Bootloader PIC18F25K80
Добавлено: Ср авг 17, 2016 14:24:53
Решил воспользоваться микрочиповским бутлодером AN1310 вроде все сделал как в даташите: настроил конфигурационные биты:
Подкорректировал bootconfig.inc в соответствии со схемой и камнем (использую UART2):
Скомпиллировал, прошил, подключаю к компу через usb-uart , а программа пишет: Bootloader not found.
Что я делаю не так?
; Copyright (c) 2002-2011, Microchip Technology Inc.
; Microchip licenses this software to you solely for use with Microchip
; products. The software is owned by Microchip and its licensors, and
; is protected under applicable copyright laws. All rights reserved.
; SOFTWARE IS PROVIDED "AS IS." MICROCHIP EXPRESSLY DISCLAIMS ANY
; WARRANTY OF ANY KIND, WHETHER EXPRESS OR IMPLIED, INCLUDING BUT
; NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS
; FOR A PARTICULAR PURPOSE, OR NON-INFRINGEMENT. IN NO EVENT SHALL
; MICROCHIP BE LIABLE FOR ANY INCIDENTAL, SPECIAL, INDIRECT OR
; CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, HARM TO YOUR
; EQUIPMENT, COST OF PROCUREMENT OF SUBSTITUTE GOODS, TECHNOLOGY
; OR SERVICES, ANY CLAIMS BY THIRD PARTIES (INCLUDING BUT NOT LIMITED
; TO ANY DEFENSE THEREOF), ANY CLAIMS FOR INDEMNITY OR CONTRIBUTION,
; OR OTHER SIMILAR COSTS.
; To the fullest extent allowed by law, Microchip and its licensors
; liability shall not exceed the amount of fees, if any, that you
; have paid directly to Microchip to use this software.
; MICROCHIP PROVIDES THIS SOFTWARE CONDITIONALLY UPON YOUR ACCEPTANCE
; OF THESE TERMS.
;#define TBLWT_BUG ; Enable this to work around timing bug found in some PIC18Fxx20's
;#define INVERT_UART ; If you don't have an RS232 transceiver, you might want this option
#define USE_MAX_INTOSC ; Sets OSCCON<IRCF2:IRCF0> for maximum INTOSC frequency (8MHz)
#define USE_PLL ; Sets OSCTUNE.PLLEN bit at start up for frequency multiplication.
;#define PICDEM_LCD2 ; RB0 = 1 required to enable MAX3221 TX output on PICDEM LCD 2 demo board
#define USE_SOFTBOOTWP ; enable software boot block write protection
;#define USE_SOFTCONFIGWP ; enable software config words write protection
; Autobaud will be used by default. To save code space or to force a specific baud rate to be used,
; you can optionally define a BAUDRG value instead. Most PIC18's support BRG16 mode and use the
; following equation:
; BAUDRG = Fosc / (4 * Baud Rate) - 1
; Old PIC18's without BRG16 mode need this equation instead:
; BAUDRG = Fosc / (16 * Baud Rate) - 1
; Examples:
;#define BAUDRG .51 ; 19.2Kbps from 4MHz (BRG16 = 1, BRGH = 1)
;#define BAUDRG .103 ; 115.2Kbps from 48MHz (BRG16 = 1, BRGH = 1)
;#define BAUDRG .85 ; 115.2Kbps from 40MHz (BRG16 = 1, BRGH = 1)
;#define BAUDRG .68 ; 115.2Kbps from 32MHz (BRG16 = 1, BRGH = 1)
;#define BAUDRG .16 ; 115.2Kbps from 8MHz (BRG16 = 1, BRGH = 1)
;#define BAUDRG .11 ; 1Mbps from 48MHz (BRG16 = 1, BRGH = 1)
;#define BAUDRG .9 ; 1Mbps from 40MHz (BRG16 = 1, BRGH = 1)
;#define BAUDRG .4 ; 2Mbps from 40MHz (BRG16 = 1, BRGH = 1)
;#define BAUDRG .3 ; 3Mbps from 48MHz (BRG16 = 1, BRGH = 1)
;#define BAUDRG .12 ; 19.2Kbps from 4MHz, 115.2Kbps from 24MHz (BRG16 = 0, BRGH = 1)
;#define BAUDRG .10 ; 115.2Kbps from 19.6608MHz (BRG16 = 0, BRGH = 1)
; Bootloader must start at the beginning of a FLASH Erase Block. If unspecified,
; bootloader will automatically be located at the end of program memory address space.
#define BOOTLOADER_ADDRESS 0 ; bootloader at beginning, application start/ISR vectors require remapping
;#define BOOTLOADER_ADDRESS END_FLASH - (ERASE_FLASH_BLOCKSIZE * 20) ; useful for running under debugger (debug executive wants to reside at the end of memory space too)
;#define BOOTLOADER_ADDRESS (END_FLASH - ERASE_FLASH_BLOCKSIZE) ; use on J parts to locate inside flash config erase block
#ifdef BOOTLOADER_ADDRESS
#if BOOTLOADER_ADDRESS == 0
; For Bootloader located at program memory address 0, the application firmware must
; provide remapped reset and interrupt vectors outside of the Boot Block. The following
; #defines tell the bootloader firmware where application entry points are to be expected:
#define AppVector 0x400 ; application start up code should be located here.
#define AppHighIntVector 0x408 ; application high priority interrupt should be located here
#define AppLowIntVector 0x418 ; application low priority interrupt should be located here
#endif
#endif
; Define UART pins and registers.
; Modify the following lines if you want to use a different UART module.
; Note: If your UART's RX pin happens to be multiplexed with analog ANx input
; functionality, you may need to edit the "preprocess.inc" DigitalInput
; macro. Code there needs to enable the digital input buffer (refer to
; ADC chapter of your device's datasheet).
#define UARTNUM 2
#if UARTNUM == 1
#define UxSPBRG SPBRG
#define UxSPBRGH SPBRGH
#define UxRCSTA RCSTA
#define UxTXSTA TXSTA
#define UxRCREG RCREG
#define UxTXREG TXREG
#define UxPIR PIR1
#define UxRCIF RCIF
#define UxTXIF TXIF
#define UxBAUDCON BAUDCON
; #define RXPORT PORTC ; RX on RC7 is used by default for most PIC18's.
; #define RXPIN .7
; #define RXPORT PORTB ; PIC18F14K50: RX on RB5/AN11
; #define RXPIN .5
; #define RXANSEL ANSELH ; RX/AN11 multiplexed -- must enable digital input buffer
; #define RXAN .3 ; ANSELH<3> controls AN11 digital input buffer
#endif
#if UARTNUM == 2
#define UxSPBRG SPBRG2
#define UxSPBRGH SPBRGH2
#define UxRCSTA RCSTA2
#define UxTXSTA TXSTA2
#define UxRCREG RCREG2
#define UxTXREG TXREG2
#define UxPIR PIR3
#define UxRCIF RC2IF
#define UxTXIF TX2IF
#define UxBAUDCON BAUDCON2
; #define RXPORT PORTG ; RG2 is default RX2 pin for some high pin count PIC18's.
; #define RXPIN .2
; #define RXPORT PORTD ; RX2 pin PPS'ed to RD4/RP21 on PIC18F46J11 for example.
; #define RXPIN .4
; #define RXANSEL ANSELH ; On PICs where RX is multiplexed with ANx analog inputs,
; #define RXAN .3 ; the digital input buffer needs to be enabled via ANSELx SFRs
; devices that use PPS to remap UART2 pins will need these lines defined:
; #define PPS_UTX .5 ; PPS code for TX2/CK2 output function
; #define PPS_UTX_PIN RPOR23 ; UART TX assigned to RP23 pin
; #define PPS_URX_PIN .21 ; UART RX assigned to RP21 pin
; #define PPS_URX RPINR16 ; PPS register for RX2/CK2 input function
#endif
; If you get linker errors complaining "can not fit the absolute section," you might want to
; increase BOOTLOADERSIZE below or set the BOOTLOADER_ADDRESS above to a smaller address number.
; Because we need to know the total size of the bootloader before the assembler has finished
; compiling the source code, we have to estimate the final bootloader size and provide it
; here as BOOTLOADERSIZE. This number is in bytes (twice the instruction word count).
; If you see the bootloader is reserving more FLASH memory than it really needs (you'll
; see a bunch of FFFF/NOP instructions at the end of the bootloader memory region),
; you can try reducing BOOTLOADERSIZE.
#define BOOTLOADERSIZE .708
#define MAJOR_VERSION .1 ; Bootloader Firmware Version
#define MINOR_VERSION .5
Что я делаю не так?
