#include <mega32.h>
#include <delay.h>
#include "diskio.h"
#include "pff.h"
#define _XTAL_FREQ 16000000
#define WS 1
#define BCK 0
#define DATA 2
#define Set_0_DATA PORTA &= ~(1 << DATA)
#define Set_1_DATA PORTA |= (1 << DATA)
#define BeginTakt PORTA &= ~(1 << BCK)
#define EndTakt PORTA |= (1 << BCK)
#define Select_A PORTA &= ~(1 << WS)
#define Select_B PORTA |= (1 << WS)
#define Init_I2S DDRA |= (1 << WS)|(1 << BCK)|(1 << DATA); PORTA |= (1 << WS)|(1 << BCK)|(1 << DATA); Select_A
unsigned char buff[512];
volatile unsigned int n = 0;
void Write_Data(unsigned char DataR, unsigned char DataL)
unsigned char i;
Select_A;
for (i = 0; i < 8; i++)
if ((DataR & 0x80) == 0x00)
Set_0_DATA;
else
Set_1_DATA;
DataR = DataR << 1;
BeginTakt;
#asm("nop");
EndTakt;
Set_0_DATA;
BeginTakt;
#asm("nop");
EndTakt;
Select_B;
if ((DataL & 0x80) == 0x00)
Set_0_DATA;
else
Set_1_DATA;
DataL = DataL << 1;
BeginTakt;
#asm("nop");
EndTakt;
Set_0_DATA;
BeginTakt;
#asm("nop");
EndTakt;
interrupt[TIM0_OVF] void Timer0_OVF_8bit (void)
Write_Data(buff[n], buff[n]); // Предпологаю что ошибка тут.
n++;
if (n > 511) n = 0;
TCNT0 = 0xC5; //~32000 Гц
void Play(char *Name)
WORD bt;
unsigned char p = 0;
pf_open(Name);
TIMSK = 0x01;
while(1)
if (!p && n > 255)
pf_read(&buff[0], 256, &bt);
p = 1;
if (bt < 256) break;
if (p && n < 256)
pf_read(&buff[256], 256, &bt);
p = 0;
TIMSK = 0x00;
void main(void)
FATFS FS;
DDRA = 0xff;
PORTA = 0x00;
TCCR0 = 0b00000010;
Init_I2S;
delay_ms(100);
if (disk_initialize() == 0) if (pf_mount(&FS) == 0) if (pf_open("1.wav") == 0) PORTA.3 = 1;
delay_ms(1000);
#asm("sei")
Play("1.wav");
while(1)
PORTA.3 = !PORTA.3;
delay_ms(1000);
