Создание ЧПУ
Сообщение Ruzik »
Код так разве должен выглядеть?
Спойлер( Карман 3 )
( File created: Tuesday July 21 2015 - 11:50 PM)
( for Mach2/3 from Vectric )
( Material Size)
( X= 7.283, Y= 8.203, Z= 2.000)
(Toolpaths used in this file:)
(Карман 3)
(Tools used in this file: )
(1 = End Mill {0.125 inch})
N100G00G21G17G90G40G49G80
N110G71G91.1
N120T1M06
N130 (End Mill {0.125 inch})
N140G00G43Z20.320H1
N150S12000M03
N160(Toolpath:- Карман 3)
N170()
N180G94
N190X0.000Y0.000F20.0
N200G00X5.080Y14.030Z5.080
N210G1Z-0.286F20.0
N220G3X4.980Y13.930I0.000J-0.100
N230G1Y8.930
N240G3X5.080Y8.830I0.100J0.000
N250G3X5.180Y8.930I0.000J0.100
N260G1Y13.930
N270G3X5.080Y14.030I-0.100J0.000
N280G00Z5.080
N290G1Z-0.571F20.0
N300G3X4.980Y13.930I0.000J-0.100
N310G1Y8.930
N320G3X5.080Y8.830I0.100J0.000
N330G3X5.180Y8.930I0.000J0.100
N340G1Y13.930
N350G3X5.080Y14.030I-0.100J0.000
N360G00Z5.080
N370G1Z-0.857F20.0
N380G3X4.980Y13.930I0.000J-0.100
N390G1Y8.930
N400G3X5.080Y8.830I0.100J0.000
N410G3X5.180Y8.930I0.000J0.100
N420G1Y13.930
N430G3X5.080Y14.030I-0.100J0.000
N440G00Z5.080
N450G1Z-1.143F20.0
N460G3X4.980Y13.930I0.000J-0.100
N470G1Y8.930
N480G3X5.080Y8.830I0.100J0.000
N490G3X5.180Y8.930I0.000J0.100
N500G1Y13.930
N510G3X5.080Y14.030I-0.100J0.000
N520G00Z5.080
N530G1Z-1.429F20.0
N540G3X4.980Y13.930I0.000J-0.100
N550G1Y8.930
N560G3X5.080Y8.830I0.100J0.000
N570G3X5.180Y8.930I0.000J0.100
N580G1Y13.930
N590G3X5.080Y14.030I-0.100J0.000
N600G00Z5.080
N610G1Z-1.714F20.0
N620G3X4.980Y13.930I0.000J-0.100
N630G1Y8.930
N640G3X5.080Y8.830I0.100J0.000
N650G3X5.180Y8.930I0.000J0.100
N660G1Y13.930
N670G3X5.080Y14.030I-0.100J0.000
N680G00Z5.080
N690G1Z-2.000F20.0
N700G3X4.980Y13.930I0.000J-0.100
N710G1Y8.930
N720G3X5.080Y8.830I0.100J0.000
N730G3X5.180Y8.930I0.000J0.100
N740G1Y13.930
N750G3X5.080Y14.030I-0.100J0.000
N760G00Z5.080
N770G00Z20.320
N780G00X0.000Y0.000
N790M09
N800M30
N100, N110, N120 и тд, может делаю не так?
Сообщение mr_kot »
Ruzik писал(а):N100, N110, N120 и тд, может делаю не так?
Это нумерация строк. В арткаме есть возможность включать/отключать. Думаю, и здесь тоже можно
Сообщение nhrib »
GCode(mm)(*.tap)
сохрани так - посмотри :))
Сообщение Ruzik »
nhrib
Сделал, хорошая программа. :)
Делал первый раз, перемудрил с толщиной. Получилось 7 проходов по 0,3 мм при толщине заготовки 2 мм, надо было ставить 1,5 мм. Ну ладно, для первого раза пойдет. :)
Видео..
Фото..
Код УП во вложении..
Пазы.txt
(8.92 КБ) 218 скачиваний
Сообщение nhrib »
Тише едешь- дальше будешь.
Сообщение mr_kot »
Эт точно. Единственный недостаток такого резания - кончик фрезы будет намного быстрее садиться. При том, что остальная часть будет практически новая.
Сообщение Ruzik »
Если смотреть на фото, то место входа фрезы все равно разбивает паз. :(
Сообщение mr_kot »
Фреза не предназначена для сверления. По крайней мере та, у которой отсутствует центр. В арткаме есть опция "Наклонное врезание" в обработке по контуру.
Может это поможет. Я сам эту опцию не проверял, не было необходимости. Но, как я понимаю, это и есть не вертикальное врезание фрезы в материал, а плавное, вдоль вектора. Надо будет как-то проверить. Но это не скоро. Шпиндель все-таки отошел в мир иной :cry:
(22.1 КБ) 1915 скачиваний
Сообщение mial »
Я помню раньше делал вообще ручками в два прохода. Первый проход идет плавно врезаясь по Z, к концу паза Z уже на рабочей глубине. Второй проход выбирает остаток от первого. Вроде не плохо получалось. Сейчас делаю с отверстием для захода и в один проход фрезой. Отверстие заранее подставляю в ДТ, потом отдельно генерю им же программу для пазов. Единственно нужно смотреть откуда ДТ начинает делать паз, там и ставить доп отверстие. Проблем нет, пазы ровные.
Сообщение Бурабат »
Вот снова скомбинировал. не знаю какой номинал резистора в затвор IRF7313 поставить
Инвалиды, тоже люди
Сообщение nhrib »
mr_kot
Есть у Вектрика похожая приблуда - только насколько она эффективна - неизвестно
https://cloud.mail.ru/public/5pjB/aZmTT6ZhF
Сообщение Ruzik »
И как там это сделать?
Сообщение nhrib »
Пошарься ещё здесь в разделе "2D Toolpaths":
http://support.vectric.com/tutorials/V8 ... Index.html#
Сообщение Ruzik »
Что за "дистанция" 4 мм, от чего до чего?
Сообщение nhrib »
по-моему то что выделено красным, точно пока не определил.
Это из справки:
Ramp Plunge Moves
The cutter can be ramped over a distance into the pocket instead of plunging vertically. This approach reduces heat build-up that damages the cutter
and also reduces the load on the spindle and z axis bearings.
Сообщение Ruzik »
То есть дистанция не может быть больше длины паза минус диаметр фрезы?
Сообщение nhrib »
Не знаю пока, Рузик.
https://cloud.mail.ru/public/EYrn/4uX6nRRuM
Последний раз редактировалось nhrib Пт июл 24, 2015 05:45:00, всего редактировалось 1 раз.
Сообщение Ruzik »
Надо будет попробовать по наклонной.
Сообщение nhrib »
http://www.youtube.com/watch?v=0Czw_LZfejs
вот здесь вроде про зигзаг немного объясняют
Сообщение troyep »
Бурабат по -моему ваша схема не будет работать с Mach -м. у него вход не степ/дир , а скорее он для программы Р. Ветрова.
если у вас есть доступ к микросхемам отечественного производства- то настоятельно рекомендую эту схему (автор falconist,)
сразу степ /дир+ ограничение тока (ссылка)
http://forum.cxem.net/index.php?showtop ... try1082978
или вот- ж. Радио#5 2008 стр. 45
(160.52 КБ) 355 скачиваний
(193.47 КБ) 558 скачиваний
