Освоение USART, совсем запутался, помогите.
Сообщение Frosty85 »
Вернемся к нашим попугаям )))
Принято решение собрать на Atmega8 с железным USART работа по прерыванию по INT1
(модераторам прошу перенести тему в соответствующий раздел)
This program was created by the
CodeWizardAVR V3.12 Advanced
Automatic Program Generator
© Copyright 1998-2014 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date    : 19.10.2015
Author  :
Company :
Comments:
Chip type               : ATmega8A
Program type            : Application
AVR Core Clock frequency: 8,000000 MHz
Memory model            : Small
External RAM size       : 0
Data Stack size         : 256
#include <mega8.h>
// Declare your global variables here
// External Interrupt 1 service routine
interrupt [EXT_INT1] void ext_int1_isr(void)
USART_Transmit( unsigned char data )
// Standard Input/Output functions
#include <stdio.h>
void USART_Transmit( unsigned char data );
void USART_Init( unsigned int ubrr);
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port B initialization
// Function: Bit7=In Bit6=In Bit5=In Bit4=In Bit3=In Bit2=In Bit1=In Bit0=In
DDRB=(0<<DDB7) | (0<<DDB6) | (0<<DDB5) | (0<<DDB4) | (0<<DDB3) | (0<<DDB2) | (0<<DDB1) | (0<<DDB0);
// State: Bit7=T Bit6=T Bit5=T Bit4=T Bit3=T Bit2=T Bit1=T Bit0=T
PORTB=(0<<PORTB7) | (0<<PORTB6) | (0<<PORTB5) | (0<<PORTB4) | (0<<PORTB3) | (0<<PORTB2) | (0<<PORTB1) | (0<<PORTB0);
// Port C initialization
// Function: Bit6=In Bit5=In Bit4=In Bit3=In Bit2=In Bit1=In Bit0=In
DDRC=(0<<DDC6) | (0<<DDC5) | (0<<DDC4) | (0<<DDC3) | (0<<DDC2) | (0<<DDC1) | (0<<DDC0);
// State: Bit6=T Bit5=T Bit4=T Bit3=T Bit2=T Bit1=T Bit0=T
PORTC=(0<<PORTC6) | (0<<PORTC5) | (0<<PORTC4) | (0<<PORTC3) | (0<<PORTC2) | (0<<PORTC1) | (0<<PORTC0);
// Port D initialization
// Function: Bit7=In Bit6=In Bit5=In Bit4=Out Bit3=In Bit2=In Bit1=In Bit0=In
DDRD=(0<<DDD7) | (0<<DDD6) | (0<<DDD5) | (1<<DDD4) | (0<<DDD3) | (0<<DDD2) | (0<<DDD1) | (0<<DDD0);
// State: Bit7=T Bit6=T Bit5=T Bit4=0 Bit3=T Bit2=T Bit1=T Bit0=T
PORTD=(0<<PORTD7) | (0<<PORTD6) | (0<<PORTD5) | (0<<PORTD4) | (0<<PORTD3) | (0<<PORTD2) | (0<<PORTD1) | (0<<PORTD0);
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
TCCR0=(0<<CS02) | (0<<CS01) | (0<<CS00);
TCNT0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer1 Stopped
// Mode: Normal top=0xFFFF
// OC1A output: Disconnected
// OC1B output: Disconnected
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=(0<<COM1A1) | (0<<COM1A0) | (0<<COM1B1) | (0<<COM1B0) | (0<<WGM11) | (0<<WGM10);
TCCR1B=(0<<ICNC1) | (0<<ICES1) | (0<<WGM13) | (0<<WGM12) | (0<<CS12) | (0<<CS11) | (0<<CS10);
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer2 Stopped
// OC2 output: Disconnected
ASSR=0<<AS2;
TCCR2=(0<<PWM2) | (0<<COM21) | (0<<COM20) | (0<<CTC2) | (0<<CS22) | (0<<CS21) | (0<<CS20);
TCNT2=0x00;
OCR2=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=(0<<OCIE2) | (0<<TOIE2) | (0<<TICIE1) | (0<<OCIE1A) | (0<<OCIE1B) | (0<<TOIE1) | (0<<TOIE0);
// External Interrupt(s) initialization
// INT0: Off
// INT1: On
// INT1 Mode: Any change
GICR|=(1<<INT1) | (0<<INT0);
MCUCR=(0<<ISC11) | (1<<ISC10) | (0<<ISC01) | (0<<ISC00);
GIFR=(1<<INTF1) | (0<<INTF0);
// USART initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART Receiver: Off
// USART Transmitter: On
// USART Mode: Sync. Master UCPOL=0
// USART Baud Rate: 15625
UCSRA=(0<<RXC) | (0<<TXC) | (0<<UDRE) | (0<<FE) | (0<<DOR) | (0<<UPE) | (0<<U2X) | (0<<MPCM);
UCSRB=(0<<RXCIE) | (0<<TXCIE) | (0<<UDRIE) | (0<<RXEN) | (1<<TXEN) | (0<<UCSZ2) | (0<<RXB8) | (0<<TXB8);
UCSRC=(1<<URSEL) | (1<<UMSEL) | (0<<UPM1) | (0<<UPM0) | (0<<USBS) | (1<<UCSZ1) | (1<<UCSZ0) | (0<<UCPOL);
UBRRH=0x00;
UBRRL=0xFF;
// Analog Comparator initialization
// Analog Comparator: Off
// The Analog Comparator's positive input is
// connected to the AIN0 pin
// The Analog Comparator's negative input is
// connected to the AIN1 pin
ACSR=(1<<ACD) | (0<<ACBG) | (0<<ACO) | (0<<ACI) | (0<<ACIE) | (0<<ACIC) | (0<<ACIS1) | (0<<ACIS0);
SFIOR=(0<<ACME);
// ADC initialization
// ADC disabled
ADCSRA=(0<<ADEN) | (0<<ADSC) | (0<<ADFR) | (0<<ADIF) | (0<<ADIE) | (0<<ADPS2) | (0<<ADPS1) | (0<<ADPS0);
// SPI initialization
// SPI disabled
SPCR=(0<<SPIE) | (0<<SPE) | (0<<DORD) | (0<<MSTR) | (0<<CPOL) | (0<<CPHA) | (0<<SPR1) | (0<<SPR0);
// TWI initialization
// TWI disabled
TWCR=(0<<TWEA) | (0<<TWSTA) | (0<<TWSTO) | (0<<TWEN) | (0<<TWIE);
// Global enable interrupts
#asm("sei")
while (1)
      // Place your code here
Многоуважаемый vladlen-from-vrtp поделился вариантом на PIC12F629 как раз то что мне нужно, но перечитав весь даташит на этот контроллер так и не нашел регистр отвечающий за настройку нужной мне тактовой частоты (SCLK) прошу помощи как мне допилить данный код чтобы можно было выставлять частоту, или ткните носом где это в коде :(
// PIC12F629 Configuration Bit Settings
// 'C' source line config statements
#include <xc.h>
#include <stdint.h>
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// CONFIG
#pragma config FOSC = INTRCIO   // Oscillator Selection bits (INTOSC oscillator: I/O function on GP4/OSC2/CLKOUT pin, I/O function on GP5/OSC1/CLKIN)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT enabled)
#pragma config PWRTE = OFF      // Power-Up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = OFF       // GP3/MCLR pin function select (GP3/MCLR pin function is MCLR)
#pragma config BOREN = ON       // Brown-out Detect Enable bit (BOD enabled)
#pragma config CP = OFF         // Code Protection bit (Program Memory code protection is disabled)
#pragma config CPD = OFF        // Data Code Protection bit (Data memory code protection is disabled)
#define _XTAL_FREQ  4000000L
#define MOSI      GP0
#define MISO      GP1
#define SCK       GP2
#define SS        GP5
#define GPIO_Tx   GP4
#define TRIS_Tx   TRISIObits.TRISIO4
const uint8_t arr_data[] = {
    0x00
unsigned char flag;
enum {
    reset = 0,
    in = 1,   //приняли байт
void Init_MCU(void);
void SPI_write_LSB (uint8_t);
void SPI_send_arr_data(void);
void Init_MCU(void) {
    GPIO = 0;
    CMCON = 7;
    TRISIO = 0b00010010; //GP4,GP1 input
    GPIF = 0;
    GPIE = 1;
    IOCB4 = 1;  //GP4 interrupt
    PEIE = 1;
    GIE = 1;
void main(void) {
    Init_MCU();
    SS=1;
    while (1) {
        switch(flag) {
            case in: SPI_send_arr_data();
            break;
        __delay_ms(100);
void SPI_send_arr_data(void) {
    SS = 0;
    for (uint8_t i = 0; i<sizeof (arr_data); i++) {
        SPI_write_LSB(arr_data[i]);
    SS = 1;
    flag = reset;
void SPI_write_LSB (uint8_t data) {
    unsigned char mask = 0x01;
    while (mask) {
        if (data & mask)MOSI = 1;
        else MOSI = 0;
        SCK = 1;
        __delay_us(46);
        SCK = 0; //
        __delay_us(46);
        mask <<= 1;
interrupt void IRQ(void) {
    flag = GPIO;
    if (GPIF && GP4 == 0) {
        flag = in;
    GPIF = 0;
Сообщение shindax »
У этого МК внутренний осциллятор может работать только на 4МГц. У более поздних можно настройкой OSCCON выбрать другие частоты (8МГц, 4МГц, 2МГц и т.д. до 31КГц ). Для 675-го внутренний осциллятор можно лишь настроить поточнее, используя калибровочную константу. В XC8 для этого есть макрос:
OSCCAL = _READ_OSCCAL_DATA();
Но эта константа должна быть в последней ячейке памяти МК в виде retlw 0xXX. Нормальные программаторы её сохраняют, PicKit ещё и восстанавливает потёртую, это нужно учесть. Попытка использовать константу при её отсутствии, вызовет зависание МК по понятным причинам.
После долгих изучений, анализа и прочего, в голове сложилась картина что это вовсе не UART а SPI, вот только передача идет не по битно 8n1 а единым целым 128bit апаратно это реализовать нереально, вопрос как программно это можно реализовать. Гугл да и все остальные форумы выдают только программную реализацию SPI на 8 максимум 16bit
Сообщение КРАМ »
Frosty85 писал(а):а единым целым 128bit апаратно это реализовать нереально, вопрос как программно это можно реализовать.
Не вижу никаких препятствий к аппаратной реализации "единых целых 128 бит".
SPI - это просто сдвиговый регистр и переданные подряд 16 байт дадут искомые 128 бит.
Все равно начало и конец пакета по SPI определит синхронизирующий CS.
Да согласен, но судя по анализу сигнала при вашем варианте аппаратного SPI между байтами передаваемой информации будет другой временной интервал (если судить по шине SCK) там идет тактовый импульс на 8 бит потом временная задержка и снова тактовый импульс на 8 бит)
А в моем случае этой временной задержки недолжно быть, т.е. последовательная передача всех 136 бит
Сообщение vladlen-from-vrtp »
Frosty85 писал(а): А в моем случае...
В Вашем случае ясно видно непонимание происходящего.
Вы абсолютно не представляете о чем говорите, на мой взгляд, почему я и не стал дальше Вам помогать.
Сообщение КРАМ »
Frosty85 писал(а): А в моем случае этой временной задержки недолжно быть, т.е. последовательная передача всех 136 бит
Херню не надо городить.
Совершенно безразлично какая временная задержка между байтами и даже между битами. защелкивание в сдвиговом регистре приемника происходит по фронту тактирующего импульса и главное, чтобы значение бита совпадало с ЭТИМ ФРОНТОМ.
Можно даже тактирующие клоки модулировать по частоте совершенно произвольно. Временные задержки НЕ ОПРЕДЕЛЯЮТ ГРАНИЦЫ БАЙТ.
Хорошо раз я не совсем догоняю, или не могу внятно обьяснить, покажу на примерах.
Вот стандартный SPI
Стандартный SPI
(3.51 КБ) 449 скачиваний
А в моем случае нужно сделать вот такой вариант SPI
Нестандартный SPI
(152.44 КБ) 273 скачивания
первый канал - данные в виде 136 бит
второй канал - SCK
третий канал - входной сигнал на разрешение передачи данных (не путать с SS)
Как видно из картинок, в сандартном SPI есть промежуток между байтами это видно по SCK
А в моем случае его нет и идет все единой цепочкой, плюс ко всему в стандартном SPI тактовая частота SCK начинает выдаваться как только придет управляющая команда с SS (сброс в логический 0 ), а в моем случае этот тактовый сигнал начинает генерироваться с момента подачи питания на МК и относительно него уже формируется выходные данные.
Как вариант исполнения, на той же самой Atmega8 управляющий сигнал привязать к внешнему прерыванию INT1 или INT0, тактовую частоту задать с любого выхода к примеру pd6 ну а вывод данных реализовать на таймере T1
Это только мое предположение. не пинайте и не ругайте, я только учусь.
И в целом это очень похоже на RFID-эмулятор, только разница в том что тактовый сигнал не приходит в МК, а наоборот им же и формируется и относительно него выдает данные.
Сообщение КРАМ »
Вы плохо понимаете о чем Вам говорят. Ну то есть вообще не понимаете.
Клоки в синхронном интерфейсе потому и называются клоками, что они ЖИЗНЬ. Жизнь и внутреннее время интерфейса.
Если клоки нелинейны в реальном времени, то сам интерфейс ничего об этом не знает. Для него время всегда линейно, а пробелы между группами клоков - анабиоз. Как и для контроллера, кстати. Можно остановить клоки и он впадет в спячку, продолжить - и он не заметит украденного у него времени. И дело тут не в том как назвать интерфейс, а В ПРИНЦИПЕ ЕГО СИНХРОННОСТИ.
Нижний сигнал задает начало отсчета 136 бит. И далее число бит равно числу КЛОКОВ. Хоть бы даже последний придет через год, а предпоследний через 20 миллисекунд.
Кроме того, пауза между клоками отдельных байт в SPI определяется построением программы. То есть если грузить выходной буфер SPI немедленно как он освободится (в прерывании), то и зазор будет определяться соотношением частоты SPI и машинным циклом МК.
При соотношении 1:10 разглядеть зазор на диаграмме будет невозможно.
А если соотношение 1:2, то сформировать 8-битным контроллером вывод без зазоров ПРИНЦИПИАЛЬНО НЕВОЗМОЖНО, поскольку он 8-битный и требуется загрузка каждого байта.
Сообщение Аlex »
Frosty85, а зачем кучу тем создавать, в которых Вам одно и то же разжёвывают ? :facepalm:
То AVR, то PIC, то Си, то АСМ, то UART, то уже SPI, 128 бит, потом уже откуда то взялось число 136, ..... Определитесь уже, наконец, что Вы делаете, на чём и для чего ...
я просто не знаю как удалить тему ((( или закрыть ее.
Вернуться в «PIC»
