Изменение файла Startup в STM32F103vet6
loreal1970
Сообщение loreal1970 »
Ребята! Прошу помощи или пояснения.
Возникла необходимость добавить недостающие прерывания.
(DMA2_Channel3_IRQHandler, SDIO_IRQHandler)
Использую вот этот startup
; Amount of memory (in bytes) allocated for Stack and Heap
; Tailor those values to your application needs
Stack_Size   EQU     0x400
Heap_Size    EQU     0x400
; Allocate space for the Stack
  AREA    STACK, NOINIT, READWRITE, ALIGN=3
Stack
    SPACE   Stack_Size
; Allocate space for the Heap
  AREA    HEAP, NOINIT, READWRITE, ALIGN=3
Heap
    SPACE   Heap_Size
;*  Declarations for the interrupt handlers that are used by the application.
  		IMPORT  __main
  		IMPORT  OSPendSV
  		IMPORT  SysTickHandler
  		IMPORT  WWDG_IRQHandler
  		IMPORT  PVD_IRQHandler
  		IMPORT  TAMPER_IRQHandler
  		IMPORT  RTC_IRQHandler
  		IMPORT  FLASH_IRQHandler
  		IMPORT  RCC_IRQHandler
  		IMPORT  EXTI0_IRQHandler
  		IMPORT  EXTI1_IRQHandler
  		IMPORT  EXTI2_IRQHandler
  		IMPORT  EXTI3_IRQHandler
  		IMPORT  EXTI4_IRQHandler
  		IMPORT  DMAChannel1_IRQHandler
  		IMPORT  DMAChannel2_IRQHandler
  		IMPORT  DMAChannel3_IRQHandler
  		IMPORT  DMAChannel4_IRQHandler
  		IMPORT  DMAChannel5_IRQHandler
  		IMPORT  DMAChannel6_IRQHandler
  		IMPORT  DMAChannel7_IRQHandler
  		IMPORT  ADC_IRQHandler
  		IMPORT  USB_HP_CAN_TX_IRQHandler
  		IMPORT  USB_LP_CAN_RX0_IRQHandler
  		IMPORT  CAN_RX1_IRQHandler
  		IMPORT  CAN_SCE_IRQHandler
  		IMPORT  EXTI9_5_IRQHandler
  		IMPORT  TIM1_BRK_IRQHandler
  		IMPORT  TIM1_UP_IRQHandler
  		IMPORT  TIM1_TRG_COM_IRQHandler
  		IMPORT  TIM1_CC_IRQHandler
  		IMPORT  TIM2_IRQHandler
  		IMPORT  TIM3_IRQHandler
  		IMPORT  TIM4_IRQHandler
  		IMPORT  I2C1_EV_IRQHandler
  		IMPORT  I2C1_ER_IRQHandler
  		IMPORT  I2C2_EV_IRQHandler
  		IMPORT  I2C2_ER_IRQHandler
  		IMPORT  SPI1_IRQHandler
  		IMPORT  SPI2_IRQHandler
  		IMPORT  USART1_IRQHandler
  		IMPORT  USART2_IRQHandler
  		IMPORT  USART3_IRQHandler
  		IMPORT  EXTI15_10_IRQHandler
  		IMPORT  RTCAlarm_IRQHandler
  		IMPORT  USBWakeUp_IRQHandler
		PRESERVE8
;*  Reset code section.
        AREA    RESET, CODE, READONLY
        THUMB
; Fill-up the Vector Table entries with the exceptions ISR address
    	EXPORT  __Vectors
__Vectors
    	DCD  Stack + Stack_Size            ; Top of Stack
    	DCD  Reset_Handler
    	DCD  NMIException
    	DCD  HardFaultException
    	DCD  MemManageException
    	DCD  BusFaultException
    	DCD  UsageFaultException
    	DCD  0                 ; Reserved
    	DCD  0                 ; Reserved
    	DCD  0                 ; Reserved
    	DCD  0                 ; Reserved
    	DCD  SVCHandler
    	DCD  DebugMonitor
    	DCD  0                 ; Reserved
    	DCD  OSPendSV
    	DCD  SysTickHandler
    	DCD  WWDG_IRQHandler
    	DCD  PVD_IRQHandler
    	DCD  TAMPER_IRQHandler
    	DCD  RTC_IRQHandler
    	DCD  FLASH_IRQHandler
    	DCD  RCC_IRQHandler
    	DCD  EXTI0_IRQHandler
    	DCD  EXTI1_IRQHandler
    	DCD  EXTI2_IRQHandler
    	DCD  EXTI3_IRQHandler
    	DCD  EXTI4_IRQHandler
    	DCD  DMAChannel1_IRQHandler
    	DCD  DMAChannel2_IRQHandler
    	DCD  DMAChannel3_IRQHandler
    	DCD  DMAChannel4_IRQHandler
    	DCD  DMAChannel5_IRQHandler
    	DCD  DMAChannel6_IRQHandler
    	DCD  DMAChannel7_IRQHandler
    	DCD  ADC_IRQHandler
    	DCD  USB_HP_CAN_TX_IRQHandler
    	DCD  USB_LP_CAN_RX0_IRQHandler
    	DCD  CAN_RX1_IRQHandler
    	DCD  CAN_SCE_IRQHandler
    	DCD  EXTI9_5_IRQHandler
    	DCD  TIM1_BRK_IRQHandler
    	DCD  TIM1_UP_IRQHandler
    	DCD  TIM1_TRG_COM_IRQHandler
    	DCD  TIM1_CC_IRQHandler
    	DCD  TIM2_IRQHandler
    	DCD  TIM3_IRQHandler
    	DCD  TIM4_IRQHandler
    	DCD  I2C1_EV_IRQHandler
    	DCD  I2C1_ER_IRQHandler
    	DCD  I2C2_EV_IRQHandler
    	DCD  I2C2_ER_IRQHandler
    	DCD  SPI1_IRQHandler
    	DCD  SPI2_IRQHandler
    	DCD  USART1_IRQHandler
    	DCD  USART2_IRQHandler
    	DCD  USART3_IRQHandler
    	DCD  EXTI15_10_IRQHandler
    	DCD  RTCAlarm_IRQHandler
    	DCD  USBWakeUp_IRQHandler
    	DCD  0                 ; Reserved
    	DCD  0                 ; Reserved
    	DCD  0                 ; Reserved
    	DCD  0                 ; Reserved
    	DCD  0                 ; Reserved
;*  Reset entry
        EXPORT  Reset_Handler
Reset_Handler
        IMPORT  __main
        LDR     R0, =__main
        BX      R0
;*  NMI exception handler.  -  обработчик исключений
;*  It simply enters an infinite loop.  -  это просто входит в бесконечный цикл
NMIException
        B       NMIException
;*  Fault interrupt handler.   -  обработчик прерываний неисправности
HardFaultException
        B       HardFaultException
;*  MemManage interrupt handler.
MemManageException
        B       MemManageException
;*  Bus Fault interrupt handler.    -  обработчик прерываний шины
BusFaultException
        B       BusFaultException
;*  UsageFault interrupt handler.
UsageFaultException
        B       UsageFaultException
;*  DebugMonitor interrupt handler.
DebugMonitor
        B       DebugMonitor
;*  SVCall interrupt handler.
SVCHandler
        B       SVCHandler
;*  Make sure the end of this section is aligned.
        ALIGN
;*  Code section for initializing the heap and stack   - инициализация кучи и стека
		AREA    |.text|, CODE, READONLY
;*  The function expected of the C library startup
;*  code for defining the stack and heap memory locations.
        IMPORT  __use_two_region_memory
        EXPORT  __user_initial_stackheap
        LDR     R0, =Heap
        LDR     R1, =(Stack + Stack_Size)
        LDR     R2, =(Heap + Heap_Size)
        LDR     R3, =Stack
        BX      LR
        ALIGN
;*  End Of File
        END
Подскажите, как правильно их сюда прописать.
Или, может, другим способом их активировать.
loreal1970
Re: Изменение файла Startup в STM32F103vet6
В общем добавил я в startup недостающие прерывания.
Собственно продолжил таблицу прерываний для HD-линейки.
Вот дополнения
		IMPORT  TIM8_BRK_IRQHandler
		IMPORT  TIM8_UP_IRQHandler
		IMPORT  TIM8_TRG_COM_IRQHandler
		IMPORT  TIM8_CC_IRQHandler
		IMPORT  ADC3_IRQHandler
		IMPORT  FSMC_IRQHandler
		IMPORT  SDIO_IRQHandler
		IMPORT  TIM5_IRQHandler
		IMPORT  SPI3_IRQHandler
		IMPORT  UART4_IRQHandler
		IMPORT  UART5_IRQHandler
		IMPORT  TIM6_IRQHandler
		IMPORT  TIM7_IRQHandler
		IMPORT  DMA2_Channel1_IRQHandler
		IMPORT  DMA2_Channel2_IRQHandler
		IMPORT  DMA2_Channel3_IRQHandler
		IMPORT  DMA2_Channel4_5_IRQHandler
И дальше
		DCD  TIM8_BRK_IRQHandler
		DCD  TIM8_UP_IRQHandler
		DCD  TIM8_TRG_COM_IRQHandler
		DCD  TIM8_CC_IRQHandler
		DCD  ADC3_IRQHandler
		DCD  FSMC_IRQHandler
		DCD  SDIO_IRQHandler
		DCD  TIM5_IRQHandler
		DCD  SPI3_IRQHandler
		DCD  UART4_IRQHandler
		DCD  UART5_IRQHandler
		DCD  TIM6_IRQHandler
		DCD  TIM7_IRQHandler
		DCD  DMA2_Channel1_IRQHandler
		DCD  DMA2_Channel2_IRQHandler
		DCD  DMA2_Channel3_IRQHandler
		DCD  DMA2_Channel4_5_IRQHandler
Сами функции прерываний, откуда берется IMPORT, прописаны в файле stm32f10x_it.c.
Компиляция проходит успешно.
НО вот не задача. В эти дописанные прерывания контроллер не попадает.
Пытался, к примеру зажечь светодиод по прерыванию таймера TIM8, не получилось. Повис.
Точнее у меня заведен IWDG на 2сек. и вместо прерывания TIM8 идет перезагруз.
Подскажите, господа хорошие, что не так. Направьте на путь истинный.
Reflector
Сообщение Reflector »
loreal1970 писал(а):В общем добавил я в startup недостающие прерывания.
Я правильно понял, что ты взял стартап от какого-нибудь 103С8 и дополнил его до 103VE вместо того, чтобы просто взять стартап от 103VE? :)
loreal1970
Нет.
Я взял готовый проект с операционкой uCOS + GUI от платы miniSTM.
Там стоит VET6. И в проекте тоже VET6
Reflector
loreal1970 писал(а):Нет.
Создай любой проект для VET6, посмотри какой там используется стартап и подключи к своему старому проекту.
loreal1970
Уже пробовал. И свой создавал и из ST-шных примеров подсовывал. Собственно он с библиотекой идет и при создании проекта туда подсовывается.
Эти файлы совершенно разные. Контроллер с ST-м файлом вообще не стартует.
dosikus
Сообщение dosikus »
103VE это HD линейка и стартап не абыкакой а startup_stm32f10x_hd.s
Он( и все остальное необходимое) лежит в паках Keil
;******************** (C) COPYRIGHT 2011 STMicroelectronics ********************
;* File Name          : startup_stm32f10x_hd.s
;* Author             : MCD Application Team
;* Version            : V3.5.0
;* Date               : 11-March-2011
;* Description        : STM32F10x High Density Devices vector table for MDK-ARM
;*                      toolchain.
;*                      This module performs:
;*                      - Set the initial SP
;*                      - Set the initial PC == Reset_Handler
;*                      - Set the vector table entries with the exceptions ISR address
;*                      - Configure the clock system and also configure the external
;*                        SRAM mounted on STM3210E-EVAL board to be used as data
;*                        memory (optional, to be enabled by user)
;*                      - Branches to __main in the C library (which eventually
;*                        calls main()).
;*                      After Reset the CortexM3 processor is in Thread mode,
;*                      priority is Privileged, and the Stack is set to Main.
;* <<< Use Configuration Wizard in Context Menu >>>
; THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
; WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
; AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
; INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
; CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
; INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
; Tailor this value to your application needs
; <h> Stack Configuration
;   <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
; </h>
Stack_Size      EQU     0x00000400
Stack_Mem       SPACE   Stack_Size
__initial_sp
; <h> Heap Configuration
;   <o>  Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
; </h>
Heap_Size       EQU     0x00000200
__heap_base
Heap_Mem        SPACE   Heap_Size
__heap_limit
                PRESERVE8
                THUMB
; Vector Table Mapped to Address 0 at Reset
                AREA    RESET, DATA, READONLY
                EXPORT  __Vectors
                EXPORT  __Vectors_End
                EXPORT  __Vectors_Size
__Vectors       DCD     __initial_sp               ; Top of Stack
                DCD     Reset_Handler              ; Reset Handler
                DCD     NMI_Handler                ; NMI Handler
                DCD     HardFault_Handler          ; Hard Fault Handler
                DCD     MemManage_Handler          ; MPU Fault Handler
                DCD     BusFault_Handler           ; Bus Fault Handler
                DCD     UsageFault_Handler         ; Usage Fault Handler
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
                DCD     SVC_Handler                ; SVCall Handler
                DCD     DebugMon_Handler           ; Debug Monitor Handler
                DCD     0                          ; Reserved
                DCD     PendSV_Handler             ; PendSV Handler
                DCD     SysTick_Handler            ; SysTick Handler
                ; External Interrupts
                DCD     WWDG_IRQHandler            ; Window Watchdog
                DCD     PVD_IRQHandler             ; PVD through EXTI Line detect
                DCD     TAMPER_IRQHandler          ; Tamper
                DCD     RTC_IRQHandler             ; RTC
                DCD     FLASH_IRQHandler           ; Flash
                DCD     RCC_IRQHandler             ; RCC
                DCD     EXTI0_IRQHandler           ; EXTI Line 0
                DCD     EXTI1_IRQHandler           ; EXTI Line 1
                DCD     EXTI2_IRQHandler           ; EXTI Line 2
                DCD     EXTI3_IRQHandler           ; EXTI Line 3
                DCD     EXTI4_IRQHandler           ; EXTI Line 4
                DCD     DMA1_Channel1_IRQHandler   ; DMA1 Channel 1
                DCD     DMA1_Channel2_IRQHandler   ; DMA1 Channel 2
                DCD     DMA1_Channel3_IRQHandler   ; DMA1 Channel 3
                DCD     DMA1_Channel4_IRQHandler   ; DMA1 Channel 4
                DCD     DMA1_Channel5_IRQHandler   ; DMA1 Channel 5
                DCD     DMA1_Channel6_IRQHandler   ; DMA1 Channel 6
                DCD     DMA1_Channel7_IRQHandler   ; DMA1 Channel 7
                DCD     ADC1_2_IRQHandler          ; ADC1 & ADC2
                DCD     USB_HP_CAN1_TX_IRQHandler  ; USB High Priority or CAN1 TX
                DCD     USB_LP_CAN1_RX0_IRQHandler ; USB Low  Priority or CAN1 RX0
                DCD     CAN1_RX1_IRQHandler        ; CAN1 RX1
                DCD     CAN1_SCE_IRQHandler        ; CAN1 SCE
                DCD     EXTI9_5_IRQHandler         ; EXTI Line 9..5
                DCD     TIM1_BRK_IRQHandler        ; TIM1 Break
                DCD     TIM1_UP_IRQHandler         ; TIM1 Update
                DCD     TIM1_TRG_COM_IRQHandler    ; TIM1 Trigger and Commutation
                DCD     TIM1_CC_IRQHandler         ; TIM1 Capture Compare
                DCD     TIM2_IRQHandler            ; TIM2
                DCD     TIM3_IRQHandler            ; TIM3
                DCD     TIM4_IRQHandler            ; TIM4
                DCD     I2C1_EV_IRQHandler         ; I2C1 Event
                DCD     I2C1_ER_IRQHandler         ; I2C1 Error
                DCD     I2C2_EV_IRQHandler         ; I2C2 Event
                DCD     I2C2_ER_IRQHandler         ; I2C2 Error
                DCD     SPI1_IRQHandler            ; SPI1
                DCD     SPI2_IRQHandler            ; SPI2
                DCD     USART1_IRQHandler          ; USART1
                DCD     USART2_IRQHandler          ; USART2
                DCD     USART3_IRQHandler          ; USART3
                DCD     EXTI15_10_IRQHandler       ; EXTI Line 15..10
                DCD     RTCAlarm_IRQHandler        ; RTC Alarm through EXTI Line
                DCD     USBWakeUp_IRQHandler       ; USB Wakeup from suspend
                DCD     TIM8_BRK_IRQHandler        ; TIM8 Break
                DCD     TIM8_UP_IRQHandler         ; TIM8 Update
                DCD     TIM8_TRG_COM_IRQHandler    ; TIM8 Trigger and Commutation
                DCD     TIM8_CC_IRQHandler         ; TIM8 Capture Compare
                DCD     ADC3_IRQHandler            ; ADC3
                DCD     FSMC_IRQHandler            ; FSMC
                DCD     SDIO_IRQHandler            ; SDIO
                DCD     TIM5_IRQHandler            ; TIM5
                DCD     SPI3_IRQHandler            ; SPI3
                DCD     UART4_IRQHandler           ; UART4
                DCD     UART5_IRQHandler           ; UART5
                DCD     TIM6_IRQHandler            ; TIM6
                DCD     TIM7_IRQHandler            ; TIM7
                DCD     DMA2_Channel1_IRQHandler   ; DMA2 Channel1
                DCD     DMA2_Channel2_IRQHandler   ; DMA2 Channel2
                DCD     DMA2_Channel3_IRQHandler   ; DMA2 Channel3
                DCD     DMA2_Channel4_5_IRQHandler ; DMA2 Channel4 & Channel5
__Vectors_End
__Vectors_Size  EQU  __Vectors_End - __Vectors
; Reset handler
Reset_Handler   PROC
                EXPORT  Reset_Handler             [WEAK]
                IMPORT  __main
                IMPORT  SystemInit
                LDR     R0, =SystemInit
                BLX     R0
                LDR     R0, =__main
                BX      R0
                ENDP
; Dummy Exception Handlers (infinite loops which can be modified)
NMI_Handler     PROC
                EXPORT  NMI_Handler                [WEAK]
                B       .
                ENDP
HardFault_Handler\
                PROC
                EXPORT  HardFault_Handler          [WEAK]
                B       .
                ENDP
MemManage_Handler\
                PROC
                EXPORT  MemManage_Handler          [WEAK]
                B       .
                ENDP
BusFault_Handler\
                PROC
                EXPORT  BusFault_Handler           [WEAK]
                B       .
                ENDP
UsageFault_Handler\
                PROC
                EXPORT  UsageFault_Handler         [WEAK]
                B       .
                ENDP
SVC_Handler     PROC
                EXPORT  SVC_Handler                [WEAK]
                B       .
                ENDP
DebugMon_Handler\
                PROC
                EXPORT  DebugMon_Handler           [WEAK]
                B       .
                ENDP
PendSV_Handler  PROC
                EXPORT  PendSV_Handler             [WEAK]
                B       .
                ENDP
SysTick_Handler PROC
                EXPORT  SysTick_Handler            [WEAK]
                B       .
                ENDP
Default_Handler PROC
                EXPORT  WWDG_IRQHandler            [WEAK]
                EXPORT  PVD_IRQHandler             [WEAK]
                EXPORT  TAMPER_IRQHandler          [WEAK]
                EXPORT  RTC_IRQHandler             [WEAK]
                EXPORT  FLASH_IRQHandler           [WEAK]
                EXPORT  RCC_IRQHandler             [WEAK]
                EXPORT  EXTI0_IRQHandler           [WEAK]
                EXPORT  EXTI1_IRQHandler           [WEAK]
                EXPORT  EXTI2_IRQHandler           [WEAK]
                EXPORT  EXTI3_IRQHandler           [WEAK]
                EXPORT  EXTI4_IRQHandler           [WEAK]
                EXPORT  DMA1_Channel1_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel2_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel3_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel4_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel5_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel6_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel7_IRQHandler   [WEAK]
                EXPORT  ADC1_2_IRQHandler          [WEAK]
                EXPORT  USB_HP_CAN1_TX_IRQHandler  [WEAK]
                EXPORT  USB_LP_CAN1_RX0_IRQHandler [WEAK]
                EXPORT  CAN1_RX1_IRQHandler        [WEAK]
                EXPORT  CAN1_SCE_IRQHandler        [WEAK]
                EXPORT  EXTI9_5_IRQHandler         [WEAK]
                EXPORT  TIM1_BRK_IRQHandler        [WEAK]
                EXPORT  TIM1_UP_IRQHandler         [WEAK]
                EXPORT  TIM1_TRG_COM_IRQHandler    [WEAK]
                EXPORT  TIM1_CC_IRQHandler         [WEAK]
                EXPORT  TIM2_IRQHandler            [WEAK]
                EXPORT  TIM3_IRQHandler            [WEAK]
                EXPORT  TIM4_IRQHandler            [WEAK]
                EXPORT  I2C1_EV_IRQHandler         [WEAK]
                EXPORT  I2C1_ER_IRQHandler         [WEAK]
                EXPORT  I2C2_EV_IRQHandler         [WEAK]
                EXPORT  I2C2_ER_IRQHandler         [WEAK]
                EXPORT  SPI1_IRQHandler            [WEAK]
                EXPORT  SPI2_IRQHandler            [WEAK]
                EXPORT  USART1_IRQHandler          [WEAK]
                EXPORT  USART2_IRQHandler          [WEAK]
                EXPORT  USART3_IRQHandler          [WEAK]
                EXPORT  EXTI15_10_IRQHandler       [WEAK]
                EXPORT  RTCAlarm_IRQHandler        [WEAK]
                EXPORT  USBWakeUp_IRQHandler       [WEAK]
                EXPORT  TIM8_BRK_IRQHandler        [WEAK]
                EXPORT  TIM8_UP_IRQHandler         [WEAK]
                EXPORT  TIM8_TRG_COM_IRQHandler    [WEAK]
                EXPORT  TIM8_CC_IRQHandler         [WEAK]
                EXPORT  ADC3_IRQHandler            [WEAK]
                EXPORT  FSMC_IRQHandler            [WEAK]
                EXPORT  SDIO_IRQHandler            [WEAK]
                EXPORT  TIM5_IRQHandler            [WEAK]
                EXPORT  SPI3_IRQHandler            [WEAK]
                EXPORT  UART4_IRQHandler           [WEAK]
                EXPORT  UART5_IRQHandler           [WEAK]
                EXPORT  TIM6_IRQHandler            [WEAK]
                EXPORT  TIM7_IRQHandler            [WEAK]
                EXPORT  DMA2_Channel1_IRQHandler   [WEAK]
                EXPORT  DMA2_Channel2_IRQHandler   [WEAK]
                EXPORT  DMA2_Channel3_IRQHandler   [WEAK]
                EXPORT  DMA2_Channel4_5_IRQHandler [WEAK]
WWDG_IRQHandler
PVD_IRQHandler
TAMPER_IRQHandler
RTC_IRQHandler
FLASH_IRQHandler
RCC_IRQHandler
EXTI0_IRQHandler
EXTI1_IRQHandler
EXTI2_IRQHandler
EXTI3_IRQHandler
EXTI4_IRQHandler
ADC1_2_IRQHandler
CAN1_RX1_IRQHandler
CAN1_SCE_IRQHandler
EXTI9_5_IRQHandler
TIM1_BRK_IRQHandler
TIM1_UP_IRQHandler
TIM1_CC_IRQHandler
TIM2_IRQHandler
TIM3_IRQHandler
TIM4_IRQHandler
I2C1_EV_IRQHandler
I2C1_ER_IRQHandler
I2C2_EV_IRQHandler
I2C2_ER_IRQHandler
SPI1_IRQHandler
SPI2_IRQHandler
USART1_IRQHandler
USART2_IRQHandler
USART3_IRQHandler
RTCAlarm_IRQHandler
TIM8_BRK_IRQHandler
TIM8_UP_IRQHandler
TIM8_CC_IRQHandler
ADC3_IRQHandler
FSMC_IRQHandler
SDIO_IRQHandler
TIM5_IRQHandler
SPI3_IRQHandler
UART4_IRQHandler
UART5_IRQHandler
TIM6_IRQHandler
TIM7_IRQHandler
                B       .
                ENDP
                ALIGN
; User Stack and Heap initialization
                 IF      :DEF:__MICROLIB
                 EXPORT  __initial_sp
                 EXPORT  __heap_base
                 EXPORT  __heap_limit
                 ELSE
                 LDR     R0, =  Heap_Mem
                 LDR     R1, =(Stack_Mem + Stack_Size)
                 LDR     R2, = (Heap_Mem +  Heap_Size)
                 LDR     R3, = Stack_Mem
                 BX      LR
                 ALIGN
                 ENDIF
                 END
;******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE*****
loreal1970
Вот этот файл я и подсовывал. Вернее его содержимое.
На нем процессор не стартует. Пока не знаю почему.
Может это связано с UCOS.?
В недрах файла os_cpu_a.asm нашел такие строки. Может это?
Путаница какая то.
;                                                EQUATES
NVIC_INT_CTRL   EQU     0xE000ED04                              ; Interrupt control state register
;NVIC_SYSPRI2    EQU     0xE000ED20                              ; System priority register (2)
NVIC_SYSPRI2    EQU     0xE000ED22                              ; System priority register (yan).
;NVIC_PENDSV_PRI EQU     0x00   ; 0xFF00                         ; PendSV priority value (highest)
NVIC_PENDSV_PRI EQU           0xFF                              ; PendSV priority value (LOWEST yan).
NVIC_PENDSVSET  EQU     0x10000000                              ; Value to trigger PendSV exception
;                                      CODE GENERATION DIRECTIVES
    AREA |.text|, CODE, READONLY, ALIGN=2
    THUMB
    REQUIRE8
    PRESERVE8
dosikus
Сообщение dosikus »
Вы сперва без оси потренируйтесь. Сдается мне вы кривые китай_примеры терзаете?
loreal1970
Да совершенно верно - китайские. Которые с платой шли.
Без оси тренировался , все гуд.
Причем по ST-шному алгоритму. О нем тут не раз писали.
Ну а по существу. Те добавления, которые я внес, должны были помочь. Но прерывание возникает, а попадает не известно куда.
dosikus
Сообщение dosikus »
Тот пример выложите в архиве...
loreal1970
Хочу добавить вложение. Не добавляется???
dosikus
Сообщение dosikus »
На любой файлообменник.
loreal1970
loreal1970
В общем РЕШЕНО это безобразие путем создания проекта с нуля ручками, а не ковыряния демо проектов. Все заработало.
Хотя осталось чувство, что не разобрался я с тем файлом. Почему не видит прерывания после добавления недостающих строк, так и не знаю.
dosikus
Сообщение dosikus »
Там в проекте даже CMSIS древнее. Так что лучше и проще создать новый проект с обновленными файлами...
Вернуться в «ARM»
