000000: PnP Event: Device Connected (UP), 2019-10-01 15:43:58,4981010 (1. Device: My device (pid.codes Test PID))
The USB device has just been connected to the system.
000001: Get Descriptor Request (DOWN), 2019-10-01 15:43:58,4981106 +0,0000096 (1. Device: My device (pid.codes Test PID))
Descriptor Type: Device
Descriptor Index: 0x0
Transfer Buffer Size: 0x12 bytes
000002: Control Transfer (UP), 2019-10-01 15:43:58,4982936 +0,0001830. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
Pipe Handle: Control Pipe
12 01 00 02 00 00 00 08 09 12 01 00 00 02 01 02 ................
03 01 ..
Setup Packet
000003: Get Descriptor Request (DOWN), 2019-10-01 15:43:58,4983099 +0,0000163 (1. Device: My device (pid.codes Test PID))
Descriptor Type: Configuration
Transfer Buffer Size: 0x9 bytes
000004: Control Transfer (UP), 2019-10-01 15:43:58,4985354 +0,0002255. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
09 02 29 00 01 01 00 E0 32 ..)....а2
Setup Packet
000005: Get Descriptor Request (DOWN), 2019-10-01 15:43:58,4985449 +0,0000095 (1. Device: My device (pid.codes Test PID))
Transfer Buffer Size: 0x29 bytes
000006: Control Transfer (UP), 2019-10-01 15:43:58,4987822 +0,0002373. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
09 02 29 00 01 01 00 E0 32 09 04 00 00 02 03 00 ..)....а2.......
00 00 09 21 11 01 00 01 22 26 00 07 05 81 03 02 ...!...."&...Ѓ..
00 05 07 05 01 03 02 00 05 .........
Setup Packet
000007: Select Configuration (DOWN), 2019-10-01 15:43:58,4987994 +0,0000172 (1. Device: My device (pid.codes Test PID))
Configuration Index: 1
000008: Select Configuration (UP), 2019-10-01 15:43:58,4990083 +0,0000010. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
Configuration Handle: 0x10989620
000009: Class-Specific Request (DOWN), 2019-10-01 15:43:58,4990166 +0,0000083 (1. Device: My device (pid.codes Test PID))
Destination: Interface, Index 0
Reserved Bits: 34
Request: 0xa
Value: 0x0
Send 0x0 bytes to the device
000010: Control Transfer (UP), 2019-10-01 15:43:58,4991632 +0,0001466. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
Setup Packet
000011: Get Descriptor Request (DOWN), 2019-10-01 15:43:58,4991865 +0,0000233 (1. Device: My device (pid.codes Test PID))
Descriptor Type: HID Report Descriptor
Transfer Buffer Size: 0x66 bytes
000012: Control Transfer (UP), 2019-10-01 15:43:58,4994164 +0,0002299. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
05 0C 09 01 A1 01 85 01 09 01 15 00 26 FF 00 75 ....Ў.….....&я.u
08 95 01 B1 82 85 01 09 01 91 82 85 02 09 02 75 .•.±‚…...‘‚…...u
08 95 01 81 82 C0 .•.Ѓ‚А
Setup Packet
000013: PnP Event: Query ID (UP), 2019-10-01 15:43:58,4998351 +0,0004187 (1. Device: My device (pid.codes Test PID))
Device ID: USB\VID_1209&PID_0001
000014: PnP Event: Query ID (UP), 2019-10-01 15:43:58,4999088 +0,0000737 (1. Device: My device (pid.codes Test PID))
Hardware IDs: USB\VID_1209&PID_0001&REV_0200, USB\VID_1209&PID_0001
000017: Get Descriptor Request (DOWN), 2019-10-01 15:43:58,8163532 +0,3160812 (1. Device: My device (pid.codes Test PID))
Descriptor Type: String
Descriptor Index: 0x2
Transfer Buffer Size: 0x20a bytes
LanguageId: 0x409
000018: Control Transfer (UP), 2019-10-01 15:43:58,8165216 +0,0001684. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
14 03 4D 00 79 00 20 00 64 00 65 00 76 00 69 00 ..M.y. .d.e.v.i.
63 00 65 00 c.e.
Setup Packet
000019: Get Descriptor Request (DOWN), 2019-10-01 15:43:58,8168660 +0,0003444 (1. Device: My device (pid.codes Test PID))
LanguageId: 0x409
000020: Control Transfer (UP), 2019-10-01 15:43:58,8170165 +0,0001505. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
63 00 65 00 c.e.
Setup Packet
000021: Get Descriptor Request (DOWN), 2019-10-01 15:43:59,8245625 +1,0075460 (1. Device: My device (pid.codes Test PID))
Descriptor Index: 0x3
Transfer Buffer Size: 0x402 bytes
LanguageId: 0x409
000022: Control Transfer (UP), 2019-10-01 15:43:59,8247647 +0,0002022. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
0C 03 31 00 32 00 33 00 34 00 35 00 ..1.2.3.4.5.
Setup Packet
000023: Get Descriptor Request (DOWN), 2019-10-01 15:43:59,8247822 +0,0000175 (1. Device: My device (pid.codes Test PID))
Descriptor Index: 0x1
LanguageId: 0x409
000024: Control Transfer (UP), 2019-10-01 15:43:59,8250076 +0,0002254. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
0C 03 49 00 74 00 73 00 20 00 49 00 ..I.t.s. .I.
Setup Packet
000025: Get Descriptor Request (DOWN), 2019-10-01 15:43:59,8250670 +0,0000594 (1. Device: My device (pid.codes Test PID))
LanguageId: 0x409
000026: Control Transfer (UP), 2019-10-01 15:43:59,8252570 +0,0001900. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
63 00 65 00 c.e.
Setup Packet
000027: Get Descriptor Request (DOWN), 2019-10-01 15:44:00,3206128 +0,4953558 (1. Device: My device (pid.codes Test PID))
LanguageId: 0x409
000028: Control Transfer (UP), 2019-10-01 15:44:00,3207602 +0,0001474. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
63 00 65 00 c.e.
Setup Packet
000029: Get Descriptor Request (DOWN), 2019-10-01 15:44:00,3210908 +0,0003306 (1. Device: My device (pid.codes Test PID))
LanguageId: 0x409
000030: Control Transfer (UP), 2019-10-01 15:44:00,3212461 +0,0001553. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
63 00 65 00 c.e.
Setup Packet
000031: Get Descriptor Request (DOWN), 2019-10-01 15:44:00,8221648 +0,5009187 (1. Device: My device (pid.codes Test PID))
LanguageId: 0x409
000032: Control Transfer (UP), 2019-10-01 15:44:00,8223657 +0,0002009. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
Setup Packet
000033: Get Descriptor Request (DOWN), 2019-10-01 15:44:00,8223753 +0,0000096 (1. Device: My device (pid.codes Test PID))
LanguageId: 0x409
000034: Control Transfer (UP), 2019-10-01 15:44:00,8224930 +0,0001177. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
Setup Packet
000035: Get Descriptor Request (DOWN), 2019-10-01 15:44:00,8225006 +0,0000076 (1. Device: My device (pid.codes Test PID))
LanguageId: 0x409
000036: Control Transfer (UP), 2019-10-01 15:44:00,8226167 +0,0001161. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
63 00 65 00 c.e.
Setup Packet
000037: Get Descriptor Request (DOWN), 2019-10-01 15:44:01,3152936 +0,4926769 (1. Device: My device (pid.codes Test PID))
LanguageId: 0x409
000038: Control Transfer (UP), 2019-10-01 15:44:01,3154996 +0,0002060. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
Setup Packet
000039: Get Descriptor Request (DOWN), 2019-10-01 15:44:01,3155251 +0,0000255 (1. Device: My device (pid.codes Test PID))
LanguageId: 0x409
000040: Control Transfer (UP), 2019-10-01 15:44:01,3157470 +0,0002219. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
Setup Packet
000041: Get Descriptor Request (DOWN), 2019-10-01 15:44:01,3157630 +0,0000160 (1. Device: My device (pid.codes Test PID))
LanguageId: 0x409
000042: Control Transfer (UP), 2019-10-01 15:44:01,3159887 +0,0002257. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
63 00 65 00 c.e.
Setup Packet
000043: Get Descriptor Request (DOWN), 2019-10-01 15:44:02,3415104 +1,0255217 (1. Device: My device (pid.codes Test PID))
LanguageId: 0x409
000044: Control Transfer (UP), 2019-10-01 15:44:02,3417323 +0,0002219. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
63 00 65 00 c.e.
Setup Packet
000045: Get Descriptor Request (DOWN), 2019-10-01 15:44:02,3430005 +0,0012682 (1. Device: My device (pid.codes Test PID))
LanguageId: 0x409
000046: Control Transfer (UP), 2019-10-01 15:44:02,3432435 +0,0002430. (1. Device: My device (pid.codes Test PID)) Status: 0x00000000
63 00 65 00 c.e.
Setup Packet
