Вопрос к спецам по "пк". Какой компьютер лучше собрать???
А по современнее ничего не нашлось?
Вот состав...
CPU-Z TXT Report
Binaries
CPU-Z version 1.60
Processors
Number of processors 1
Number of threads 1
APICs
Processor 0
-- Core 0
-- Thread 0 0
Processors Information
Processor 1 ID = 0
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name AMD Athlon XP
Codename Barton
Specification AMD Athlon(tm) XP
Package Socket A (462)
CPUID 6.A.0
Extended CPUID 7.A
Core Stepping
Technology 0.13 um
Core Speed 1667.2 MHz
Multiplier x FSB 10.0 x 166.7 MHz
Rated Bus speed 333.4 MHz
Instructions sets MMX (+), 3DNow! (+), SSE
L1 Data cache 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 512 KBytes, 16-way set associative, 64-byte line size
FID/VID Control no
K7 Thermal sensor yes
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02001002h
Max CPUID level 00000001h
Max CPUID ext. level 80000008h
Cache descriptor Level 1, I, 64 KB, 1 thread(s)
Cache descriptor Level 1, D, 64 KB, 1 thread(s)
Cache descriptor Level 2, U, 512 KB, 1 thread(s)
CPUID
0x00000000 0x00000001 0x68747541 0x444D4163 0x69746E65
0x00000001 0x000006A0 0x00000000 0x00000000 0x0383FBFF
0x80000000 0x80000008 0x68747541 0x444D4163 0x69746E65
0x80000001 0x000007A0 0x00000000 0x00000000 0xC1C3FBFF
0x80000002 0x20444D41 0x6C687441 0x74286E6F 0x5820296D
0x80000003 0x00000050 0x00000000 0x00000000 0x00000000
0x80000004 0x00000000 0x00000000 0x00000000 0x00000000
0x80000005 0x0408FF08 0xFF20FF10 0x40020140 0x40020140
0x80000006 0x00000000 0x41004100 0x02008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000001
0x80000008 0x00002022 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC0010114 0x88F098D8 0x37373737
MSR 0xC0010015 0x00000000 0x0E001008
Chipset
Northbridge VIA KT400 (VT8377) rev. 00
Southbridge VIA VT8235 rev. 00
Memory Type DDR
Memory Size 1280 MBytes
Memory Frequency 166.7 MHz (1:1)
DRAM Interleave 4-way
CAS# latency (CL) 2.5
RAS# to CAS# delay (tRCD) 3
RAS# Precharge (tRP) 3
Cycle Time (tRAS) 7
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR
Manufacturer (ID) Hyundai Electronics (AD00000000000000)
Size 512 MBytes
Max bandwidth PC3200 (200 MHz)
Part number HYMD564 646B8J-D43
Serial number 1C1CC12A
Manufacturing date Week 104/Year 40
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
Nominal Voltage 2.50 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 2.0-2-2-6-n.a. @ 133 MHz
JEDEC #2 2.5-3-3-7-n.a. @ 166 MHz
JEDEC #3 3.0-3-3-8-n.a. @ 200 MHz
DIMM # 2
SMBus address 0x51
Memory type DDR
Manufacturer (ID) Kingston (7F98000000000000)
Size 512 MBytes
Part number K
Serial number 680A9787
Manufacturing date Week 44/Year 05
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
DIMM # 3
SMBus address 0x52
Memory type DDR
Manufacturer (ID) MOSEL (4000000000000000)
Size 256 MBytes
Part number V826632K24SCIW-D3
Serial number 2B822C93
Manufacturing date Week 41/Year 06
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
Monitoring
Mainboard Model KT400-8235 (0x00000232 - 0x17F98A88)
LPCIO
LPCIO Vendor Winbond
LPCIO Model W83697HF
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0x60
LPCIO Revision ID 0x12
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Hardware Monitors
Hardware monitor Winbond W83697HF
Voltage 0 1.66 Volts [0x68] (CPU VCore)
Voltage 1 1.63 Volts [0x66] (AUX)
Voltage 2 2.94 Volts [0xB8] (+3.3V)
Voltage 3 5.30 Volts [0xC5] (+5V)
Voltage 4 12.89 Volts [0xD4] (+12V)
Temperature 0 39°C (102°F) [0x27] (TMPIN0)
Temperature 1 50°C (121°F) [0x63] (TMPIN1)
Fan 0 2557 RPM [0x42] (FANIN0)
Hardware registers
Register space LPC, base address = 0x0290
Hardware monitor ACPI
Temperature 0 50°C (121°F) [0xC9B] (THRM)
DMI
DMI BIOS
vendor Phoenix Technologies, LTD
version 6.00 PG
date 07/23/2003
DMI System Information
manufacturer VIA Technologies, Inc.
product KT400-8235
version unknown
serial unknown
UUID {FFFFFFFF-FFFF-FFFF-FFFF-FFFFFFFFFFFF}
DMI Baseboard
vendor unknown
model KT400-8235
revision unknown
serial unknown
DMI System Enclosure
manufacturer unknown
chassis type Desktop
chassis serial unknown
DMI Processor
manufacturer AMD
model AMD Athlon(tm) XP
clock speed 1666.0 MHz
FSB speed 166.0 MHz
multiplier 10.0x
DMI Memory Controller
correction unknown
Max module size 32 MBytes
DMI Memory Module
designation A0
size 512 MBytes (single bank)
DMI Memory Module
designation A1
size 512 MBytes (double bank)
DMI Memory Module
designation A2
size 256 MBytes (single bank)
DMI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation SECONDARY IDE (internal)
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
DMI Port Connector
designation COM2 (internal)
connector DB-9 male
DMI Port Connector
designation LPT1 (internal)
port type Parallel Port ECP/EPP
connector DB-25 female
DMI Port Connector
designation Keyboard (internal)
port type Keyboard Port
connector PS/2
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
port type Mouse Port
connector PS/2
connector PS/2
DMI Port Connector
designation USB0 (external)
port type USB
DMI Port Connector
designation AUDIO (external)
port type Audio Port
DMI Extension Slot
designation PCI0
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI3
type PCI
width 32 bits
populated no
DMI Extension Slot
designation AGP
type AGP
width 32 bits
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 768 MBytes
max# of devices 3
DMI Memory Device
designation A0
format DIMM
type unknown
size 512 MBytes
DMI Memory Device
designation A1
format DIMM
type unknown
size 512 MBytes
DMI Memory Device
designation A2
format DIMM
type unknown
size 256 MBytes
Graphics
Number of adapters 2
Graphic APIs
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
Name ATI Radeon X1950 GT
Memory size 512 MB
GPU ref clock 27000
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x0000)
Model ID 0x7288 (0x0000)
Performance Level 0
Display adapter 1
Name ATI Radeon X1950 GT Secondary
Memory size 512 MB
PCI device bus 1 (0x1), device 0 (0x0), function 1 (0x1)
Model ID 0x72A8 (0x0001)
Performance Level 0
Software
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX Version 9.0c
CPU-Z TXT Report
Binaries
CPU-Z version 1.60
Processors
Number of threads 1
APICs
Processor 0
-- Core 0
-- Thread 0 0
Processor 1 ID = 0
Name AMD Athlon XP
Codename Barton
CPUID 6.A.0
Extended CPUID 7.A
Core Stepping
Technology 0.13 um
FID/VID Control no
Thread dumps
CPU Thread 0
APIC ID 0
Type 02001002h
CPUID
Chipset
Memory Type DDR
Cycle Time (tRAS) 7
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR
Size 512 MBytes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
DIMM # 2
SMBus address 0x51
Memory type DDR
Size 512 MBytes
Part number K
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
DIMM # 3
SMBus address 0x52
Memory type DDR
Size 256 MBytes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
Monitoring
LPCIO
LPCIO Chip ID 0x60
Config Mode LDN 0xB
Hardware Monitors
Hardware registers
DMI
DMI BIOS
version 6.00 PG
date 07/23/2003
product KT400-8235
version unknown
serial unknown
DMI Baseboard
vendor unknown
model KT400-8235
revision unknown
serial unknown
DMI Processor
manufacturer AMD
FSB speed 166.0 MHz
multiplier 10.0x
correction unknown
DMI Memory Module
designation A0
DMI Memory Module
designation A1
DMI Memory Module
designation A2
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
connector DB-9 male
DMI Port Connector
connector DB-9 male
DMI Port Connector
DMI Port Connector
connector PS/2
connector PS/2
DMI Port Connector
connector PS/2
connector PS/2
DMI Port Connector
port type USB
DMI Port Connector
DMI Extension Slot
designation PCI0
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI3
type PCI
width 32 bits
populated no
DMI Extension Slot
designation AGP
type AGP
width 32 bits
populated no
usage System Memory
correction None
max# of devices 3
DMI Memory Device
designation A0
format DIMM
type unknown
size 512 MBytes
DMI Memory Device
designation A1
format DIMM
type unknown
size 512 MBytes
DMI Memory Device
designation A2
format DIMM
type unknown
size 256 MBytes
Graphics
Graphic APIs
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
Memory size 512 MB
GPU ref clock 27000
Performance Level 0
Display adapter 1
Memory size 512 MB
Performance Level 0
Software
Послушайте уважаемые!Upgrader писал(а):А по современнее ничего не нашлось?
Нашлось то что подходит для определенных целей! Мне что под протеус и программатор нужно покупать четырех ядерный компьютер с видеокартой на 1 гиг памяти???
DMI BIOS
version 6.00 PG
date 07/23/2003
scio me nihil scire...
_______________________
<= Жалобная кнопка в правом нижнем углу... )
о чем я и говорил:обновите биос!
но нужно это делать осторожно.
в нэте найдете как это сделать.
Cпасибо
Нашел утилиту производителя платы которая шьет биос... Попробую разобраться.....
А какая частота, по вашему, должна быть?осторожно! леоныч!!! писал(а):..Процессор amd athlon 2900+ Но хр видит его как 1,6ггц.... Пичалька....
Любой, заслуживающий внимания, опыт приобретается себе в убыток...
Перепрошил биос утилитой Epox Magic Flash 2.0
Файлик бин - 8k9a4813.bin
Это 2004 год. Не знаю самый новый я нашел или нет... Но частота процессора осталось той же
А везде написано что частота у него 2900мгц (реальная 2000мгц)
Это не реальная частота, а эквивалентная..
Ну тогда поставить вручную: Multiplier x FSB 10.0 x 200 MHz
Покопался в залежах....
Нашел еще процессоры
Совсем ацццтой - amd athlon 1900
еще - amd athlon 2100
и - amd athlon 2000
Но по моему они не сравнятся с тем что стоит сейчас (amd athlon 2900)
Ок попробую в ручную....
и - amd athlon 2000
Изменил значение в биос с 166 на 200.... Комп отказался загружаться.....
Это же Barton? Не-barton 2900+ вроде как нету. А у Barton FSB вообще-то 200, а не 166. Вот и поставь её руками 200 - и будут твои 2000МГц частоты.
Во, уже успели написать..
Память какая? Простыню лень читать. Может память не способна на такой манёвр?осторожно! леоныч!!! писал(а):Изменил значение в биос с 166 на 200.... Комп отказался загружаться.....
Это как раз Barton! Только сейчас посмотрел повнимательнее
Память 3 модуля. 2 по 512 и 1 на 256мб...
Да плевать на её объём. DDR333, DDR400, DDR266
При загрузке пишет 400... Но это не то наверное....
Проверил утилитой - тайминг пишет DRAM FREQUENCY 166.7 МГЦ.... потеря потерь....
Последний раз редактировалось осторожно! леоныч!!! Пн апр 02, 2012 14:40:25, всего редактировалось 2 раза.
Тогда надо доставать всю кучу памяти и оставить для начала одну самую нормальную планку. Которая точно PC3200, она же DDR400. И не какой-то говёный NoName
Если это правда то маловато будет.осторожно! леоныч!!! писал(а):Voltage 2 2.94 Volts [0xB8] (+3.3V)
