Сделал прошивку драйвера ШД при помощи CodeVision:
#include <tiny2313a.h>
#include <delay.h>
// Declare your global variables here
char cTable[][4] = {
{0xff,0x00,0x00,0x00},
{0xff,0xff,0x00,0x00},
{0x00,0xff,0x00,0x00},
{0x00,0xff,0xff,0x00},
{0x00,0x00,0xff,0x00},
{0x00,0x00,0xff,0xff},
{0x00,0x00,0x00,0xff},
{0xff,0x00,0x00,0xff}};
void SetState( char cState[] )
if( cState[0] > 0 && cState[2] > 0 ||
cState[1] > 0 && cState[3] > 0)
delay_ms(5000);
return;
OCR0A = cState[0];
OCR1A = cState[1];
OCR0B = cState[2];
OCR1B = cState[3];
void main(void)
// Declare your local variables here
// Crystal Oscillator division factor: 1
#pragma optsize-
CLKPR=0x80;
CLKPR=0x00;
#ifdef _OPTIMIZE_SIZE_
#pragma optsize+
#endif
// Input/Output Ports initialization
// Port A initialization
// Func2=In Func1=In Func0=In
// State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
// Func7=In Func6=In Func5=In Func4=Out Func3=Out Func2=Out Func1=In Func0=In
// State7=T State6=T State5=T State4=0 State3=0 State2=0 State1=T State0=T
PORTB=0x00;
DDRB=0x1C;
// Port D initialization
// Func6=In Func5=Out Func4=In Func3=In Func2=In Func1=In Func0=In
// State6=T State5=0 State4=T State3=T State2=T State1=T State0=T
PORTD=0x00;
DDRD=0x20;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: 125,000 kHz
// Mode: Fast PWM top=0xFF
// OC0A output: Non-Inverted PWM
// OC0B output: Non-Inverted PWM
TCCR0A=0xA3;
TCCR0B=0x03;
TCNT0=0x00;
OCR0A=0x00;
OCR0B=0x00;
// Timer/Counter 1 initialization
// Mode: Fast PWM top=0x00FF
// OC1A output: Non-Inv.
// OC1B output: Non-Inv.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0xA1;
TCCR1B=0x0B;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// Interrupt on any change on pins PCINT0-7: Off
GIMSK=0x00;
MCUCR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// Universal Serial Interface initialization
// Mode: Disabled
// Clock source: Register & Counter=no clk.
// USI Counter Overflow Interrupt: Off
USICR=0x00;
// USART initialization
// USART disabled
UCSRB=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
DIDR=0x00;
OCR0A = 0;
OCR0B = 0;
OCR1A = 0;
OCR1B = 0;
while(1)
int i=0;
for(i=0; i<8; i++)
SetState( cTable[i] );
delay_ms( 2 );
Хочу расширить этот массив, на что компилятор мне говорит что я вылез за пределы памяти RAM.
Почитал, вроди как надо разместить его во flash.
Пометил массив и аргумент в функции как flesh. Все скомпилировалось и собралось без проблем!
Прошиваю как обычно, программатором TL866a, хекс файл в "Code memo", ставлю в плату и нифига не работает.
Подумал, что массив не правильный налепил, попробовал просто пометить в рабочей прошивке массив и аргумент как flash и тоже перестало работать. Без flash этот маленький массив работает.
Помогите, что надо сделать чтобы большой массив разместить во flash а не в ram как по умолчанию?
Гуглил много, но ничего не помогло
