В IDE отваливаются библиотеки
REB
Сообщение REB »
Версия IDE - 1.6.6
библиотеки:
Adafruit_GFX
Adafruit-PCD8544-Nokia-5110-LCD-library-master
LCD5110_Basic
Пытаюсь положить в соовтествующую папку - ошибка в компиляции кода. Пытаюсь инсталлировать библиотеку зип архивом через меню - снова ошибка при компиляции кода. Даже если не обращаться к библиотеке по средствам кода, только подключить ее.
ПРимер ошибки:
In file included from C:\Users\REB\Documents\Arduino\PROBNI_SKETCH\PROBNI_SKETCH.ino\PROBNI_SKETCH.ino.ino:5:0:
D:\PROG\arduino-nightly\libraries\Adafruit/Adafruit_PCD8544.h:36:0: warning: "PCD8544_DISPLAYBLANK" redefined [enabled by default]
 #define PCD8544_DISPLAYBLANK 0x0
In file included from C:\Users\REB\Documents\Arduino\PROBNI_SKETCH\PROBNI_SKETCH.ino\PROBNI_SKETCH.ino.ino:1:0:
C:\Users\REB\Documents\Arduino\libraries\LCD5110_Basic/LCD5110_Basic.h:37:0: note: this is the location of the previous definition
 #define PCD8544_DISPLAYBLANK  0x00
D:\PROG\arduino-nightly\libraries\Adafruit/Adafruit_PCD8544.h:37:0: warning: "PCD8544_DISPLAYNORMAL" redefined [enabled by default]
 #define PCD8544_DISPLAYNORMAL 0x4
C:\Users\REB\Documents\Arduino\libraries\LCD5110_Basic/LCD5110_Basic.h:38:0: note: this is the location of the previous definition
 #define PCD8544_DISPLAYNORMAL  0x04
D:\PROG\arduino-nightly\libraries\Adafruit/Adafruit_PCD8544.h:38:0: warning: "PCD8544_DISPLAYALLON" redefined [enabled by default]
 #define PCD8544_DISPLAYALLON 0x1
C:\Users\REB\Documents\Arduino\libraries\LCD5110_Basic/LCD5110_Basic.h:39:0: note: this is the location of the previous definition
 #define PCD8544_DISPLAYALLON  0x01
D:\PROG\arduino-nightly\libraries\Adafruit/Adafruit_PCD8544.h:39:0: warning: "PCD8544_DISPLAYINVERTED" redefined [enabled by default]
 #define PCD8544_DISPLAYINVERTED 0x5
C:\Users\REB\Documents\Arduino\libraries\LCD5110_Basic/LCD5110_Basic.h:40:0: note: this is the location of the previous definition
 #define PCD8544_DISPLAYINVERTED  0x05
C:\Users\REB\Documents\Arduino\libraries\LCD5110_Basic\DefaultFonts.c:12:14: error: variable 'SmallFont' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
 fontdatatype SmallFont[] PROGMEM =
C:\Users\REB\Documents\Arduino\libraries\LCD5110_Basic\DefaultFonts.c:117:14: error: variable 'MediumNumbers' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
 fontdatatype MediumNumbers[] PROGMEM =
C:\Users\REB\Documents\Arduino\libraries\LCD5110_Basic\DefaultFonts.c:135:14: error: variable 'BigNumbers' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
 fontdatatype BigNumbers[] PROGMEM =
exit status 1
Ошибка компиляции.
Установил на смартфон, получил конкретную ошибку без лишнего мата:
(149.88 КБ) 545 скачиваний
Вопрос, что за "файл свойств" у библиотеки и где его взять? Ну и как вообще бороться с этим глюком?
Существует миф, о том, что дырявые вечно суют свой нос не в свое дело, ввиду необоснованного ЧСВ. Не правда! Это не миф! )))
REB
Сообщение REB »
Прошу прощения за сообщение не по теме. Постил в ветке AVR (ибо Ардуино это avr) , но каким то боком оказалось в ARM
Вернуться в «ARM»
