Отдам HDD 2.5" SATA
Совсем уж ненужное можно просто отдать. Или обменять.
Сообщение Restart1566 »
Здравствуйте!
60 Гбайт отдам за самовывоз в Москве.
Смарт лог
Спойлерsmartctl 7.5 2025-04-30 r5714 [x86_64-linux-6.18.8-1-MANJARO] (local build)
Copyright (C) 2002-25, Bruce Allen, Christian Franke, http://www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Toshiba 2.5" HDD (30-60 GB)
Device Model: TOSHIBA MK6034GSX
Serial Number: Y6SLF09WS
Firmware Version: AH101A
User Capacity: 60 011 642 880 bytes [60,0 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database 7.5/5706
ATA Version is: ATA/ATAPI-7 (minor revision not indicated)
Local Time is: Mon Feb 16 13:38:51 2026 MSK
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 219) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 43) minutes.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
2 Throughput_Performance 0x0005 100 100 050 Pre-fail Offline - 0
3 Spin_Up_Time 0x0027 100 100 001 Pre-fail Always - 1202
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 1039
5 Reallocated_Sector_Ct 0x0033 100 100 050 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 100 100 050 Pre-fail Offline - 0
9 Power_On_Hours 0x0032 093 093 000 Old_age Always - 2850
10 Spin_Retry_Count 0x0033 120 100 030 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 1009
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 159
193 Load_Cycle_Count 0x0032 096 096 000 Old_age Always - 49759
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 35 (Min/Max 7/48)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
220 Disk_Shift 0x0002 100 100 000 Old_age Always - 256
222 Loaded_Hours 0x0032 095 095 000 Old_age Always - 2169
223 Load_Retry_Count 0x0032 100 100 000 Old_age Always - 0
224 Load_Friction 0x0022 100 100 000 Old_age Always - 0
226 Load-in_Time 0x0026 100 100 000 Old_age Always - 413
240 Head_Flying_Hours 0x0001 100 100 001 Pre-fail Offline - 0
SMART Error Log Version: 1
ATA Error Count: 11 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 11 occurred at disk power-on lifetime: 2805 hours (116 days + 21 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 51 00 f2 72 02 e0 Error: UNC at LBA = 0x000272f2 = 160498
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
40 d8 01 f2 72 02 e0 00 00:05:08.320 READ VERIFY SECTOR(S)
c8 d8 01 00 00 00 e0 00 00:05:08.308 READ DMA
40 d8 01 f1 72 02 e0 00 00:05:08.298 READ VERIFY SECTOR(S)
c8 d8 01 00 00 00 e0 00 00:05:08.289 READ DMA
40 d8 02 f1 72 02 e0 00 00:05:01.675 READ VERIFY SECTOR(S)
Error 10 occurred at disk power-on lifetime: 2805 hours (116 days + 21 hours)
40 d8 02 ef 72 02 e0 00 00:05:01.664 READ VERIFY SECTOR(S)
40 d8 04 f3 72 02 e0 00 00:05:01.653 READ VERIFY SECTOR(S)
c8 d8 01 00 00 00 e0 00 00:05:01.645 READ DMA
40 d8 04 ef 72 02 e0 00 00:04:55.020 READ VERIFY SECTOR(S)
Error 9 occurred at disk power-on lifetime: 2805 hours (116 days + 21 hours)
c8 d8 01 00 00 00 e0 00 00:04:55.008 READ DMA
40 d8 08 f7 72 02 e0 00 00:04:54.998 READ VERIFY SECTOR(S)
c8 d8 01 00 00 00 e0 00 00:04:54.989 READ DMA
40 d8 08 ef 72 02 e0 00 00:04:48.365 READ VERIFY SECTOR(S)
Error 8 occurred at disk power-on lifetime: 2805 hours (116 days + 21 hours)
c8 d8 01 00 00 00 e0 00 00:04:48.356 READ DMA
40 d8 10 ef 72 02 e0 00 00:04:41.720 READ VERIFY SECTOR(S)
c8 d8 01 00 00 00 e0 00 00:04:41.708 READ DMA
40 d8 10 df 72 02 e0 00 00:04:41.698 READ VERIFY SECTOR(S)
Error 7 occurred at disk power-on lifetime: 2805 hours (116 days + 21 hours)
c8 d8 01 00 00 00 e0 00 00:04:41.689 READ DMA
40 d8 20 df 72 02 e0 00 00:04:35.085 READ VERIFY SECTOR(S)
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
The above only provides legacy SMART information - try 'smartctl -x' for more
149 Гбайт отдам за самовывоз в Москве.
Смарт лог
Model Family: Fujitsu MJA BH
Device Model: FUJITSU MJA2160BH G2
Serial Number: K906T95270W6
LU WWN Device Id: 5 00000e 04393a937
Firmware Version: 00000018
User Capacity: 160 041 885 696 bytes [160 GB]
ATA Version is: ATA8-ACS T13/1699-D revision 3f
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Mon Feb 16 14:35:59 2026 MSK
was never started.
Self-test execution status: ( 24) The self-test routine was aborted by
the host.
data collection: ( 508) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
command.
power-saving mode.
recommended polling time: ( 72) minutes.
Conveyance self-test routine
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 100 100 046 Pre-fail Always - 165445
2 Throughput_Performance 0x0005 100 100 030 Pre-fail Offline - 26673152
3 Spin_Up_Time 0x0003 100 100 025 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 1022
5 Reallocated_Sector_Ct 0x0033 100 100 024 Pre-fail Always - 0 (2100 0)
7 Seek_Error_Rate 0x000f 100 100 047 Pre-fail Always - 2710
8 Seek_Time_Performance 0x0005 100 100 019 Pre-fail Offline - 0
9 Power_On_Hours 0x0032 089 089 000 Old_age Always - 5679
10 Spin_Retry_Count 0x0013 100 100 020 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 732
192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 375
193 Load_Cycle_Count 0x0032 099 099 000 Old_age Always - 28998
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 25 (Min/Max 13/59)
195 Hardware_ECC_Recovered 0x001a 100 100 000 Old_age Always - 3098
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 (0 16143)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 253 000 Old_age Always - 1
200 Multi_Zone_Error_Rate 0x000f 100 100 060 Pre-fail Always - 27216
203 Run_Out_Cancel 0x0002 100 100 000 Old_age Always - 1533273047302
240 Head_Flying_Hours 0x003e 200 200 000 Old_age Always - 0
No Errors Logged
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Aborted by host 80% 498 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
И еще четыре по 149, смарты могу выложить по запросу, а то очень большое сообщение.
Подскажите только, как оставить контакт для связи?
С уважением
Сообщение petrenko »
[uquote="Restart1566",url="/forum/viewtopic.php?p=4789755#p4789755"]Здравствуйте!
.. Гбайт отдам за самовывоз в Москве.
Подскажите только, как оставить контакт для связи?[/uquote]
B нижней части каждого "cooбщения" есть виртуальные "кнопочки" :
[ Профиль ] , [ ЛC ] , ......... , [ Цитата ]
Я "нажал" [ ЛC ] и написал Вам Л.(ичное)C.(ooбщение)
Bы его пока ещё не прочитали.
Зайдите в [ Центр пользователя ] и прочитайте пожалуйста.
Всё отдал.
Добавлено after 1 minute 45 seconds:
[uquote="petrenko",url="/forum/viewtopic.php?p=4790276#p4790276"]B нижней части каждого "cooбщения" есть виртуальные "кнопочки" :
Зайдите в [ Центр пользователя ] и прочитайте пожалуйста.[/uquote]
СПАСИБО!
Paд, что у Вас всё получилось.
Знаю, что отдано человеку, которому это пригодится.
Xopoшо, что не выкинули, а не поленились зайти на форум. :beer:
[uquote="petrenko",url="/forum/viewtopic.php?p=4790512#p4790512"]Xopoшо, что не выкинули, а не поленились зайти на форум.[/uquote]
Есть ещё кое-что по мелочи.
Создать отдельную тему или здесь выкладывать, сменив название?
Вернуться в «Отдам-Обменяю»
