Софт для изготовления плат на ЧПУ (LPT-контроллер)
Сообщение Ghost in shell »
Нашел файл, который подходил для станка. Раньше.
Медалька 2)
G90G80G21G49
(Tool Number:1) (10.0 градус конический с 0.000 мм радиусом скругления и 0.125 мм плоской кромкой)
G0Z5.0000
M3 S15000
G0 X24.6390 Y-18.4701 Z5.0000
G1 Z-2.0000 F240
G3 X24.8497 Y-18.5320 I0.1363 J0.0743 F360
G1 X24.6390 Y-18.4701
G0 Z5.0000
G0 X29.5164 Y-19.3296
G1 Z-2.0000 F240
G1 X29.5793 F360
X29.0426 Y-19.3111
X29.4074 Y-19.3296
X29.5105 Y-19.3237
X29.5164 Y-19.4268
G3 X30.6156 Y-19.2462 I0.1062 J2.7887
G1 X28.1290 Y-19.1747
G3 X29.5164 Y-19.4268 I1.2654 J3.0198
G1 Y-19.5292
X29.8395 Y-19.5286
G3 X31.3668 Y-19.1169 I-1.0909 J7.0862
G2 X27.1525 Y-18.9746 I-1.2380 J25.8039
G1 X28.5550 Y-19.4164
G3 X29.5164 Y-19.5292 I0.7686 J2.3984
G1 X29.5164 Y-19.6316
G3 X30.4567 Y-19.5112 I0.1603 J2.4806
G1 X32.1726 Y-18.9853
G2 X25.9260 Y-18.6740 I-1.8695 J25.3105
G1 X24.4640 Y-18.3115
X24.5908 Y-18.6239
G2 X26.2084 Y-18.8327 I-0.4442 J-9.8102
G2 X28.5288 Y-19.5156 I-6.0349 J-24.7877
G3 X29.5164 Y-19.6316 I0.7915 J2.4778
G1 Y-19.7340
G3 X30.4830 Y-19.6104 I0.1635 J2.5630
G2 X33.1689 Y-18.8584 I5.8621 J-15.7662
G2 X34.7064 Y-18.7241 I1.5111 J-8.4302
G1 X34.8066 Y-18.5649
G2 X27.0141 Y-18.7497 I-4.5164 J26.0612
G2 X24.2824 Y-18.1510 I2.0137 J15.7204
G1 X24.5216 Y-18.7259
G2 X26.1827 Y-18.9319 I-0.3134 J-9.3254
G2 X28.5026 Y-19.6149 I-6.0172 J-24.7219
G3 X29.5164 Y-19.7340 I0.8143 J2.5571
G1 Y-19.8363
G3 X30.5094 Y-19.7095 I0.1667 J2.6455
G2 X33.1820 Y-18.9601 I5.8492 J-15.7188
G2 X34.7633 Y-18.8263 I1.5067 J-8.3966
G1 X35.0250 Y-18.4103
G2 X32.4791 Y-18.7692 I-3.5157 J15.7340
G2 X27.0302 Y-18.6484 I-2.0922 J28.5959
G2 X24.0980 Y-17.9897 I2.1552 J16.4479
G1 X24.4524 Y-18.8279
G2 X26.1570 Y-19.0311 I-0.2106 J-9.0163
G2 X28.4764 Y-19.7141 I-5.9993 J-24.6558
G3 X29.5164 Y-19.8363 I0.8371 J2.6364
G1 Y-19.9387
G3 X30.5357 Y-19.8087 I0.1700 J2.7280
G2 X33.1950 Y-19.0618 I5.8365 J-15.6722
G2 X34.8201 Y-18.9285 I1.5064 J-8.3938
G1 X35.2434 Y-18.2558
G2 X32.4754 Y-18.6667 I-3.7744 J15.8950
G2 X27.0463 Y-18.5472 I-2.0883 J28.5055
G2 X23.9125 Y-17.8258 I2.2539 J16.9590
G1 X24.3832 Y-18.9299
G2 X26.1313 Y-19.1304 I-0.1253 J-8.8157
G2 X28.4503 Y-19.8133 I-5.9814 J-24.5893
G3 X29.5164 Y-19.9387 I0.8600 J2.7157
G1 Y-20.0446
G3 X30.5621 Y-19.9079 I0.1345 J3.0386
G2 X33.2081 Y-19.1634 I5.8242 J-15.6265
G2 X34.8766 Y-19.0311 I1.5028 J-8.3660
G1 X35.4777 Y-18.0976
G2 X32.4717 Y-18.5643 I-4.0958 J16.4668
G2 X27.0624 Y-18.4460 I-2.0845 J28.4152
G2 X23.7204 Y-17.6472 I2.1507 J16.3900
G1 X24.3140 Y-19.0319
G2 X26.1056 Y-19.2296 I-0.0517 J-8.6872
G2 X28.4241 Y-19.9125 I-5.9634 J-24.5225
G3 X29.5164 Y-20.0446 I0.9160 J2.9926
G1 Y-20.1470
Какая опция подойдет для сохранения траектории в таком формате?
Кот гуляет сам по себе, но вблизи холодильника.
Сообщение Jeri »
Чем управляется станок, какая CAM? Если какой-нибудь мач3, то для него есть соответствующий постпроцессор - выбирается при сохранении траектории внизу окошка.
Станок управляется Math3. Какую опцию использовать? Там Math3 упомянут?
Сообщение Jeri »
[uquote="Ghost in shell",url="/forum/viewtopic.php?p=3637392#p3637392"]Станок управляется Math3. Какую опцию использовать? Там Math3 упомянут?[/uquote]
В таком случае в окне сохранения траектории нужно выбрать постпроцессор для Mach3 на ютубе полно уроков, например:
https://youtu.be/nPNSfEbJONg?t=48s
Спасибо, работает на железе. Но странная инверсия: перемещение понизу, а гравировка - поверху.
Где это переключить?
