генератор по совпадению таймера
Вот код:
#include <mega8.h>
// Alphanumeric LCD Module functions
#asm
.equ __lcd_port=0x12 ;PORTD
#endasm
#include <lcd.h>
#include <math.h>
#include <stdio.h>
#include <delay.h>
//#define button_+_ PINC.0;//кнопка +
//#define button_-_ PINC.1;//кнопка -
char lcd_buffer[10];
unsigned int chislo_taktov=5000;
// Timer 1 output compare A interrupt service routine
interrupt [TIM1_COMPA] void timer1_compa_isr(void)
{ TCNT1=0;//обнулить счетный регтстр
PORTB.0=1;
#asm //небольшая задержка
nop
nop
nop
nop
nop
#endasm
PORTB.0=0;
// Declare your global variables here
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port B initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTB=0;
DDRB=1;
// Port C initialization
// Func6=In Func5=In Func4=In Func3=In Func2=In Func1=Out Func0=Out
// State6=T State5=T State4=T State3=T State2=T State1=1 State0=1
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
TCCR0=0x00;
TCNT0=0x00;
// Timer/Counter 1 initialization
// Clock value: 500,000 kHz
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: On
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x02;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=25;
OCR1AL=255;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// Mode: Normal top=FFh
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
MCUCR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x10;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
// LCD module initialization
lcd_init(16);
lcd_gotoxy(0,0);
PORTC.0=1;
PORTC.1=1;
// Global enable interrupts
#asm("sei")
while (1)
// Place your code here
if ( PINC.0==0) //читаем кнопку+
delay_ms(100);
if ( PINC.0==0)
chislo_taktov=chislo_taktov+10;
OCR1A=chislo_taktov;
if ( PINC.1==0) //читаем кнопку-
delay_ms(100);
if ( PINC.1==0)
chislo_taktov=chislo_taktov-10;
sprintf(lcd_buffer,"%-5d",chislo_taktov);
lcd_puts(lcd_buffer);
lcd_gotoxy(0,5);
sprintf(lcd_buffer,"%-5d",TCNT1);
lcd_gotoxy(0,7);
sprintf(lcd_buffer,"%-5d",OCR1A);
lcd_gotoxy(0,0);
но вот какая штука в протеосе посмотрел как работает увидел что импульсы скачут как попало(картинку посмотрите) помогите разоьратся в чем ошибка, за ранее спасибо
#include <mega8.h>
#asm
#endasm
#include <lcd.h>
#include <math.h>
#include <stdio.h>
#include <delay.h>
PORTB.0=1;
nop
nop
nop
nop
nop
#endasm
PORTB.0=0;
void main(void)
PORTB=0;
DDRB=1;
PORTC=0x00;
DDRC=0x00;
PORTD=0x00;
DDRD=0x00;
TCCR0=0x00;
TCNT0=0x00;
TCCR1A=0x00;
TCCR1B=0x02;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=25;
OCR1AL=255;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
MCUCR=0x00;
TIMSK=0x10;
ACSR=0x80;
SFIOR=0x00;
lcd_init(16);
lcd_gotoxy(0,0);
PORTC.0=1;
PORTC.1=1;
#asm("sei")
while (1)
delay_ms(100);
if ( PINC.0==0)
delay_ms(100);
if ( PINC.1==0)
lcd_gotoxy(0,5);
lcd_gotoxy(0,7);
lcd_gotoxy(0,0);
- (72.04 КБ) 318 скачиваний
Re: генератор по совпадению таймера
Может на осцилографе масштаб увеличить нужно просто?
не мне кажется не в этом дело просто пробовал генератор стандартный в протеосе на другой вход осцилографа ставил смотрел не похоче что из за маштаба вот файлы посмотрите кому не лень может что то и увидете своим опыиным взглядом
- generator.rar
- проэкт в CVA
- (75.24 КБ) 113 скачиваний
вот протеус
- generator1.rar
- протеус
- (11.23 КБ) 122 скачивания
codenamehawk
- Вымогатель припоя
Попробуйте такой код.
А то у вас в архиве
PORTB.0=1;
nop
nop
nop
nop
nop
#endasm
PORTB.0=0;
{ TCNT1L=0;//обнулить счетный регтстр
TCNT1H=0;
спасибо попробую но это без разницы помоему
codenamehawk
- Вымогатель припоя
Это только по вашему, а на самом деле это важно, это видно на ассемблере.dimka86 писал(а):спасибо попробую но это без разницы помоему
TCNT1=0;
.CSEG
_timer1_compa_isr:
000060 93ea ST -Y,R30
000061 93fa ST -Y,R31
000062 e0e0 LDI R30,LOW(0)
000063 e0f0 LDI R31,HIGH(0)
000064 bdfd OUT 0x2C+1,R31
000065 bdec OUT 0x2C,R30
.CSEG
_timer1_compa_isr:
000061 e0e0 LDI R30,LOW(0)
000062 bdec OUT 0x2C,R30
; 0000 002C TCNT1H=0;
000063 bded OUT 0x2D,R30Re: генератор по совпадению таймера
Спасибо был неправ признаю еще подскажите кода у меня задержка тактов более 10000 тысяч на осцилографе импульсы в разноьой это из за маштабирования на осцилографе
codenamehawk
- Вымогатель припоя
Посмотрел, правильный код получается переставив местами
У вас в программе не хватает одной строки
добавьте после #asm("sei")
При задержке 10000 тактов осциллограф не успевает прорисовывать.
Попробуйте Graph Для прорисовки графика нажмите пробел.
TCNT1H=0;//обнулить счетный регтстр
TCNT1L=0;добавьте после #asm("sei")
#asm("sei")
while (1)Попробуйте Graph Для прорисовки графика нажмите пробел.
спасибо большое я хочу сделать формирователь угла опережения для своего урала вы мпе очень помогли а это я делаю для проверки работы прошивки виртуально не пояя железа
