Заказываю эти дисплейчики (1.3" OLED Module 1.3 inch Display Module White/Blue 128X64SPI/IIC I2C ) уже давно. Так же давно заметил толи баг, толи не правильно инициализирую. Причем я использовал разные библиотеки, и все время этот баг.
Код:
status += ssd1306_WriteCommand(hi2c, 0xAE); // Display off status += ssd1306_WriteCommand(hi2c, 0x20); // Set Memory Addressing Mode status += ssd1306_WriteCommand(hi2c, 0x10); // 00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid status += ssd1306_WriteCommand(hi2c, 0xB0); // Set Page Start Address for Page Addressing Mode,0-7 status += ssd1306_WriteCommand(hi2c, 0xC0); //Set COM Output Scan Direction //C0 or C8 mirror vertical status += ssd1306_WriteCommand(hi2c, 0x00); // Set low column address status += ssd1306_WriteCommand(hi2c, 0x10); // Set high column address status += ssd1306_WriteCommand(hi2c, 0x40); // Set start line address status += ssd1306_WriteCommand(hi2c, 0x81); // set contrast control register status += ssd1306_WriteCommand(hi2c, 0xFF); status += ssd1306_WriteCommand(hi2c, 0xA0); //--set segment re-map 0 to 127 // A1 or A0 mirror horizontal status += ssd1306_WriteCommand(hi2c, 0xA6); // Set normal display
status += ssd1306_WriteCommand(hi2c, 0xA8); // Set multiplex ratio(1 to 64) status += ssd1306_WriteCommand(hi2c, SSD1306_HEIGHT - 1); //0x3F
status += ssd1306_WriteCommand(hi2c, 0xA4); // 0xa4,Output follows RAM content;0xa5,Output ignores RAM content status += ssd1306_WriteCommand(hi2c, 0xD3); // Set display offset status += ssd1306_WriteCommand(hi2c, 0x00); // No offset status += ssd1306_WriteCommand(hi2c, 0xD5); // Set display clock divide ratio/oscillator frequency status += ssd1306_WriteCommand(hi2c, 0xF0); // Set divide ratio status += ssd1306_WriteCommand(hi2c, 0xD9); // Set pre-charge period status += ssd1306_WriteCommand(hi2c, 0x22);
status += ssd1306_WriteCommand(hi2c, 0xDA); // Set com pins hardware configuration status += ssd1306_WriteCommand(hi2c, SSD1306_COM_LR_REMAP << 5 | SSD1306_COM_ALTERNATIVE_PIN_CONFIG << 4 | 0x02);
status += ssd1306_WriteCommand(hi2c, 0xDB); // Set vcomh status += ssd1306_WriteCommand(hi2c, 0x20); // 0x20,0.77xVcc status += ssd1306_WriteCommand(hi2c, 0x8D); // Set DC-DC enable status += ssd1306_WriteCommand(hi2c, 0x14); // status += ssd1306_WriteCommand(hi2c, 0xAF); // Turn on SSD1306 panel
Например вот инициализация. В таком случае есть смещение на 2 пикселя по горизонтали влево. То-есть по Х первые два ряда пикселей как бы за экраном. Но зато справа по X два ряда дополнительных пикселей, но они мусорные, в них нельзя рисовать. Мне приходится изголятся, пишу в настройках хеадера что у меня ширина дисплея 130 пикселей. и рисую квадрат например вот так: Draw_Rectangle(2, 0, 129, 63, NOFILL, White, SQUARE); ну то-есть рисую по Х с 2 до 129 , а не с 0 по 127 как хотелось бы правильно. Ну и текст соответственно тоже приходится размещать с учетом этого смещения. Что за смещение? Кто сталкивался? В чем может быть косяк?
Лень вникать, но вы уверены, что дисплей на SSD1306. Очень много в продаже именно 1.3" дисплеев на SH1106 а у них разводка сделана так, что первые 2 пикселя (и 2 последних, хотя это не имеет значения) не подключены. Поэтому самый левый пиксель имеет адрес не 0, а 2.
гуглите такой запрос: difference between ssd1306 and sh1106
Ну конечно не уверен))) Как тут можно быть уверенным. В принципе ответ понятен. Либо SH1106 либо брак.
а я думал это только у меня фигня такая)) оказывается нет...
просто все как и я ленились об этом написать спросить ) думая что только у них такая фигня.
Из англоязычных ресурсов, через переводчик: - SSD1306 имеет расширенный набор команд по сравнению с SH1106 - SH1106 поддерживает только режим адресации страниц - В SSD1306 добавлены специальные режимы горизонтальной и вертикальной адресации - SSD1306 также поддерживает автоматическую прокрутку/scrolling
Если код/библиотека использует режим адресации страниц, то будет работать с любым из контроллеров (с разницей в длине строки - 128 против 132). Если код/библиотека использует режим горизонтальной или вертикальной адресации, он будет работать только на SSD1306
Отрегулируйте длину строки и используйте дисплей. Правда, есть трудность с многосерийное производство (нужен тест на каждом вложенном дисплее).
Отвечая самому себе, дополняя: сейчас еще позаморачивался с этим дисплеем. Оказывается там 127 пикселей в ширину, а не 128 ) Причем там через китайский микроскоп видна маркировка у одного светодиода 125, и далее еще два светодиода. Итого 127. Ну и вручную посчитал внимательно. 127 их. Твердо и четко! Ну там когда фонариком светишь, граница светодиодов светится и видно где они заканчиваются.
Оказывается там 127 пикселей в ширину, а не 128... через китайский микроскоп видна маркировка...
не слушай этих старпёров)) они вечно всем недовольны... ты всё делаешь правильно. зато теперь мы знаем, что оказывается китайцы просто забыли добавить светодиодов...
Что-то я ложанул. Перекомпилировал и тд и тп, пересчитал 128 пикселей)
