#define F_CPU 8000000UL
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#define sw PIND
#define set 4
#define ok 3
#define up 2
#define down 1
#define setEvent (sw & (1<<set))
#define okEvent (sw & (1<<ok))
#define upEvent (sw & (1<<up))
#define downEvent (sw & (1<<down))
uint8_t sec, min, hr;
int day,dd,mm,yy;
char setFlag;
volatile uint8_t count,count1;
#define timeFormat 24
uint8_t d0,d1,d2,d3;
enum
hour=1,
minute,
void init_ports()
DDRB = 0xFF;
PORTB = 0x00;
DDRD=0x00;
PORTD=0xff;
void update_Time();
int bcd_to_char(int8_t num)
return ((num/16 * 10) + (num % 16));
int dec_to_bcd(int8_t num)
return ((num/10)<<4) + (num % 10);
void RTC_start()
TWCR=(1<<TWINT)|(1<<TWSTA)|(1<<TWEN);
while((TWCR&0x80)==0x00);
void device()
TWDR=0xD0; //RTC write (slave address)
TWCR=(1<<TWINT)|(1<<TWEN);
while(!(TWCR&(1<<TWINT)));
TWDR=0x00; // word address write
void RTC_stp()
TWCR=(1<<TWINT)|(1<<TWEN)|(1<<TWSTO); //stop communication
void RTC_read()
TWDR=0x00; //RTC write (word address)
TWCR=(1<<TWINT)|(1<<TWSTA)|(1<<TWEN); //start RTC communication again
while ((TWCR&0x80)==0x00);
TWDR=0xD1; // RTC command to read
void sec_init(int8_t d)
TWDR=d; //second init
void min_init(int8_t d)
TWDR=d; //minute init
void hr_init(int8_t d)
TWDR=d; //hour init
void day_init(int8_t d)
TWDR=d; //days init
void date_init(int8_t d)
TWDR=d; //date init
void month_init(int8_t d)
TWDR=d; //month init
void yr_init(int8_t d)
TWDR=d; //year init
int sec_rw()
TWCR|=(1<<TWINT)|(1<<TWEA); //RTC second read
while((TWCR & 0x80)==0x00);
return bcd_to_char(TWDR);
int min_rw()
TWCR|=(1<<TWINT); //RTC minute read
TWCR|=(1<<TWEA);
int hr_rw()
TWCR|=(1<<TWINT)|(1<<TWEA); //RTC hour read
int day_rd()
TWCR|=(1<<TWINT)|(1<<TWEA); //RTC day read
int date_rw()
TWCR|=(1<<TWINT)|(1<<TWEA); //RTC date read
int month_rw()
TWCR|=(1<<TWINT)|(1<<TWEA); //RTC month read
int yr_rw()
TWCR|=(1<<TWINT); //RTC year read
TWCR&=(~(1<<TWEA));
void setTime()
RTC_start();
device();
sec_init(0);
min_init(dec_to_bcd(min));
hr_init(dec_to_bcd(hr));
RTC_stp();
void RTC()
RTC_read();
sec=sec_rw();
min=min_rw();
hr=hr_rw();
day=day_rd();
dd=date_rw();
mm=month_rw();
yy=yr_rw();
RTC_stp();
char get_SETTINGS(uint8_t count)
while(1)
update_Time();
if(!upEvent)
count++;
if(setFlag == hour)
if(timeFormat == 24)
if(count > 23)
count=0;
hr=count;
else if(setFlag == minute)
if(count>59)
count=0;
min=count;
_delay_ms(100);
else if(!(downEvent))
count--;
if(setFlag == hour)
if(count > 23)
count=0;
hr=count;
if(count>59)
count=0;
min=count;
_delay_ms(100);
else if(!okEvent)
_delay_ms(500);
return count;
void setting_Time()
setFlag=1;
hr=get_SETTINGS(hr);
setFlag++;
min=get_SETTINGS(min);
setFlag=0;
void update_Time()
d0=min%10;//минуты
d1=min/10;//десятки минут
d2=hr%10;//часы
d3=hr/10;//десятки часов
const uint8_t dig[] = {
0b10000001, //0
0b11110011, //1
0b01001001, //2
0b01100001, //3
0b00110011, //4
0b00100101, //5
0b00000101, //6
0b11110001, //7
0b00000001, //8
0b00100001, //9
0b00000000,//пусто
0b00000001}; //точка
const uint8_t razr[] = {
0b11111110,
0b11111101,
0b11111011,
0b11110111};
uint8_t display[2];
volatile uint8_t i, a=0,k;
volatile uint16_t dot=0;
uint8_t dig1, dig2, dig3, dig4;
void init_timer0()
TIMSK =(1<<TOIE0); // timer0 enable
TCCR0 = (1<<CS01); // prescaler 1/1024
TCNT0=128;
sei();
void write_display(unsigned char *data)
unsigned char mask,i;
for(i = 0; i < 2; i++)
mask = 0x80;
for(char k = 0; k < 8; k++)
// Сравниваем каждый бит с единицей
if(data[i] & mask)
PORTB |= (1 << 0); // DATA 1
PORTB |= (1 << 1); // CLK 1
PORTB &= ~(1 <<1); // CLK 0
else
PORTB &= ~(1 << 0); // DATA 0
PORTB &= ~(1 << 1); // CLK 0
mask = mask >> 1; // Сдвигаем биты
// Защелкиваем регистр
PORTB |= (1 << 2);
PORTB &= ~(1 << 2);
ISR (TIMER0_OVF_vect)
(k == 4) ? k = 0: k++;
switch(k)
case 0:
dig4=dig[d3] ;
display[0] = razr[3];
display[1] = ~ dig4;
write_display(display);
break;
case 1:
dig3=dig[d2];
display[0] = razr[2];
display[1] = ~ dig3;
break;
case 2:
dig2=dig[d1];
display[0] = razr[1];
display[1] = ~dig2;
break;
case 3:
dig1=dig[d0];
display[0] =razr[0]; // в крайний левый символ
display[1] =~ dig1; // выводится цифра
break;
case 4:
dig3=dig[d2];
display[0] =razr[2]; // в крайний левый символ
display[1] =dig[10|dot]; // выводится цифра
break;
int main(void)
init_ports();
init_timer0();
while (1)
RTC();
update_Time();
if (sec&1) dot=0;
else
dot=dig[11];
if (!setEvent)
setting_Time();
setTime();
