Уменьшение веса кода с 4kb до 1kb
Сообщение sTRog »
Прошу помочь урезать код, чтобы он влез в attiny13a.
#define F_CPU 1200000UL
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include <stdlib.h>
#define T_POLL 136
#define TRANSON   _BV(2)
#define TRANSOFF   _BV(4)
#define LED_R   _BV(3)
#define BTN      _BV(1)
char mod = 0; // vatiable for 0 to 1
volatile uint8_t amount; //vatiable for 0 to 12 need for 12 reps ot one side and back
volatile uint8_t i; //vatiable for 0 to 10 need fo timer
volatile uint16_t Sec; //variable for count the number of second
volatile uint16_t SecF=0;// variable for make 5 second delay working mode, and than off.
int rantime; // variable for make random number.
ISR(TIM0_OVF_vect){ //timer
   TCNT0 = T_POLL;
   i++;
   if (i>=10) //period 1s
      Sec++;
     i=0;
static void pulcesDREAMon(void){
	for ( amount = 0; amount < 12; amount++ ) //this function make 11 times on/off ransistor of number 1
      PORTB |= TRANSON;
      _delay_ms(500);
      PORTB &= ~TRANSON;
	  _delay_ms(1000);
static void pulcesDREAMoff(void){
	for ( amount = 0; amount < 12; amount++ ) //this function make 11 times on/off ransistor of number 2
      PORTB |= TRANSOFF;
      _delay_ms(500);
      PORTB &= ~TRANSOFF;
	  _delay_ms(1000);
static void pulce_led(void){
    PORTB |= LED_R;
    _delay_ms(10);
    PORTB &= ~LED_R;
static void povtor_per(void){ //repeating a piece of text repeat
   	SecF=5; //this variable need for check how much time passed
	Sec = 0;
static void povtor_per2(void){ //repeating a piece of text repeat
   	SecF=3000; //this variable need for disable funtion which off the mode
	Sec = 0;
int main(void){
   PRR = (1<<PRADC); // shut down ADC
   TIMSK0 = (1<<TOIE0);  // timer0 overflow interrupt enable
   TCCR0B = (1<<CS02) | (1<<CS00); // prescaler 1/1024
   sei();
   DDRB = TRANSON | TRANSOFF | LED_R; //work for the exit
   rantime = 1800 + random() % 5400; //make random number between 30 min and 2 hours.
while (1){
  if (mod==0){
     if (Sec>=1800){
        pulcesDREAMon(); //on the need mode and give them to work 5 sek.
		povtor_per();
	 if (Sec>=SecF){ //check how much time passed
        pulcesDREAMoff();
		povtor_per2();
  if (mod==1){
     if (Sec>=rantime){
		povtor_per();
	 if (Sec>=SecF){
        pulcesDREAMoff(); //check how much time passed
		povtor_per2();
  if (PINB & BTN){ //just a function button processing
     cli();
     Sec = 0;
     if (mod==0){
        mod = 1;
        pulce_led();
    } else {
       mod = 0;
       pulce_led();
       _delay_ms(100);
       pulce_led();
	   SecF=5400;
     _delay_ms(1000);
     sei();
СпойлерАдминам и пользователям, прошу извинения за дубликат темы. Сделано это по той причине, что в предыдущей теме оставлено уже множество сообщений и, возможно, это отпугивает тех, кто мог бы помочь. Ту тему, если это возможно, просьба отправить в архив.
Сообщение viiv »
Чем собираешь?
gcc-4.8.2 с опцией -Os твой код в 574 байт скомпилировал. +надо добавить startup + вектора + внешние функции (беглый просмотр, что это _delay_ms())
Как _delay_ms() у тебя реализован, я не знаю. А что возможности посмотреть карту памяти в твоей среде нет? Если есть - посмотри, что так жрет и решай как решить.
Сообщение sTRog »
Собираю в avr sudio 4. Как память отследить - гуглил, но чет не понял. Знаю только что выше 6 там в отчете пишется, но у меня не тянет такой софт.
Сообщение Аlex »
sTRog писал(а):Прошу помочь урезать код, чтобы он влез в attiny13a
Урезал :
int main(void){
В attiny13a точно влезет.
Сообщение viiv »
sTRog, вроде в AVR студии gcc и используется. Как там из среды запускать - не знаю, не ставил студию. Если там gcc - ищи в своей установке студии консольные приложения, с именами что-то типа avr-gcc*.exe, avr-objdump*.exe... Есть такие? Если есть, то любо сам можешь посмотреть их использование, либо сюда их название - может сможем пмочь.
Сообщение Mishany »
реализовать stdlib.h (random() % 5400) на свободном таймере (сабака)
либо так:
while (1){
unsigned int rnd++;
if(rnd>5400) rnd=0;
rantime = 1800 + rnd; // random() % 5400;
пол тиньки останется свободной....
Сообщение Z_h_e »
1. Включить оптимизацию для начала.
2. Использовать режим CTC таймера.
3. Использовать 8ми битные переменные, зачем считать 1800, когда можно до 18?
4. Оптимизировать алгоритм, использовать поменьше сравнений.
5. Не использовать volotile переменные без необходимости.
6. Взять МК с 32кБ флеша ;)
7. Понять что случайностей не бывает и все предопределено :) , особенно в ПСЕВДОслучайной последовательности и убедится что при старте МК rantime всегда инициализируется одним и тем же совершенно случайным числом.
8. Написать ТЗ и дать денежку тому кто сделает. Хотите сделаю? Но сначала ТЗ почитаю конечно (это если что в личку).
Добро всегда побеждает зло. Поэтому кто победил - тот и добрый.
Сообщение sTRog »
viiv писал(а):sTRog, вроде в AVR студии gcc и используется. Как там из среды запускать - не знаю, не ставил студию. Если там gcc - ищи в своей установке студии консольные приложения, с именами что-то типа avr-gcc*.exe, avr-objdump*.exe... Есть такие? Если есть, то любо сам можешь посмотреть их использование, либо сюда их название - может сможем пмочь.
По адрессу C:\avr\avr8-gnu-toolchain\bin есть .exe avr-gcc.exe но я не понял, как ее запускать, если тупо два раза кликнуть то на мгновений открывается консольное окно, а затем сразу же закрывается.
Mishany писал(а):реализовать stdlib.h (random() % 5400) на свободном таймере (сабака)
либо так:
Спасибо. А не подскажите, где можно почитать о функциях рандом на си для микроконтролеров? Читал о генерации псевдослучайных чисел на регистре сдвига, но так и не нашел примеров под attiny 13 или принципов написание, которые уже можно было бы подстроить
Сообщение Mishany »
Инкремент переменной в цикле с произвольным во времени обращением к ней и есть рандомное значение, да банальный шум на ацп....
Как часто нужно рандомное значение?
Сообщение sTRog »
Mishany писал(а):Инкремент переменной в цикле с произвольным во времени обращением к ней и есть рандомное значение, да банальный шум на ацп....
Максимальная частота запроса - раз в пол часа.
Сообщение Mishany »
Тема закрыта, вопрос решен.
Вернуться в «AVR»
