Страница 1 из 1
усилители мощности вч
Добавлено: Сб апр 04, 2026 10:17:12
k22
Американцы. С рабочего оборудования. Находится в Нижнем Новгороде.
Наработка не более 3 часов.
Model 1117 BBM3K5KEL 23500 рублей.
Start Frequency 500 MHz
Stop Frequency 2500 MHz
Output Power 25 Watt
Gain 44 dB
Operating Voltage 28 VDC
Current Consumption 3.4 Amp
Size 6.0x3.0x1.0 inch
Modulation Type CW/FM/AM
Model 1133 BBM2E4AEM 22600 рублей. Торг.
ManufacturerEmpower RF
Description20 - 1000 MHz / 25 Watts Solid State Broadband High Power Amplifier
ConfigurationModule with Connector
Standards SupportedL Band, S Band
Industry ApplicationTest & Measurement
Frequency20 MHz to 1 GHz
Power Gain46 dB
Gain Flatness±1.5 to 2 dB
Noise Figure 10 dB
Output Power40 dBm
Output Power10 W
P1dB 40 dBm
P1dB10 W
IP3 48 dBm
IP363.1 W
Saturated Power43.98 dBm
Saturated Power 25 W
Input Power3 dBm
Input Power0.002 W
Power Consumption6 A to 300 mA
ClassClass AB
Impedance50 Ohms
Pulsed/CWCW
ModulationCW, AM, FM
Sub-CategoryLinear Amplifier, SSPA
Input Return Loss-10 dB
Harmonics-20 dBc
Spurious-60 dBc
Switching Time20 uSec
Supply Voltage26 to 30 V
TechnologyMOSFET
Dimensions6.4 x 3.4 x 1.1 Inches
