usb custom hid
Alex_Golubev
usb custom hid
Сообщение Alex_Golubev »
всем привет.
Столкнулся с проблемой реализации custom hid на stm32f429-disco. Не принимает данные хост пк.
Windows HID simplification
Alan Ott
Signal 11 Software
8/22/2009
Copyright 2009, All Rights Reserved.
This contents of this file may be used by anyone
for any reason without any conditions and may be
used as a starting point for your own applications
which use HIDAPI.
#include <stdio.h>
#include <wchar.h>
#include <string.h>
#include <stdlib.h>
#include "hidapi.h"
// Headers needed for sleeping.
#ifdef _WIN32
   #include <windows.h>
#else
   #include <unistd.h>
#endif
int main(int argc, char* argv[])
   int res;
   unsigned char buf[256];
   #define MAX_STR 255
   wchar_t wstr[MAX_STR];
   hid_device *handle;
   int i;
#ifdef WIN32
   UNREFERENCED_PARAMETER(argc);
   UNREFERENCED_PARAMETER(argv);
#endif
   struct hid_device_info *devs, *cur_dev;
   devs = hid_enumerate(0x0, 0x0);
   cur_dev = devs;
   while (cur_dev) {
      printf("Device Found\n  type: %04hx %04hx\n  path: %s\n  serial_number: %ls", cur_dev->vendor_id, cur_dev->product_id, cur_dev->path, cur_dev->serial_number);
      printf("\n");
      printf("  Manufacturer: %ls\n", cur_dev->manufacturer_string);
      printf("  Product:      %ls\n", cur_dev->product_string);
      printf("  Release:      %hx\n", cur_dev->release_number);
      printf("  Interface:    %d\n",  cur_dev->interface_number);
      printf("\n");
      cur_dev = cur_dev->next;
   hid_free_enumeration(devs);
   // Set up the command buffer.
   memset(buf,0x00,sizeof(buf));
   buf[0] = 0x01;
   buf[1] = 0x81;
   // Open the device using the VID, PID,
   // and optionally the Serial number.
   ////handle = hid_open(0x4d8, 0x3f, L"12345");
   handle = hid_open(0x483, 0x5750, NULL);
   if (!handle) {
      printf("unable to open device\n");
      return 1;
   // Read the Manufacturer String
   wstr[0] = 0x0000;
   res = hid_get_manufacturer_string(handle, wstr, MAX_STR);
   if (res < 0)
      printf("Unable to read manufacturer string\n");
   printf("Manufacturer String: %ls\n", wstr);
   // Read the Product String
   wstr[0] = 0x0000;
   res = hid_get_product_string(handle, wstr, MAX_STR);
   if (res < 0)
      printf("Unable to read product string\n");
   printf("Product String: %ls\n", wstr);
   // Read the Serial Number String
   wstr[0] = 0x0000;
   res = hid_get_serial_number_string(handle, wstr, MAX_STR);
   if (res < 0)
      printf("Unable to read serial number string\n");
   printf("Serial Number String: (%d) %ls", wstr[0], wstr);
   printf("\n");
   // Read Indexed String 1
   wstr[0] = 0x0000;
   res = hid_get_indexed_string(handle, 1, wstr, MAX_STR);
   if (res < 0)
      printf("Unable to read indexed string 1\n");
   printf("Indexed String 1: %ls\n", wstr);
   // Set the hid_read() function to be non-blocking.
   hid_set_nonblocking(handle, 1);
   // Try to read from the device. There shoud be no
   // data here, but execution should not block.
/*   res = hid_read(handle, buf, 17);
   // Send a Feature Report to the device
   buf[0] = 0x2;
   buf[1] = 0xa0;
   buf[2] = 0x0a;
   buf[3] = 0x00;
   buf[4] = 0x00;
   res = hid_send_feature_report(handle, buf, 17);
   if (res < 0) {
      printf("Unable to send a feature report.\n");
   memset(buf,0,sizeof(buf));
   // Read a Feature Report from the device
   buf[0] = 0x2;
   res = hid_get_feature_report(handle, buf, sizeof(buf));
   if (res < 0) {
      printf("Unable to get a feature report.\n");
      printf("%ls", hid_error(handle));
   else {
      // Print out the returned buffer.
      printf("Feature Report\n   ");
      for (i = 0; i < res; i++)
         printf("%02hhx ", buf[i]);
      printf("\n");
/*   memset(buf,0,sizeof(buf));
   // Toggle LED (cmd 0x80). The first byte is the report number (0x1).
   buf[0] = 0x1;
   buf[1] = 0x80;
   res = hid_write(handle, buf, 17);
   if (res < 0) {
      printf("Unable to write()\n");
      printf("Error: %ls\n", hid_error(handle));
   // Request state (cmd 0x81). The first byte is the report number (0x1).
   buf[0] = 0x1;
   buf[1] = 0x81;
   if (res < 0)
      printf("Unable to write() (2)\n");
   // Read requested state. hid_read() has been set to be
   // non-blocking by the call to hid_set_nonblocking() above.
   // This loop demonstrates the non-blocking nature of hid_read().
   res = 0;
   while (res == 0) {
      res = hid_read(handle, buf, sizeof(buf));
      if (res == 0)
         printf("waiting...\n");
      if (res < 0)
         printf("Unable to read()\n");
      #ifdef WIN32
      Sleep(500);
      #else
      usleep(500*1000);
      #endif
   printf("Data read:\n   ");
   printf("\n");
   hid_close(handle);
   /* Free static HIDAPI objects. */
   hid_exit();
#ifdef WIN32
   system("pause");
#endif
   return 0;
репорт устройства
__ALIGN_BEGIN static uint8_t CUSTOM_HID_ReportDesc_HS[USBD_CUSTOM_HID_REPORT_DESC_SIZE] __ALIGN_END =
  /* USER CODE BEGIN 1 */
    0x06, 0x00, 0xff,              // 	USAGE_PAGE (Generic Desktop)
    0x09, 0x01,                    // 	USAGE (Vendor Usage 1)
    // System Parameters
    0xa1, 0x01,                    // 	COLLECTION (Application)
    0x19,0x01,
    0x29,0x40,
    0x15,0x00,
    0x26,0xff,0x00,
    0x75,0x08,
    0x95,CUSTOM_HID_EPOUT_SIZE,
    0x81,0x02,
    0x19,0x01,
    0x29,0x40,
    0x25,0x08,
    0x91,0x02,
  /* USER CODE END 1 */
   0xC0    /*     END_COLLECTION	             */
для передачи использую функцию USBD_CUSTOM_HID_SendReport(hUsbDevice_1, dataToSend, 4);
пк видит hid устройство не ругается. Может кто подскажет в чем может быть дело
(220.34 КБ) 278 скачиваний
Вернуться в «ARM»
