Страница 1 из 1
UNI-T UT171\UT181
Добавлено: Ср окт 26, 2016 13:57:23
Maho
Лежа на подоконнике и оглядывая из-за стекла внешний мир внезапно ощутил в ушастой голове мысль, содрогнувшую до кончика хвоста: "А не побаловать ли себя любимого новым мультиметром?". Понажимав подушками лап клавиши компа моего раба наткнулся на это
http://www.uni-t.cz/en/p/multimeter-uni-t-ut171b
Multimeter UNI-T UT171B
Спойлер* TRMS
* USB connection to PC
* high accuracy
* datalogging 1000 values
* input protection
* industrial grade quality
* build in rechargeable battery
* admitance, temperature
SPECIFICATIONS
DC Voltage 600mV/6V/60V/600V/1000V ±(0.025%+5)
AC Voltage 600mV/6V/60V/600V/1000V ±(0.4%+40)
DC Current 600μA/6000μA/60mA/600mA/6A/10A ±(0.15%+10)
AC Current 600μA/6000μA/60mA/600mA/6A/10A ±(0.75%+20)
Resistance 600Ω/6kΩ/60kΩ/600kΩ/6MΩ/60MΩ ±(0.05%+2)
Capacitance 6nF/60nF/600nF/6μF/60μF/600μF/6mF/60mF ±(2.5%+40)
Admittance 60nS (±2.5%+40)
Frequency 10Hz~10MHz ±(0.01%+5)
Temperature -40°C~1000°C ±(1%+3°C)*
*only up to 230°C with standart accessory thermocouple
FEATURES
Display Count 60000
Auto/Manual Range
True RMS
Bandwidth 100kHz
AC+DC
4-20mA Loop
LoZ (AC)
VFC
Diode test
Continuity Buzzer
Duty Cycle
NCV
Data Hold/MAX/MIN
Relative Mode
Peak Hold
Data Storage 9999
USB Interface
EBNT Display
LCD Backlight
Analogue Bar Graph 31
Rechargeable
Mis-plug Alarm
Low Battery Indication
Auto Power Off
Input Protection
Input Impedance for DCV around 10MΩ
GENERAL CHARACTERISTICS
Power 7,4V 1800mAh Li-Ion Battery
LCD Size 70,6x49,5mm
Weight 384g
Size 206x95x55mm
ACCESSORY: Test Leads, Point Contact Temperature Probe, USB Interface Cable, CD with software, Power Adaptor
а затем на это
UNI-T UT181A
СпойлерSPECIFICATIONS:
DC Voltage 60mV/600mV/6V/60V/600V/1000V ±(0.025%+5)
AC Voltage 60mV/600mV/6V/60V/600V/1000V ±(0.3%+30)
DC Current 600μA/6000μA/60mA/600mA/10A ±(0.08%+10)
AC Current 600μA/6000μA/60mA/600mA/10A ±(0.6%+20)
Admittance 60nS ±(2%+10)
Capacitance 6nF/60nF/600nF/6μF/600μF/6mF/60mF ±(2%+5)
Frequency (Hz) 10Hz - 60MHz ±(0.01%+5)
Temperature -40°C°~1000°C * ±(1.5%+50)
FEATURES:
Display Count 60000
Auto Range
Manual Range
True RMS
Bandwidth 100kHz
AC+DC
Low Pass Filter
dBV/dBm
Continuity Buzzer
Diode
Duty Cycle
Dual Temperature Measurement
Data Hold
Peak Hold
Relative Mode
Datalogging 20000
Trend Capture
MAX/MIN/AVG
Date Time Display
Data Comparison
Display Type 3.5" 320x240 64k colour
Backlight Adjustment
Analogue Bargraf
USB Interface
Mis-Plug Alarm
Battery Indication
Auto Power Off
Re-Chargeable Battery
Input Protection
Input Impedance DCV 10MΩ+
GENERAL CHARACTERISTICS:
Power: 7.4V 2200mAh Li-ion Battery
Weight: 638.6g
LCD Size: 70x52mm
Accessory: Battery, Test Lead, Temperature Adaptor, Point Contact Temperature Probe x2, Power Adaptor, PC software CD, USB interface cable
181-й вроде точнее + регистратор, а в 171b мне экранчик в душу (глаза) запал.
Вот и сижу в раздумиях. Помогите потратить/сэкономить гроши!
Смотрю подвохи в мануалах:
181: ну скажем переменка до 1 кГц на пределе 600.00мВ - 0.3%+30D, что фактически 0,6мВ*3+0,3мВ=2,1мВ, а следовательно все 0,35%
171b на том же пределе 0,4%+40D - 0,6*4+0,4=2,8мВ т.е. примерно 0,45%
в целом некритично
С постоянным током у 181 на "ходовом" для меня пределе в 60мА 0,08+20 против 0,15+10 у 171-го.
Сейчас владею старым (17 лет в строю!) MeteX M3860M (базовая 0,3%+1D, до 10 кГц + разные плюшечки). Алчу также 34401 (мне до 300кГц по переменке измерять в принципе интересно, но не жизненно важно). От 34401 останавливает только размер и неудобство на конкретном рабочем месте.
Короче отговорите\покидайте камнями про УНИ-Т.
Re: UNI-T UT171\UT181
Добавлено: Ср окт 26, 2016 20:17:00
RU3DDM
Покидать камнями можно в прибор любого производителя - или хорошо, но очень дорого, либо дорого и нет того, чего хотелось бы, либо все есть, но не очень точный, либо чего нибудь не так работает как хотелось бы..... Недостатки есть у любого прибора. На муське есть обзор 181го: http://mysku.ru/blog/aliexpress/39916.html Вроде все чинно и красиво. Когда я приобрел UNI-T UT-71C первое впечатление было таким-же как и в обзоре 181го- "ух какой большой и красивый!". Впоследствии выяснилось, что копеечный "народный" HoldPeak HP-890CN оказался существенно точнее и линейнее на очень нужном мне пределе mv (гонял дома на калибраторе Р3003 и на других приборах). Им и пользуюсь все время, а UT71C лежит в чехле. Вот такой парадокс. Не очень я теперь верю в реализации ацп двойного интегрирования от чипов Cyrustek, применяемых в мультиметрах UNI-T Может я и не прав, это мое личное мнение.
p.s. Если бы было достаточно финансов я бы пожалуй еще раз ошибся :)
Добавлено: Ср окт 26, 2016 21:15:09
kentgaryk
А на это наткнуться никак? Прежде чем новую тему создавать? http://radiokot.ru/forum/viewtopic.php?f=10&t=28629
Добавлено: Чт окт 27, 2016 09:28:52
Maho
RU3DDM, спасибо. Вот и у меня по поводу данных железок субъективизм давлеет на разумом. Вроде вещица и притягивает глаз, но чую подвох...
kentgaryk, спасибо за замечание, но там вобщем-то 85 страниц разговоров о приборах ценового диапазона до 100 котами убитых енотов. Я же интересуюсь вполне конкретными типами от конкретного производителя.
Добавлено: Чт окт 27, 2016 09:46:37
kentgaryk
Maho писал(а):Я же интересуюсь вполне конкретными типами
именно это там и делают
