Теперь хоть предупреждает о таком:
test.o: warning: multiple common of `zzz'
main.o: warning: previous common is hereКод: Выделить всё
main.o: warning: previous common is hereДобавлено after 37 minutes 38 seconds:--warn-common
Warn when a common symbol is combined with another common symbol or with a symbol definition. Unix linkers allow this somewhat sloppy practise, but linkers on some other operating systems do not. This option allows you to find potential problems from combining global symbols. Unfortunately, some C libraries use this practise, so you may get some warnings about symbols in the libraries as well as in your programs.
There are three kinds of global symbols, illustrated here by C examples:
int i = 1;
A definition, which goes in the initialized data section of the output file.
extern int i;
An undefined reference, which does not allocate space. There must be either a definition or a common symbol for the variable somewhere.
int i;
A common symbol. If there are only (one or more) common symbols for a variable, it goes in the uninitialized data area of the output file. The linker merges multiple common symbols for the same variable into a single symbol. If they are of different sizes, it picks the largest size. The linker turns a common symbol into a declaration, if there is a definition of the same variable.
The --warn-common option can produce five kinds of warnings. Each warning consists of a pair of lines: the first describes the symbol just encountered, and the second describes the previous symbol encountered with the same name. One or both of the two symbols will be a common symbol.
1.Turning a common symbol into a reference, because there is already a definition for the symbol.
<file>(<section>): warning: common of `<symbol>'
overridden by definition
<file>(<section>): warning: defined here
2. Turning a common symbol into a reference, because a later definition for the symbol is encountered. This is the same as the previous case, except that the symbols are encountered in a different order.
<file>(<section>): warning: definition of `<symbol>'
overriding common
<file>(<section>): warning: common is here
3. Merging a common symbol with a previous same-sized common symbol.
<file>(<section>): warning: multiple common
of `<symbol>'
<file>(<section>): warning: previous common is here
4. Merging a common symbol with a previous larger common symbol.
overridden by larger common
<file>(<section>): warning: larger common is here
5. Merging a common symbol with a previous smaller common symbol. This is the same as the previous case, except that the symbols are encountered in a different order.
overriding smaller common
<file>(<section>): warning: smaller common is here
int zzz;
void test() {
zzz = 123;
return;
#include <stdio.h>
float zzz;
extern void test();
int main(void) {
zzz = 111;
printf("zzz = %g, zzz addr = %p.\n", zzz, &zzz);
test();
return 0;
zzz = 111, zzz addr = 00407070.
zzz = 1.7236e-043, zzz addr = 00407070.
[main.c]: zzz = 111, zzz addr = 0x60103c.
[test.c]: zzz = 123, zzz addr = 0x60103c.
[main.c]: zzz = 123, zzz addr = 0x60103c.
В С++ эти не самые подходящие для эмбедда контейнеры по крайней мере есть и некоторые ими пользуются, значит это плюс. На С конечно можно написать более эффективные реализации, но на С++ это тоже можно сделать. Однако на плюсах я могу сделать шаблонный класс работающий с разными типа, могу на стадии компиляции проверить равен ли размер контейнера степени двойки и выбрать более эффективный алгоритм. Таким образом контейнеры на С++ проще в обращении, функциональнее и в среднем эффективнее, а если эффективность не важна, то они уже просто есть в стандартной библиотеке.Без полноценных new/delete и обработки исключений от него толку мало, а размер кода больше. Особенно если пользоваться стандартной библиотекой. Например, почти любой контейнер для конкретного применения можно реализовать на C эффективней. В ущерб универсальности, само собой. Так что, если нет сотни килобайт оперативки и мегабайта флеша, C++ я избегаю.
А зачем, это на МК? Я, кстати, параметрический полиморфизм недолюбливаю. Уже не раз тратил уйму времени на ловлю баг с ним. Оно вроде бы и красиво, но когда выясняется, что один и тот же метод с разными типами объектами соврешает совершенно разные манипуляции, хочется удавить того, кто это написал )Reflector писал(а):на плюсах я могу сделать шаблонный класс работающий с разными типа
А чем таким мк принципиально отличается от ПК, чтобы все контейнеры там работали только с uint8_t? Даже USART может работать в 9-ти битном режиме или почему-бы в векторе не хранить указатели?Reflector писал(а):А зачем, это на МК?
Давайте так, когда Вам удастся написать проект несколько более сложный, чем мигание светодиодом, на PDK14, используя C++ и его парадигму, я сам пойду убеждать Торвальдса, что пришла пора в ядро Linux принимать код на C+++ )))Reflector писал(а):А чем таким мк принципиально отличается от ПК, чтобы все контейнеры там работали только с uint8_t?
Ну уж мне такое не надо втирать! Обычно, менее чем на порядок я SQL код не оптимизирую. Чаще - порядка на два )Eddy_Em писал(а):И да: SQL — штука для ширпотреба.
Попробуйте. Я на R и SQL предиктивный анализ по терабайту и полмиллиарду строк делаю за 2 часа. А написал код за неделю (пару дней на ETL - остальное на R скрипт). Сможете быстрее?Eddy_Em писал(а):Для конкретной узкой ниши обычно уникальный алгоритм значительно производительней будет!
Да ладно. Начиная с 3.8 он существенно поумнел. Полного бреда, в виде загрузки индексного регистра перед каждым обращением к элементу структуры, не лепит. Хотя бы помнит, что перед этим в регистр положил )Eddy_Em писал(а):Иной раз посмотришь, что там sdcc наделает, схватишься за голову, и начнешь вручную оптимизировать...
Смотря для чего. Например, QT - великолепная и очень удобная штука.А насчет крестов, я ими баловался лет 18 назад.
typedef struct {
uint8_t * const buffer;
int head;
int tail;
const int maxlen;
} circ_bbuf_t;
int circ_bbuf_push(circ_bbuf_t *c, uint8_t data);Мне не нужно ничего писать на PDK14, но на tiny13 я, и не только, тестовые проекты на С++ создавал и разница от сишных там была байт 10. Или вот пример, делал я "ЛА/осцилл/частотомер/аналоговый и цифровой многоканальный генератор" и все это подключалось по USB к компу. Последний вариант был на F405, USB либа - это жестоко порезанная версия из HAL, которая все равно осталась весьма внушительного размера, плюс там абсолютно все на классах, от пина до того же USB. У мк метр флеша, размер бинарника 11KB, т.е. он занимает 1% или треть флеша самого мелкого моего 20-ти пинового STM32.Reflector писал(а):Давайте так, когда Вам удастся написать проект несколько более сложный, чем мигание светодиодом, на PDK14, используя C++ и его парадигму, я сам пойду убеждать Торвальдса, что пришла пора в ядро Linux принимать код на C+++ )))
typedef struct message_header_st {
uint8_t msg_len:2;
uint8_t msg_no:6;
} message_header_t;
typedef struct message_queue_st {
uint8_t cur_idx;
uint8_t top_idx;
uint8_t queue[MESSAGE_QUEUE_SIZE];
} message_queue_t;
Странно. Или Вы не умеете писать на C, или C++ научился обходиться вообще без инициализации своей среды. Иначе расход RAM должен был быть большим.Reflector писал(а): разница от сишных там была байт 10
C++ буфер проще в обращении, не так захламляет глобальное пространство имен, для него доступны дополнительные оптимизации и т.д.... Например, есть у нас два буферизированных USART, тогда можно написать:А что толку от шаблонного класса, если для экономии памяти кольцевой буфер все равно выделяется статически, а часто вообще вырождатся в что-то типа:
Usart1<16, 32> usart1;
Usart2<10, 20> usart2;
template<typename T, uint32_t capacity>
class List
using TI = std::conditional_t<(capacity > 254), uint16_t, uint8_t>;
struct Node
T value;
TI prev, next;
Node buf[capacity + 1];
......Разница в 10 байт флеша, практически все мои шаблонные классы не имеют полей вообще и RAM не потребляют, по крайней мере если говорить о классах периферии.Странно. Или Вы не умеете писать на C, или C++ научился обходиться вообще без инициализации своей среды. Иначе расход RAM должен был быть большим.
Но даже в этом случае - почти 10% памяти коту под хвост - непозволительная роскошь. У PDK14 - 128 байт RAM
Ничем, если нужно мало ног, ставлю 20-ти ногий STM32F0. Сейчас появились G0, там есть 8-ми пиновые, плюс они малопотребляющие, начнут продавать по адекватным ценам, буду ставить их. Я не создаю устройства которые продаются крупными партиями или просто продаются, потому дешевые падауки мне без надобности, с другой стороны у эмбеддеров обычно нет такого опыта использования С++ какой есть у программистов с ПККстати, а чем Вы его заменяете, если не секрет?
Ничем, если нужно мало ног, ставлю 20-ти ногий STM32F0.[/uquote]Кстати, а чем Вы его заменяете, если не секрет?
