Вот как делаю:
void network_init() {
uint8_t bufSize[] = {2, 2, 2, 2};
reg_wizchip_cs_cbfunc(wizchip_select, wizchip_deselect);
reg_wizchip_spi_cbfunc(wizchip_read, wizchip_write);
wizchip_init(bufSize, bufSize);
wiz_NetInfo netInfo = { .mac = {0x00, 0x08, 0xdc, 0xab, 0xcd, 0xef}, // Mac address
.ip = {192, 168, 1, 123}, // IP address
.sn = {255, 255, 255, 0}, // Subnet mask
.gw = {192, 168, 1, 1}}; // Gateway address
wizchip_setnetinfo(&netInfo);
wizchip_getnetinfo(&netInfo);
delay_ms(2000);
uint8_t *mac = netInfo.mac;
UPRINT("MAC: %02X:%02X:%02X:%02X:%02X:%02X\r\n", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
UPRINT("SIP: %d.%d.%d.%d\r\n", netInfo.ip[0],netInfo.ip[1],netInfo.ip[2],netInfo.ip[3]);
UPRINT("GAR: %d.%d.%d.%d\r\n", netInfo.gw[0],netInfo.gw[1],netInfo.gw[2],netInfo.gw[3]);
UPRINT("SUB: %d.%d.%d.%d\r\n", netInfo.sn[0],netInfo.sn[1],netInfo.sn[2],netInfo.sn[3]);
void init_spi() {
SPI_I2S_DeInit(SPI1);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_SPI1);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_SPI1);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_SPI1);
GPIO_InitTypeDef GPIO_InitStructure;
// SPI
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
// CS
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
SPI_InitTypeDef SPI_InitTypeDefStruct;
SPI_InitTypeDefStruct.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitTypeDefStruct.SPI_Mode = SPI_Mode_Master;
SPI_InitTypeDefStruct.SPI_DataSize = SPI_DataSize_8b;
SPI_InitTypeDefStruct.SPI_CPOL = SPI_CPOL_Low;
SPI_InitTypeDefStruct.SPI_CPHA = SPI_CPHA_1Edge;
SPI_InitTypeDefStruct.SPI_NSS = SPI_NSS_Soft;
SPI_InitTypeDefStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
SPI_InitTypeDefStruct.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_Init(SPI1, &SPI_InitTypeDefStruct);
SPI_Cmd(SPI1, ENABLE);
SPI_NSSInternalSoftwareConfig(SPI1, SPI_NSSInternalSoft_Set);
void wizchip_select () { GPIO_ResetBits (GPIOA, GPIO_Pin_4); }
void wizchip_deselect() { GPIO_SetBits (GPIOA, GPIO_Pin_4); }
void wizchip_write(uint8_t wb) {
while (SPI_GetFlagStatus(SPI1, SPI_FLAG_TXE) == RESET);
SPI_I2S_SendData(SPI1, wb);
uint8_t wizchip_read() {
while (SPI_GetFlagStatus(SPI1, SPI_FLAG_RXNE) == RESET);
return SPI_I2S_ReceiveData(SPI1);
void hw_init() {
RCC_APB2PeriphClockCmd (RCC_APB2Periph_SYSCFG, ENABLE);
RCC_APB2PeriphClockCmd (RCC_APB2Periph_SPI1 , ENABLE);
RCC_AHB1PeriphClockCmd (RCC_AHB1Periph_GPIOA , ENABLE);
RCC_AHB1PeriphClockCmd (RCC_AHB1Periph_GPIOD , ENABLE); // The LEDs are on GPIOD
init_spi();
GPIO_InitStructure.GPIO_Pin = LED_GREEN_PIN|LED_ORANGE_PIN|LED_RED_PIN|LED_BLUE_PIN;
GPIO_Init(GPIOD, &GPIO_InitStructure);
/* Connect PXx to USARTx_Tx* + Rx*/
GPIO_PinAFConfig(DISCOVERY_COM_TX_GPIO_PORT, DISCOVERY_COM_TX_SOURCE, DISCOVERY_COM_TX_AF);
GPIO_PinAFConfig(DISCOVERY_COM_RX_GPIO_PORT, DISCOVERY_COM_RX_SOURCE, DISCOVERY_COM_RX_AF);
USBD_Init(&USB_OTG_dev, USB_OTG_FS_CORE_ID, &USR_desc, &USBD_CDC_cb, &USR_cb);
void SystemClock_Config() {
RCC_GetClocksFreq (&RCC_Clocks);
PWR_MainRegulatorModeConfig(PWR_Regulator_Voltage_Scale2);
RCC_DeInit();
RCC_HSEConfig(RCC_HSE_ON);
RCC_HSICmd(ENABLE);
ErrorStatus HSEStartUpStatus = RCC_WaitForHSEStartUp();
if (HSEStartUpStatus == SUCCESS) {
RCC_HCLKConfig(RCC_SYSCLK_Div1); /* HCLK = SYSCLK */
RCC_PCLK1Config(RCC_HCLK_Div2); /* PCLK1 = HCLK*/
RCC_PCLK2Config(RCC_HCLK_Div1); /* PCLK2 = HCLK*/
RCC_AdjustHSICalibrationValue(0x10);
RCC_PLLConfig(RCC_PLLSource_HSI, 16, 336, 4, 7);
RCC_PLLCmd(ENABLE);
while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) {}
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while (RCC_GetSYSCLKSource() != 0x08) {}
RCC_GetClocksFreq(&RCC_Clocks);
int main() {
if (SysTick_Config(SystemCoreClock / 1000))
while (1) ; // Capture error
hw_init();
SystemClock_Config();
init_eth();
while (1) ;
return 0;
