Proteus: вопросы и ответы
Сообщение Fizik_S »
Нет, это текстовой файл с расширением *.DAT.
Примерное содержимое:
"TIME","64","42","43","44","57","66","CLK","_RES_CPU","/MREQ","73_/RD"
-3.535631294e-006,"SLO","SLO","SLO","SLO","SHI","SHI","SLO","SHI","FLT","SHI"
5.5e-008,"SHI","SLO","SLO","SLO","SHI","SHI","SLO","SHI","FLT","SHI"
6e-008,"SHI","SHI","SLO","SLO","SLO","SHI","SLO","SHI","FLT","SHI"
1.05e-007,"SLO","SHI","SLO","SLO","SLO","SHI","SLO","SHI","FLT","SHI"
1.55e-007,"SHI","SHI","SLO","SLO","SLO","SHI","SLO","SHI","FLT","SHI"
1.6e-007,"SHI","SLO","SHI","SLO","SLO","SLO","SLO","SHI","FLT","SHI"
1.8e-007,"SHI","SLO","SHI","SLO","SLO","SLO","SLO","SLO","FLT","SHI"
2.05e-007,"SLO","SLO","SHI","SLO","SLO","SLO","SLO","SLO","FLT","SHI"
2.55e-007,"SHI","SLO","SHI","SLO","SLO","SLO","SLO","SLO","FLT","SHI"
2.6e-007,"SHI","SHI","SHI","SLO","SHI","SLO","SLO","SLO","FLT","SHI"
2.68e-007,"SHI","SHI","SHI","SLO","SHI","SLO","SHI","SLO","FLT","SHI"
3.05e-007,"SLO","SHI","SHI","SLO","SHI","SLO","SHI","SLO","FLT","SHI"
3.55e-007,"SHI","SHI","SHI","SLO","SHI","SLO","SHI","SLO","FLT","SHI"
3.6e-007,"SHI","SLO","SLO","SHI","SHI","SHI","SHI","SLO","FLT","SHI"
3.665e-007,"SHI","SLO","SLO","SHI","SHI","SHI","SLO","SLO","FLT","SHI"
4.05e-007,"SLO","SLO","SLO","SHI","SHI","SHI","SLO","SLO","FLT","SHI"
4.55e-007,"SHI","SLO","SLO","SHI","SHI","SHI","SLO","SLO","FLT","SHI"
4.6e-007,"SHI","SHI","SLO","SHI","SLO","SHI","SLO","SLO","FLT","SHI"
5.05e-007,"SLO","SHI","SLO","SHI","SLO","SHI","SLO","SLO","FLT","SHI"
Сообщение dr.zorg82 »
Удалить
Сообщение Engineer_Keen »
Давненько я в этой теме не писал...
В общем в связи с производственной необходимостью обновил комп. Было Win XP, Proteus 7.6, все работало нормально. Стало Win10 x64, Proteus 7.10, в принципе как-то работает, правда иногда при симуляции молча вылетает, но это ладно. А вот при открытии даташита, если его нужно скачивать - скачивает и после этого виснет намертво, просмотровщик PDF (Foxit) не запускается, само окно ISIS закрыть нельзя никак, только через диспетчер задач. Если перезапустить, то даташит на эту самую деталь (так как он скачанный уже получается) открывается без проблем. Запуск от админа, совместимость с XP SP3 ставил. Было у кого так?
Неправильно собранная из неисправных деталей схема нуждается в отладке и сразу не работает... (С)
Сообщение Стан »
Engineer_Keen писал(а): Вт ноя 10, 2026 11:05:33 Стало Win10 x64, Proteus 7.10, в принципе как-то работает, правда иногда при симуляции молча вылетает, но это ладно. А вот при открытии даташита, если его нужно скачивать - скачивает и после этого виснет намертво, просмотровщик PDF (Foxit) не запускается, само окно ISIS закрыть нельзя никак, только через диспетчер задач. Если перезапустить, то даташит на эту самую деталь (так как он скачанный уже получается) открывается без проблем. Запуск от админа, совместимость с XP SP3 ставил. Было у кого так?
win10 желательно ставить корпоративную.
легкий просмотрщик pdf stdu viewer
"совместимость с xp" "запуск от админа" - не нужны. это опция для совсем старого софта из начала 200х.
ИТ-шники ставили, я не выбирал, кажется не корпоративная.
Foxit вроде не тяжелый, по крайней мере раньше был... Да и непонятно, какая разница, он же уже скачанный даташит без проблем открывает, и на XP, который тормознее был в 10 раз и оперативки в разы меньше все работало.
Это мне искусственный идиот насоветовал, терять все равно нечего было.
Сообщение Ariadna-on-Line »
Одно время у меня на Вин7 32 бит были подобные глюки. У вас же проблемы возникают после скачивания, а это работа в интернет браузере. У меня Мозилла Фаерфокс. В такие моменты запускал диспетчер задач - там процессов firefox.exe - несколько десятков. Как червей в навозе. И видимо они намертво забивали операционку. Тыркался я достаточно долго. Наобум поставил прогу Firemin 11.Дал ей настройку ограничивать использование памяти на 200мБ и проверку каждые 5 секунл.. И глюки прекратились. Не знаю в этом ли было дело, но что есть-то есть.
ПС. Ранее в браузерах была четкая настройка - ограничить число процессов конкретным числом. Но похоже это им бьёт по "рекламо-вместимости". И они втихаря эту настройку выхолостили. Вроде есть, но не работает. В Гугло Хроме - то же самое.
Похоже глюк конкретной сборки винды или ее настроек, дома на комп сына (тоже десятка, но ту я сам ставил) поставил этот же самый протеус, там все скачивается и открывается. Память точно не при чем, ее 16 гигов и кроме протеуса и pdf просмотровщика ничего не было запущено. Wireshark-ом смотрел, скачивается pdf, TCP-соединение закрывается и все, ISIS виснет, документ скачан, но команда на запуск просмотровщика не выдается.
Провел еще эксперимент, запустил 2 окна ISIS, вытащил в них одинаковый элемент, к которому даташита не скачивал, в первой скачался и завис, во второй при клике на показ PDF тут же открылся просмотровщик, зависание идет где-то в момент между сохранением даташита и вызовом просмотровщика.
добрый день. имеется коннектор TBLOCK-I4 . у него расстояние между пинами 0.2дюйма. как можно отредактировать корпус этого коннектора? для печатки нужно расстояние 0.3 дюйма. можно, конечно поставить одинарные контакты и расставить их на нужном расстоянии.. но хочется создать подходящий корпус. протеус 8
