0108_D5) |= KS0108_D5_LINE; else PORT(KS0108_D5) &= ~KS0108_D5_LINE;
	if (data & (1<<6)) PORT(KS0108_D6) |= KS0108_D6_LINE; else PORT(KS0108_D6) &= ~KS0108_D6_LINE;
	if (data & (1<<7)) PORT(KS0108_D7) |= KS0108_D7_LINE; else PORT(KS0108_D7) &= ~KS0108_D7_LINE;
	return;
static void ks0108SetDdr(uint8_t data)
	if (data & (1<<0)) DDR(KS0108_D0) |= KS0108_D0_LINE; else DDR(KS0108_D0) &= ~KS0108_D0_LINE;
	if (data & (1<<1)) DDR(KS0108_D1) |= KS0108_D1_LINE; else DDR(KS0108_D1) &= ~KS0108_D1_LINE;
	if (data & (1<<2)) DDR(KS0108_D2) |= KS0108_D2_LINE; else DDR(KS0108_D2) &= ~KS0108_D2_LINE;
	if (data & (1<<3)) DDR(KS0108_D3) |= KS0108_D3_LINE; else DDR(KS0108_D3) &= ~KS0108_D3_LINE;
	if (data & (1<<4)) DDR(KS0108_D4) |= KS0108_D4_LINE; else DDR(KS0108_D4) &= ~KS0108_D4_LINE;
	if (data & (1<<5)) DDR(KS0108_D5) |= KS0108_D5_LINE; else DDR(KS0108_D5) &= ~KS0108_D5_LINE;
	if (data & (1<<6)) DDR(KS0108_D6) |= KS0108_D6_LINE; else DDR(KS0108_D6) &= ~KS0108_D6_LINE;
	if (data & (1<<7)) DDR(KS0108_D7) |= KS0108_D7_LINE; else DDR(KS0108_D7) &= ~KS0108_D7_LINE;
	return;
Идею с макросами типа PORT() вроде давно у ARV подсмотрел, сейчас почти везде у себя применяю.
Добавлено: Чт июл 30, 2015 00:01:58
Rtmip
Здравствуйте!
Появились вопросы некоторые.
Вопрос про функцию printf, компилятор Keil:
Предположим есть такая конструкция
 unsigned char ADC_rezult()
    unsigned char adc_data;
    return adc_data;
  while (1)
    	ADC_rezult();
	printf ("%u\n", ADC_rezult());
вывод в терминал результата.
Почему в терминале вместо одного байта выводится два?
Как правильно надо сделать?
Я попробовал добавить в программу следующее:
volatile unsigned char result; 		//переменная для данных
result = ADC_rezult(); 		//результат с АЦП
printf ("%d\n",(unsigned int)result);
Так все работает правильно, но правильно ли это?
Еще вопрос, как лучше, но не очень заумно(понятно для начинающего) "отзеркалить" байт?
Например, есть байт А0Н, а надо получить 05Н? С помощью дополнительных переменных двубайтовых
и сдвигов в них 8 раз это разумно или можно иначе? :dont_know:
Добавлено: Чт июл 30, 2015 18:09:38
-Valerius-
WiseLord писал(а):Да, я тоже подобным образом делал:
Спасибо большое, по-моему это то что нужно!
Буду разбираться. :beer:
Добавлено: Вт авг 04, 2015 15:09:55
spongebob
подскажите по вопросу сохранения структуры в eeprom и получении из eeprom структуры
есть структура
struct _stflag {
   unsigned char step : 4;
   unsigned char work : 1;
   unsigned char mode : 1;
} stflag;
как видно - она занимает 6 бит
нужно её сохранить в ячейку eeprom, а потом (при необходимости) получить обратно
есть функции для работы с eeprom:
ee_write(unsigned char adr, unsigned char dat)
unsigned char ee_read(unsigned char adr)
Добавлено: Вт авг 04, 2015 15:12:50
Gudd-Head
spongebob писал(а):как видно - она занимает 48 бит
Добавлено: Вт авг 04, 2015 15:20:42
ARV
unsigned char *ptr = (void*)&stflag;
ee_write(0, *ptr); // запись структуры в EEPROM с адреса 0x0000
*ptr = ee_read(0); // чтение той самой структуры из EEPROM c 0-го адреса
Добавлено: Вт авг 04, 2015 20:55:45
isx
Здравствуйте!
Подскажите пожалуйста, как мне после обработки внешнего прерывания вернуться в начало основного цикла (main). Нужно возвращаться именно в начало, не зависимо от того, какая строка выполнялась до прерывания.
Я бы просто в конце прерывания поставил GOTO с маркером в начале функции, но кейл ругается на него...
Добавлено: Вт авг 04, 2015 21:40:59
Аlex
isx писал(а): Я бы просто в конце прерывания поставил GOTO с маркером в начале функции, но кейл ругается на него...
И правильно делает. Ибо goto возможно только в пределах одного блока кода. Видимо, это сделали специально для защиты от подобных "финтов".
Переход на вектор прерывания - это не обычное изменение адресной точки программы (типа goto), а полноценный вызов функции, с применением стека. По этому, возвращаться из него в любое место программы - практически не возможно.
Вы лучше скажите откуда появилась такая потребность, авось посоветуем чего-нибудь более традиционное...
Добавлено: Вт авг 04, 2015 22:48:19
isx
В основном цикле у меня несколько формул, которые из набора переменных вычисляют одно значение. Это значение должно быть максимально точным в каждый конкретные момент времени. Некоторые переменные изменяются в прерывании по событию. Нужно чтобы при изменении любой переменной расчет происходил с самого начала основного цикла (и если прерывание произошло в середине основного цикла, то после выхода из прерывания необходимо вернуться в начало основного цикла и произвести расчет с уже измененными переменными).
И еще вопрос созрел. Есть у меня набор значений как положительных, так и отрицательных. Как высчитать разрыв между двумя конкретными значениями? К примеру имеем два значения 1 и 1, разрыв между ними = 0. Теперь другие, 0 и 1, разрыв между ними = 1. А теперь самое интересное, значения -1 и 1, разрыв между ними = 2. Как такое на СИ реализовать не пойму... :dont_know:
Добавлено: Вт авг 04, 2015 23:06:18
WiseLord
Я бы посоветовал в прерывании просто устанавливать какой-нибудь флаг, а в начале главного цикла его сбрасывать. Результат вычислений не принимать, если флаг установлен. Для более быстрого перехода в начало цикла (если вычисления сложные и длительные) расставить проверки типа if (flag) continue; внутри цикла:
volatile uint8_t isrFlag;
ISR () {
  isrFlag = 1;
int main() {
  while (1) {
    isrFlag = 0;
    formula1();
    if (isrFlag)
      continue;
    formula2();
    if (isrFlag)
      continue;
    formula3();
    if (isrFlag)
      continue;
    processResult();
Вычесть одно из другого, очевидно.
Добавлено: Вт авг 04, 2015 23:08:19
Аlex
Если Вам нужно выполнять вычисления только по обновлению переменных, то сделайте процессы синхронизированными, по тем же флагам. В прерывании переменную обновили, взвели флаг. В майне проверяете флаг и выполняете вычисления.
По второму вопросу. Это же обычное вычитание :)
ЗЫ: Упс, опоздал. Слишком медленно печатаю :))
Добавлено: Вт авг 04, 2015 23:37:23
isx
Аlex писал(а):По второму вопросу. Это же обычное вычитание
Да, но вот только иногда получаются отрицательные значения, и приходится добавлять еще if и менять знак в этом случае. Думал может по-проще алгоритм есть, но похоже нет :) .
WiseLord писал(а):Я бы посоветовал в прерывании просто устанавливать какой-нибудь флаг,
Напрямую получается никак нельзя сделать? Тогда попробуем флаг...
Спасибо за ответы :)
Добавлено: Вт авг 04, 2015 23:43:11
Аlex
isx писал(а): Да, но вот только иногда получаются отрицательные значения,
Нужно вычитать из большего меньшее, тогда отрицательных значений никогда не получится.
Что-то типа:
int diff(int a, int b){
  return a>b ? a-b : b-a;
Добавлено: Вт авг 04, 2015 23:53:33
isx
Точно... Так можно выбросить умножение на -1. Еще раз благодарю :) .
Добавлено: Чт авг 06, 2015 12:13:21
spongebob
а подскажите ещё по записи/чтению структур в/из eeprom
на этот раз уже большая структура
struct _state {
   unsigned char temp[5];
   unsigned char time[9];
} state;
14 байт.
функции записи/чтения работают с одним байтом
Добавлено: Чт авг 06, 2015 12:43:52
Аlex
Перебирайте все байты по одному в цикле и пишите их по-очереди в еепром.
Не вижу проблем... :dont_know:
Как пример - http://forum.chipmk.ru/index.php/topic/ ... -с-eeprom/
Добавлено: Чт авг 06, 2015 13:50:49
WiseLord
Для avr-gcc в avr-libc есть функции eeprom_read_block() и eeprom_write_block() (а также eeprom_update_block() и eeprom_update_block()), позволяющие читать/писать большое количество байтов.
Поэтому всё будет достаточно просто. Например, для записи этой структуры по адресу 0xA0 вызвать её как-то так:
eeprom_update_block(&state, (void*)(0xA0), sizeof(state));
Добавлено: Чт авг 06, 2015 14:24:31
spongebob
Аlex писал(а):Как пример - http://forum.chipmk.ru/index.php/topic/ ... -с-eeprom/
взял вариант без прерываний
сначала пихал ему указатель, не то
потом просто писал ee_write(0,state) и ee_read(0,state)
получаю предупреждения "illegal conversion between pointer types", но считывает/записывает правильно
Добавлено: Чт авг 06, 2015 14:29:20
Аlex
Замените
#define ee_write(adr,p_d) _ee_write(adr,&p_d,sizeof(p_d))
#define ee_read(adr,p_d) _ee_read(adr,&p_d,sizeof(p_d))
на
#define ee_write(adr,p_d) _ee_write(adr,(char *)&p_d,sizeof(p_d))
#define ee_read(adr,p_d) _ee_read(adr,(char *)&p_d,sizeof(p_d))
Добавлено: Ср сен 23, 2015 09:28:27
kalobyte
внезапно я :tea:
вчера ковырял одно гавно на пхп и столкнулся с интерфейсами
пхп давно учил и забил, а тут какая-то новая херня
быдлокниги не читал, посмотрел ролик какого-то какляцкого школьника
правильно ли я понял, что интерфейсы это просто перечень методов, которые потом будут реализованы в разных классах и будут делать какие-то штуки, но в основном коде надо использовать готовое название метода, которое есть интерфейс?
или например я сам могу переопределить этот метод в своем приложении
интерфейсы используются в фабриках, насколько я понял из видоса про фабрики
