Re: Мелкие вопросы по МК и ПЛИС.
Добавлено: Чт июл 19, 2012 14:07:22
Опа, я думал что Keil и AVR поддерживает. Просто его расхваливали как универсальный. Будем знать...
https://radiokot.ru/forum/
This program was produced by the
CodeWizardAVR V2.05.9 Evaluation
Automatic Program Generator
© Copyright 1998-2012 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date : 20.07.2012
Author :
Company :
Comments:
Chip type : ATtiny2313
AVR Core Clock frequency: 12,000000 MHz
Memory model : Tiny
External RAM size : 0
Data Stack size : 32
#include <tiny2313.h>
#include <1wire.h>
#include <ds18b20.h>
#include <delay.h>
// Declare your global variables here
unsigned char h[10]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
unsigned char msek, sek, min,des,ed,des1,ed1,t0,t1,k,devices,temp,temp1;
// Timer 0 output compare A interrupt service routine
interrupt [TIM0_COMPA] void timer0_compa_isr(void)
// Place your code here
//t0++;
//if (t0==1){PORTD=0b00010000;PORTB=h[ed];};
//if (t0==3){PORTD=0b00001000;PORTB=h[des];};
//if (t0==5){PORTD=0b00000010;PORTB=h[ed1];};
//if (t0==9){PORTD=0b000000001;PORTB=h[des1];t0=0;};
//if (t0==2||4||6||8){PORTD=0xFF;PORTB=0xFF;};
// Timer1 output compare A interrupt service routine
interrupt [TIM1_COMPA] void timer1_compa_isr(void)
//t1++;
//k++;
// if (t1==100) {msek++;t1=0;};
//if (k==255 & (PIND.6==0)) {min++;k=0;};
// if (msek==100){sek++;msek=0;};
// if (sek==60) {min++;sek=0;};
// if (min==99){min=0;};
void main(void)
// Declare your local variables here
// Crystal Oscillator division factor: 1
#pragma optsize-
CLKPR=(1<<CLKPCE);
CLKPR=(0<<CLKPCE) | (0<<CLKPS3) | (0<<CLKPS2) | (0<<CLKPS1) | (0<<CLKPS0);
#ifdef _OPTIMIZE_SIZE_
#pragma optsize+
#endif
// Input/Output Ports initialization
// Port A initialization
// Function: Bit2=In Bit1=In Bit0=In
DDRA=(0<<DDA2) | (0<<DDA1) | (0<<DDA0);
// State: Bit2=T Bit1=T Bit0=T
PORTA=(0<<PORTA2) | (0<<PORTA1) | (0<<PORTA0);
// Port B initialization
// Function: Bit7=Out Bit6=Out Bit5=Out Bit4=Out Bit3=Out Bit2=Out Bit1=Out Bit0=Out
DDRB=(1<<DDB7) | (1<<DDB6) | (1<<DDB5) | (1<<DDB4) | (1<<DDB3) | (1<<DDB2) | (1<<DDB1) | (1<<DDB0);
// State: Bit7=0 Bit6=0 Bit5=0 Bit4=0 Bit3=0 Bit2=0 Bit1=0 Bit0=0
PORTB=(0<<PORTB7) | (0<<PORTB6) | (0<<PORTB5) | (0<<PORTB4) | (0<<PORTB3) | (0<<PORTB2) | (0<<PORTB1) | (0<<PORTB0);
// Port D initialization
// Function: Bit6=In Bit5=Out Bit4=Out Bit3=Out Bit2=Out Bit1=Out Bit0=Out
DDRD=(0<<DDD6) | (1<<DDD5) | (1<<DDD4) | (1<<DDD3) | (1<<DDD2) | (1<<DDD1) | (1<<DDD0);
// State: Bit6=P Bit5=0 Bit4=0 Bit3=0 Bit2=0 Bit1=0 Bit0=0
PORTD=(1<<PORTD6) | (0<<PORTD5) | (0<<PORTD4) | (0<<PORTD3) | (0<<PORTD2) | (0<<PORTD1) | (0<<PORTD0);
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: 1500,000 kHz
// Mode: CTC top=OCR0A
// OC0A output: Disconnected
// OC0B output: Disconnected
TCCR0A=(0<<COM0A1) | (0<<COM0A0) | (0<<COM0B1) | (0<<COM0B0) | (1<<WGM01) | (0<<WGM00);
TCCR0B=(0<<WGM02) | (0<<CS02) | (1<<CS01) | (0<<CS00);
TCNT0=0x00;
OCR0A=0x01;
OCR0B=0x00;
// Timer/Counter 1 initialization
// Mode: CTC top=OCR1A
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: On
// Compare B Match Interrupt: Off
TCCR1A=(0<<COM1A1) | (0<<COM1A0) | (0<<COM1B1) | (0<<COM1B0) | (0<<WGM11) | (0<<WGM10);
TCCR1B=(0<<ICNC1) | (0<<ICES1) | (0<<WGM13) | (1<<WGM12) | (0<<CS12) | (1<<CS11) | (0<<CS10);
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x46;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=(0<<TOIE1) | (1<<OCIE1A) | (0<<OCIE1B) | (0<<ICIE1) | (0<<OCIE0B) | (0<<TOIE0) | (1<<OCIE0A);
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// Interrupt on any change on pins PCINT0-7: Off
GIMSK=(0<<INT1) | (0<<INT0) | (0<<PCIE);
MCUCR=(0<<ISC11) | (0<<ISC10) | (0<<ISC01) | (0<<ISC00);
// USI initialization
// Mode: Disabled
// Clock source: Register & Counter=no clk.
// USI Counter Overflow Interrupt: Off
USICR=(0<<USISIE) | (0<<USIOIE) | (0<<USIWM1) | (0<<USIWM0) | (0<<USICS1) | (0<<USICS0) | (0<<USICLK) | (0<<USITC);
// USART initialization
// USART disabled
UCSRB=(0<<RXCIE) | (0<<TXCIE) | (0<<UDRIE) | (0<<RXEN) | (0<<TXEN) | (0<<UCSZ2) | (0<<RXB8) | (0<<TXB8);
// Analog Comparator initialization
// Analog Comparator: Off
ACSR=(1<<ACD) | (0<<ACBG) | (0<<ACO) | (0<<ACI) | (0<<ACIE) | (0<<ACIC) | (0<<ACIS1) | (0<<ACIS0);
DIDR=0x00;
devices=w1_init();
// Global enable interrupts
#asm("sei")
while (1)
//if(sek>=10){des=(sek/10);} else {des=0;};
//ed=sek-(des*10);
//if(min>=10){des1=(min/10);} else {des1=0;};
//ed1=min-(des1*10);
temp = (ds18b20_temperature());
if(temp>=1000){des1=temp/1000;}else{des1=0;};
if(temp>=100){ed1=((temp-(des1*1000))/100);};
if(temp>=10){des=((temp-((des1*1000)+(ed1*100))/10));};
if(temp>=1){ed=(temp-((des1*1000)+(ed1*100)+(des*10)));};
t0++;
}Код: Выделить всё
PORTD=0b000000001
PORTD=0xFFКод: Выделить всё
asm("cli");
asm("sei");Код: Выделить всё
Project :
Version :
Date : 20.07.2012
Author :
Company :
Comments:
Memory model : Tiny
// 1 Wire Bus interface functions
#include <1wire.h>
// DS1820 Temperature Sensor functions
#include <delay.h>
void main(void)
unsigned char des,ed,des1,ed1,temp,temp1;
#pragma optsize-
CLKPR=(1<<CLKPCE);
#pragma optsize+
#endif
// Function: Bit6=In Bit5=In Bit4=Out Bit3=Out Bit2=Out Bit1=Out Bit0=Out
DDRD=(0<<DDD6) | (0<<DDD5) | (1<<DDD4) | (1<<DDD3) | (1<<DDD2) | (1<<DDD1) | (1<<DDD0);
// State: Bit6=T Bit5=T Bit4=0 Bit3=0 Bit2=0 Bit1=0 Bit0=0
PORTD=(0<<PORTD6) | (0<<PORTD5) | (0<<PORTD4) | (0<<PORTD3) | (0<<PORTD2) | (0<<PORTD1) | (0<<PORTD0);
// Clock value: Timer 0 Stopped
// Mode: Normal top=0xFF
TCCR0A=(0<<COM0A1) | (0<<COM0A0) | (0<<COM0B1) | (0<<COM0B0) | (0<<WGM01) | (0<<WGM00);
TCCR0B=(0<<WGM02) | (0<<CS02) | (0<<CS01) | (0<<CS00);
TCNT0=0x00;
OCR0A=0x00;
OCR0B=0x00;
// Clock value: Timer1 Stopped
// Mode: Normal top=0xFFFF
// Compare A Match Interrupt: Off
TCCR1B=(0<<ICNC1) | (0<<ICES1) | (0<<WGM13) | (0<<WGM12) | (0<<CS12) | (0<<CS11) | (0<<CS10);
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
TIMSK=(0<<TOIE1) | (0<<OCIE1A) | (0<<OCIE1B) | (0<<ICIE1) | (0<<OCIE0B) | (0<<TOIE0) | (0<<OCIE0A);
// INT0: Off
// INT1: Off
// Mode: Disabled
// USART disabled
DIDR=0x00;
// 1 Wire Bus initialization
// 1 Wire Data port: PORTD
// 1 Wire Data bit: 5
// Note: 1 Wire port settings are specified in the
// Project|Configure|C Compiler|Libraries|1 Wire menu.
w1_init();
while (1)
w1_init();
temp = (ds18b20_temperature(0));
ed=temp%10;
des=((temp%100)-ed)/10;
ed1=((temp%1000)-ed-(des*10))/100;
des1=(temp-(ed1*100)-ed-(des*10))/100;
delay_ms(750);
PORTD.4=1;PORTB=h[ed];
delay_ms(1);
PORTD.4=0;PORTB=0xFF;
PORTD.3=1;PORTB=h[des];
delay_ms(1);
PORTD.3=0;PORTB=0xFF;
PORTD.1=1;PORTB=h[ed1];
delay_ms(1);
PORTD.1=0;PORTB=0xFF;
PORTD.0=1;PORTB=h[des1];
delay_ms(1);
PORTD.0=0;PORTB=0xFF;
unsigned char des,ed,des1,ed1,temp,temp1;Код: Выделить всё
float ds18b20_temperature(unsigned char *addr)Нельзя вешать ёмкости (перестанет прошиваться на высоких частотах) и сильно подтягивать выводы к GND и VCC - минимум 300-500ом.mr.boroda писал(а):Люди пдскажите что нельзя вешать на внутрисхемный isp 6пин разъем? У меня на SCK висит зуммер на корпус.
На MISO висит ds18b20. На MOSI светодиодный индикатор. Можно ли так прошиться? Mega8-16pu
