#include "stm32f10x.h"
#include "stm32f10x_rcc.h"
#include "stm32f10x_gpio.h"
#include "stm32f10x_spi.h"
#include "hd44780_driver.h"
#define Set_0_DI GPIOB -> BSRR = GPIO_BSRR_BR14 // Для програмного SPI
#define Set_1_DI GPIOB -> BSRR = GPIO_BSRR_BS14
#define Get_X_DO GPIOB -> IDR & GPIO_IDR_IDR15
#define BeginTakt GPIOB -> BSRR = GPIO_BSRR_BS13
#define EndTakt GPIOB -> BSRR = GPIO_BSRR_BR13
#define SELECT() GPIOB -> BSRR = GPIO_BSRR_BR12 // Управление CS
#define DESELECT() GPIOB -> BSRR = GPIO_BSRR_BS12
#define CMD0 (0x40+0) // Команды флешке microsd
#define CMD8 (0x40+8)
#define CMD55 (0x40+55)
void delay(uint32_t n) // Задержка
while (n--) {}
void INIT_SPI(void) // Инициализация SPI прогрммного или аппаратного
SPI_InitTypeDef SPI_2;
GPIO_InitTypeDef PORTB;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
PORTB.GPIO_Pin = GPIO_Pin_12;
PORTB.GPIO_Mode = GPIO_Mode_Out_PP;
PORTB.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOB, &PORTB);
PORTB.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
PORTB.GPIO_Mode = GPIO_Mode_AF_PP;
SPI_2.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_2.SPI_Mode = SPI_Mode_Master;
SPI_2.SPI_DataSize = SPI_DataSize_8b;
SPI_2.SPI_CPOL = SPI_CPOL_Low;
SPI_2.SPI_CPHA = SPI_CPHA_1Edge;
SPI_2.SPI_NSS = SPI_NSS_Soft;
SPI_2.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
SPI_2.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_2.SPI_CRCPolynomial = 7;
SPI_Init(SPI2, &SPI_2);
SPI_CalculateCRC(SPI2, DISABLE);
SPI_Cmd(SPI2, ENABLE);
SPI_NSSInternalSoftwareConfig(SPI2, SPI_NSSInternalSoft_Set);
GPIO_InitTypeDef GPIO_InitStructure;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
void Write_SPI(uint8_t Data) // Передача по SPI аппаратно или программно
while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET){}
SPI_I2S_SendData(SPI2, Data);
uint8_t i;
for (i = 0; i < 8; i++)
if ((Data & 0x80) == 0x00) Set_0_DI; else Set_1_DI;
Data = Data << 1;
BeginTakt;
EndTakt;
uint8_t Read_SPI(void) // Прием по SPI аппаратно или программно
while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET){} // Тут виснет
return SPI_I2S_ReceiveData(SPI2);
uint8_t i, Data = 0x00;
Write_SPI(0xff);
for(i = 0; i < 8; i++)
BeginTakt;
Data = Data << 1;
if (Get_X_DO) Data = Data | 0x01;
EndTakt;
return Data;
uint8_t Send_CMD(uint8_t cmd, uint32_t arg) // Посылка команды карте
uint8_t n, res;
if (cmd & 0x80)
cmd &= 0x7F;
res = Send_CMD(CMD55, 0);
if (res > 1) return res;
DESELECT();
Read_SPI();
SELECT();
Read_SPI();
Write_SPI(cmd);
Write_SPI((uint8_t)(arg >> 24));
Write_SPI((uint8_t)(arg >> 16));
Write_SPI((uint8_t)(arg >> 8));
Write_SPI((uint8_t)arg);
n = 0x01;
if (cmd == CMD0) n = 0x95;
if (cmd == CMD8) n = 0x87;
Write_SPI(n);
n = 10;
do
res = Read_SPI();
} while ((res & 0x80) && --n);
return res;
uint8_t SD_Init(void) // Перевод карты в SPI режим и посылка CMD0 инициализация начало.
uint8_t n;
INIT_SPI();
DESELECT();
for (n = 16; n; n--) Read_SPI();
SELECT();
if (Send_CMD(CMD0, 0) == 1) {return 0;} else {return 1;}
int main(void)
delay(10000000);
lcd_init();
lcd_clear();
lcd_set_xy(0,0);
lcd_out("Init_LCD_OK");
delay(10000000);
lcd_clear();
lcd_set_xy(0,0);
if (SD_Init() == 0) lcd_out("MicroSD_OK"); else lcd_out("MicroSD_Error");
while(1)
