Форум РадиоКот • Просмотр темы - Конвертация символов Ардуино.
Текущее время: Вс янв 11, 2026 22:30:25
Начать новую тему Ответить на тему  [ Сообщений: 49 ]    , , 3
 Заголовок сообщения: Re: Конвертация символов Ардуино.
СообщениеДобавлено: Чт май 24, 2018 23:43:37
СпойлерvideocardCLS:17: error: stray '#' in program
if((inByte == 'c'||inByte == 'C') && len == 0 && len_2 == 1){
videocardCLS:20: error: stray '#' in program
if((inByte == 'l'||inByte == 'L') && len == 1 && len_2 == 2){
videocardCLS:23: error: stray '#' in program
if((inByte == 's'||inByte == 'S') && len == 2 && len_2 == 3){
C:\Users\Pavel\Desktop\videocardCLS\videocardCLS.ino: In function 'void loop()':
videocardCLS:17: error: lvalue required as unary '&' operand
videocardCLS:17: error: expected ')' before ';' token
videocardCLS:17: error: 'c' was not declared in this scope
videocardCLS:17: error: expected primary-expression before '||' token
videocardCLS:17: error: 'C' was not declared in this scope
videocardCLS:17: error: expected primary-expression before ')' token
videocardCLS:17: error: expected ';' before ')' token
videocardCLS:20: error: lvalue required as unary '&' operand
videocardCLS:20: error: expected ')' before ';' token
videocardCLS:20: error: 'l' was not declared in this scope
videocardCLS:20: error: expected primary-expression before '||' token
videocardCLS:20: error: 'L' was not declared in this scope
videocardCLS:20: error: expected primary-expression before ')' token
videocardCLS:20: error: expected ';' before ')' token
videocardCLS:23: error: lvalue required as unary '&' operand
videocardCLS:23: error: expected ')' before ';' token
videocardCLS:23: error: 's' was not declared in this scope
videocardCLS:23: error: expected primary-expression before '||' token
videocardCLS:23: error: 'S' was not declared in this scope
videocardCLS:23: error: expected primary-expression before ')' token
videocardCLS:23: error: expected ';' before ')' token
exit status 1
Добавлено after 2 minutes 6 seconds:
Димон спасибо Вам за помощь еще раз!!! При попытке залить ругается вот этим. Может у меня компилятор кривой???
СообщениеДобавлено: Пт май 25, 2018 07:38:01
Карма: 20
Рейтинг сообщений: 145
Да это редактор что-то не то выдал
Код:
char len; //счетчик числа символов в команде
char len_2;
void setup() {
Serial1.begin(9600);
VGA.begin(320, 240, VGA_COLOUR);
VGA.setInk(16);
void loop() {
if(Serial1.available()) {
int inByte = Serial1.read();
len_2++;
if((inByte == 'c' ||inByte == 'C') && len == 0 && len_2 == 1){
len++;
if((inByte == 'l' ||inByte == 'L') && len == 1 && len_2 == 2){
len++;
if((inByte == 's' ||inByte == 'S') && len == 2 && len_2 == 3){
len++;
if(inByte == 13 && len == 3 && len_2 == 4){ // клавиша Enter
VGA.clear(); VGA.moveCursor(0,0);
len=0;len_2=0;
if(inByte == 13 || inByte == 27){ // клавиша Enter или клавиша Esc сброс счетчика числа символов в команде
len= 0; len_2=0;
if(inByte==27){ // клавиша ESC
VGA.clear();
VGA.moveCursor(0, 0);
VGA.write(inByte); }
СообщениеДобавлено: Пт май 25, 2018 08:52:47
Карма: 90
Рейтинг сообщений: 1432
Кошмар... И это только для одной команды.
А если их будет 20 ? Простыню на 100500 строк городить ? :facepalm:
СообщениеДобавлено: Пт май 25, 2018 09:21:56
Карма: 98
Рейтинг сообщений: 2135
я так и не понял, о чем тут идет спор...
если достаточно ресурсов (а я догадываюсь, их достаточно), то что может быть проще ранее рекомендованного strcmp?
Код:
if(strcmp(command, "CLR") == 0){
   // обработка команды CLR
} else if(strcmp(command, "PRINT") == 0{
   // обработка команды PRINT
} else if .......
для avr-gcc рекомендую strcmp_P - меньше ресурсов flash тратится.
Добавлено after 3 minutes 12 seconds:
можно, конечно, и красивее сделать - перебор структур из массива... но это на любителя, так тоже просто и удобно.
СообщениеДобавлено: Пт май 25, 2018 09:27:54
Карма: 90
Массив структур, в виде строки-команды и указателя на функцию-обработчик, как выше уже сказали - самое простое и красивое решение.
СообщениеДобавлено: Пт май 25, 2018 09:37:04
Рейтинг сообщений: 4
Да весь этот механизм в интерпретаторе бейсика уже есть и если проект открыт, то должно быть внятное описание как добавлять свои операторы.
Только от ТС так и не узнали, что это за проект, на чем он написан, чем компилить.
СообщениеДобавлено: Пт май 25, 2018 09:41:33
Карма: 98
ну я об этом и написал в дополнении... хотя не факт, что этот вариант будет компактнее и быстрее. я сталкивался с большим геморроем, когда реализовывал этот подход при помощи WinAVR, который данные во flash поддерживает не наивно для Си, а только путем работы с функциями чтения... такое не стану советовать.
avr-gcc с версии, кажется, 4 уже поддерживает пространство памяти __flash, что позволяет реализовать описанный подход на самом деле элегантно.
СообщениеДобавлено: Пт май 25, 2018 09:57:50
Карма: 96
Рейтинг сообщений: 1500
Мое видение ситуёвины...
:roll:
Человек хочет организовать внутреннюю шину данных для обмена между самостоятельными блоками единого устройства.
Это городушка вроде северна/южна моста в ПК (ибо устройство по сути и есть самодельный эквивалент ПК).
Ранее в пределах одного модуля (а за основу взят АРМ из группы ардуиновых) у него задачка решалась.
Однако, поскольку использованы библиотеки-копипасты, а не самостоятельная разработка быстродействие результирующего устройства автора не устроило и он разделил его на самостоятельные функциональные блоки.
А воть тут-то и вылезло... проблемо место...
Ему бы не RS232 с асинхронным обменом делать, а позаботится хотя-бы об аппаратном варианте синхронизации обмена "запрос-ответ" да шину данных по-другому организовать. Ан нет - уперся в тот АППАРАТНЫЙ serial поскольку ИНЫХ ГОТОВЫХ БИБЛИОТЕК НЕТ.
Ежли уж говорить о отловле команд по асинхроннику...
Каждый модуль занят своей задачей. Отлов наличия каких-либо данных в буфере приемопередатчика производится в произвольное время (а сколько за тот промежуток времени туда нападало данных - это тоже вопрос). Ардуина готовность данных прерыванием (как в случае работы непосредственно с МК) не обозначает - гонит поток всего, что принимает через буфер (можно конечно и посложнее прожку соорудить - но то уже задача посильная ЗНАТОКУ, а не НАЧИНАЮЩЕМУ и выходит за рамки "стандартных"средств IDE). Посему ставится периодический контроль содержимого того буфера (что жреть время и ресурс). Сразу всплывает вопрос о обрамлении данных синхросимволами, дабы отличить случайно совпавшую комбинацию данных от команды. Да и ответ "соседнему" блоку о том, что данные обработаны, а не потеряны...
Вобщем КАША...
СообщениеДобавлено: Пт май 25, 2018 11:33:09
Всем спасибо за помощь. Связать платы так и не получилось как следует. Пока ограничился постановкой команд на не используемый ряд верхних клавиш (F1-F12). Из плюсов - уяснил для себя много нового.
Не в курсе сколько будет стоить подобная работа по "связке плат", если заказать это?
