Ардуино - запись звука
Сообщение olegue »
roman.com, насчет проверок не знаю
а вот запустить что-то стандартное ардуиновсокое и посмотерть что оно выдасть
типа вот этого
  SD card test
  This example shows how use the utility libraries on which the'
  SD library is based in order to get info about your SD card.
  Very useful for testing a card when you're not sure whether its working or not.
  The circuit:
    SD card attached to SPI bus as follows:
 ** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
 ** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
 ** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
 ** CS - depends on your SD card shield or module.
 		Pin 4 used here for consistency with other Arduino examples
  created  28 Mar 2011
  by Limor Fried
  modified 9 Apr 2012
  by Tom Igoe
// include the SD library:
#include <SPI.h>
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
// MKRZero SD: SDCARD_SS_PIN
const int chipSelect = 4;
void setup() {
  // Open serial communications and wait for port to open:
  Serial.begin(9600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("\nInitializing SD card...");
  // we'll use the initialization code from the utility libraries
  // since we're just testing if the card is working!
  if (!card.init(SPI_HALF_SPEED, chipSelect)) {
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card inserted?");
    Serial.println("* is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    while (1);
  } else {
    Serial.println("Wiring is correct and a card is present.");
  // print the type of card
  Serial.println();
  Serial.print("Card type:         ");
  switch (card.type()) {
    case SD_CARD_TYPE_SD1:
      Serial.println("SD1");
      break;
    case SD_CARD_TYPE_SD2:
      Serial.println("SD2");
      break;
    case SD_CARD_TYPE_SDHC:
      Serial.println("SDHC");
      break;
    default:
      Serial.println("Unknown");
  // Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
  if (!volume.init(card)) {
    Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
    while (1);
  Serial.print("Clusters:          ");
  Serial.println(volume.clusterCount());
  Serial.print("Blocks x Cluster:  ");
  Serial.println(volume.blocksPerCluster());
  Serial.print("Total Blocks:      ");
  Serial.println(volume.blocksPerCluster() * volume.clusterCount());
  Serial.println();
  // print the type and size of the first FAT-type volume
  uint32_t volumesize;
  Serial.print("Volume type is:    FAT");
  Serial.println(volume.fatType(), DEC);
  volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
  volumesize *= volume.clusterCount();       // we'll have a lot of clusters
  volumesize /= 2;                           // SD card blocks are always 512 bytes (2 blocks are 1KB)
  Serial.print("Volume size (Kb):  ");
  Serial.println(volumesize);
  Serial.print("Volume size (Mb):  ");
  volumesize /= 1024;
  Serial.print("Volume size (Gb):  ");
  Serial.println((float)volumesize / 1024.0);
  Serial.println("\nFiles found on the card (name, date and size in bytes): ");
  root.openRoot(volume);
  // list all files in the card with date and size
  root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
Сообщение Martian »
[uquote="Jack_A",url="/forum/viewtopic.php?p=4240177#p4240177"]У меня такое смутное убеждение, что написать для 8-биток что-то сложнее помигать диодами - да на высокоуровневом - это как[/uquote]Не обобщайте. С обычным Cи, который не дваждыплюсанутый, прекрасно всё работается. И в большинстве случаев, всё зависит от писателя.
Сообщение roman.com »
флешки капризные... бывает зависают)) поэтому я от них отказался...
да можно как угодно посмотреть... хоть через Ардуину... хоть напрямую подключить к AVR... и вывести данные на экран...
я подключил к AVR и прочитал все сектора...
(18.84 КБ) 58 скачиваний
затем стёр все сектора... записал туда все нули... 000000000000000...
после вставил в ПК...
ПК ответил "диск не отформатирован. Отформатировать ? Нажмите да"
нажал Да))
через две минуты... у меня опять рабочая флешка))
:tea:
есть ещё бесплатные программы по восстановлению данных с флешек... но то такое... на любителя)) на AVR получается круче))
Сообщение Martian »
Конечно. АВР-то у каждого есть, не то что комп. В утилитах-то всего-навсего могут тип контроллера учитывать, его внутренние всякие фишки-плюшки... нафиг не нужно, запишем нолики в авр, это круто... У Вас, roman.com, какое-то странное увлечение чашкой. Что-то не то пьёте...
Сообщение musor »
страны вы люди имея комп с тонами софта в интернете зачем гоношить приблуду на мк...
любую флеху можно проверить и переформатировать с проверкой сектороф по заводу софтом под ее продной к4онтролер
при этом не удивляйтесь если 16/32гБТ вдрук потом станет 8или даже 2гбт
прпосто обнарпужиф в секции неск битых ячек чисто короых болше резервной зоны контролер отсекает часть нанда с битыми ячейками уменшая обьем -зато оставшие будуть работать и держать даные надежно...
Добавлено after 2 minutes 27 seconds:
а ваши потуги с принудителной записью о или 1 в каждую ячейку самобман... каки попытка указать обьем болше физической адресации НАНД
допустим винда проведет форматирование без проверки сектороф =но такая флеха будет портить и тьерять даные -оно вам надо???
[uquote="Morroc",url="/forum/viewtopic.php?p=4240180#p4240180"]во маньяки в тему слетелись...[/uquote]
ты ещё маньяков не видел))
а как насчёт много ядерных AVR ? )) с синхронизацией до машинного такта... от одного кварцевого генератора... с распределёнными вычислениями... написано на ассемблере))
(94.47 КБ) 59 скачиваний
Martian писал(а):какое-то странное увлечение чашкой.
это чай)) просто крепкий чай))
musor писал(а):страны вы люди имея комп с тонами софта в интернете зачем гоношить приблуду на мк...
нормальные мы люди)) прост она ПК это делать не интересно))
а номер контроллера может читать и AVR...
на самом деле весь тот софт на компе и AVR... используют одни и те же команды... согласно одному и тому же даташиту))
olegue писал(а):насчет проверок не знаю
а как насчёт... шифрования ?
у тебя в ардуино есть функция шифрования флешки ?
8)
в наше трудное время... все секретные переговоры... записанные на наш самодельный диктофон... не должны попасть в руки к нашим врагам ! ))
:kill:
Сообщение olegue »
Вот между работой с eeProm и sd card есть разница как я понял. Она заключается в том ,что в еепром можно записать в любой байт по адресу и также считать, а в sd карта все делается блоками по 512байт, еще и буфер каой то есть.
Объясните простыми словами как пишутся и читаются данные на карту. То что постил roman.com для меня пока слишком сложно.
ты хорошо себе представляешь как записать EEPROM ?
// запись EEPROM:
EEAR = a; // пишем адрес ячейки куда хотим записать
EEDR = b; // пишем данные которые хотим записать (1 байт)
EECR |= 0b00000100; // пишем команду "разрешить запись EEPROM"
EECR |= 0b00000010; // пишем команду "запись EEPROM"
while(EECR & 0b00000010); // ждём окончание записи EEPROM
*Примечание:
буква "A" - это адрес.
буква "D" - это данные.
буква "C" - это команда.
Тоже самое для флешки))
// запись флешки:
tx3=0x58; SPI3(); // пишем команду "запись флешки"
tx3=(x>>24); SPI3(); // пишем адрес сектора куда хотим записать
tx3=(x>>16); SPI3(); // пишем адрес сектора куда хотим записать
tx3=(x>>8); SPI3(); // пишем адрес сектора куда хотим записать
tx3=x; SPI3(); // пишем адрес сектора куда хотим записать
for (a=0; a<512; a++) {
tx3=ADC; SPI3(); // пишем данные которые хотим записать (512 байт)
while ( x1 != 0xFF ) {
tx3=0xFF; SPI3(); x1=rx3; // ждём окончание записи флешки
всё))
и в чём разница между EEPROM и флешкой ? Только в том что в EEPROM пишем по 1 байту, а на флешку пишем блоками по 512 байт. Вот и вся разница))
Сообщение olegue »
и еще кругом пишут что есть какой -то буфер?
Добавлено after 15 minutes 7 seconds:
roman.com писал(а):у, а на флешку пишем блоками по 512 байт.
и этот блок нужно где-то накопить?
Сообщение Ivanoff-iv »
не обязательно, он может и во флешке копиться
нет никакого буфера)) мы сами его себе придумали...))
флешке не нужны никакие буферы... берешь флешку и пишешь сразу 512 байт без всяких буферов))
Добавлено after 20 minutes:
olegue писал(а):и этот блок нужно где-то накопить?
не нужно ничего нигде накапливать.
берёшь флешку и пишешь...
// запись флешки:
tx3=0; SPI3(); // пишем адрес сектора куда хотим записать
tx3=0; SPI3(); // пишем данные которые хотим записать - 512 байт и все нули
в сектор 0000 будут записаны все нули...
00000000000000000000000000000000000...
и т.д.
всего 512 байт и все нули
Сообщение olegue »
#include <Wire.h>                           // Подключаем библиотеку Wire
#include <TimeLib.h>                        // Подключаем библиотеку TimeLib
#include <DS1307RTC.h>                      // Подключаем библиотеку DS1307RTC
RTC.read(tm)
//tm.Hour;
//tm.Minute;
//tm.Second;
//tm.Day;
//tm.Month;
//tm.Year;
Ну вот прибавл часы , как теперь сделать что бы аудиофйлы получили время при записи на флэшку?
Добавлено after 4 minutes 20 seconds:
мне кажется что в этой процедуре (запись заголовка) нужно добавить время записи файлов
void writeWavHeader() { // write out original WAV header to file
  recByteSaved = 0;
  // rec.open("rec00000.wav", O_CREAT | O_TRUNC | O_RDWR);
  rec.open(NameRecord, O_CREAT | O_TRUNC | O_RDWR); /* Имя нового - записываемого файла на SD-карту. */
  rec.write("RIFF");
  byte1 = fileSize & 0xff;
  byte2 = (fileSize >> 8) & 0xff;
  byte3 = (fileSize >> 16) & 0xff;
  byte4 = (fileSize >> 24) & 0xff;
  rec.write(byte1);  rec.write(byte2);  rec.write(byte3);  rec.write(byte4);
  rec.write("WAVE");
  rec.write("fmt ");
  byte1 = waveChunk & 0xff;
  byte2 = (waveChunk >> 8) & 0xff;
  byte3 = (waveChunk >> 16) & 0xff;
  byte4 = (waveChunk >> 24) & 0xff;
  byte1 = waveType & 0xff;
  byte2 = (waveType >> 8) & 0xff;
  byte1 = numChannels & 0xff;
  byte2 = (numChannels >> 8) & 0xff;
  byte1 = sampleRate & 0xff;
  byte2 = (sampleRate >> 8) & 0xff;
  byte3 = (sampleRate >> 16) & 0xff;
  byte4 = (sampleRate >> 24) & 0xff;
  byte1 = bytesPerSec & 0xff;
  byte2 = (bytesPerSec >> 8) & 0xff;
  byte3 = (bytesPerSec >> 16) & 0xff;
  byte4 = (bytesPerSec >> 24) & 0xff;
  byte1 = blockAlign & 0xff;
  byte2 = (blockAlign >> 8) & 0xff;
  byte1 = bitsPerSample & 0xff;
  byte2 = (bitsPerSample >> 8) & 0xff;
  rec.write("data");
  byte1 = dataSize & 0xff;
  byte2 = (dataSize >> 8) & 0xff;
  byte3 = (dataSize >> 16) & 0xff;
  byte4 = (dataSize >> 24) & 0xff;
Добавлено after 23 minutes 19 seconds:
нагуглил что вот эту сточку надо дергать
rec.open(filename, O_CREAT | O_TRUNC | O_RDWR); /* Имя нового - записываемого файла на SD-карту. */
roman.com писал(а):флешке не нужны никакие буферы... берешь флешку и пишешь сразу 512 байт без всяких буферов))
Мне не доводилось писать на флешку, но, разве ей не нужно время, чтобы перенести данные из своего буфера в ПЗУ? можно ли в это время продолжать в неё писать? (захват то идёт непрерывно)
если есть файловая система, то как решается вопрос с фрагментацией файлов (особенно без буферов)?
Сообщение Morroc »
[uquote="olegue",url="/forum/viewtopic.php?p=4240655#p4240655"]мне кажется что в этой процедуре (запись заголовка) нужно добавить время записи файлов[/uquote]
по идее раньше https://forums.adafruit.com/viewtopic.php?f=25&t=124195
или rec.open файл создает ?
Сообщение olegue »
что то наподобии вот этого
 if (!file.timestamp(T_CREATE, 2009, 11, 10, 1, 2, 3)) {
	    error("set create time failed");
Добавлено after 57 seconds:
Morroc писал(а):или rec.open файл создает ?
таки да
Используем SD и RTC (ну и Wire для RTC)
План реализации:
Пишем callback-функцию дату-время и подсовываем её SD.
Реализация:
	#include <SD.h>
	#include <Wire.h>
	#include <RTClib.h>
	RTC_DS3231 RTC;  // define the Real Time Clock object
	// call back for file timestamps
	void cb_dateTime(uint16_t* date, uint16_t* time) {
	  DateTime now = RTC.now();
	  // return date using FAT_DATE macro to format fields
	  *date = FAT_DATE(now.year(), now.month(), now.day());
	  // return time using FAT_TIME macro to format fields
	  *time = FAT_TIME(now.hour(), now.minute(), now.second());
	void setup() {
	  Serial.begin(9600);
	  Wire.begin();
	  if (!RTC.begin()) {
	    Serial.println("RTC failed");
	    while(1);
	  // set date time callback function
	  SdFile::dateTimeCallback(cb_dateTime);
	 //теперь все операции с файлами должны брать время с RTC
	void loop() {}
Источник: первая ссылка Гугла "arduino sd file date time".[/quote]
вот здесь интересно сделано. //теперь все операции с файлами должны брать время с RTC
Добавлено after 5 minutes 26 seconds:
http://arduino.ru/forum/programmirovani ... e-failov-n
выше всё обсуждали...
Добавлено after 1 minute 22 seconds:
[uquote="roman.com",url="/forum/viewtopic.php?p=4239594#p4239594"]1.
у флешки есть своя собственная встроенная энергозависимая память... буфер SRAM на 512 байт.
2.
у флешки есть своя собственная встроенный энергонезависимая память ROM на 4 Гбайт.
Как происходит запись на флешку ?
1.
при записи на флешку все данные сначала записываются в буфер SRAM на 512 байт.
2.
после команды "запись" флешка перезаписывает все данные из буфера SRAM на 512 байт в память ROM на 4 Гбайт.
откуда я это знаю ? ))
потому что только после команды "запись" потребляемый ток подскакивает с ~0 mA до 7 mA.
т.е. флешка потребляет ток только в момент записи данных из буфера SRAM на 512 байт в память ROM на 4 Гбайт.
вот откуда я это знаю))
поэтому мы спокойно можем начала писать данные ADC в буфер SRAM на 512 байт.
а потом, когда буфер SRAM на 512 байт заполнится, флешка по команде перезапишет данные из буфера SRAM на 512 байт в буфер ROM на 4 Гбайт.
:tea:
но тут другая проблема... самая главная))
а сколько время записи флешки ? За сколько флешка по команде перезапишет данные из буфера SRAM на 512 байт в буфер ROM на 4 Гбайт ?
судя по приборам... десятки миллисекунд !!!
это значит что мы должны сидеть и ждать...... пока флешка перезапишет данные из буфера SRAM на 512 байт в буфер ROM на 4 Гбайт... И получается что в это самое время мы не можем ничего писать на флешку... :shock:
вооооотттт.... )))
или всё таки можем ? ))
:))[/uquote]
и т.д.
[uquote="roman.com",url="/forum/viewtopic.php?p=4239502#p4239502"]а чтобы после наших издевательств мы могли вставить флешку в ПК и прочитать что мы там записали... нам нужно писать на флешку не просто по секторам... а писать согласно файловой системе... FAT32... FAT16... и т.д.)) а для этого надо писать отдельную функцию - работа с файловой системой...
https://cxem.net/mc/mc435.php
но мне и не нужно писать/читать флешки с ПК.)) Поэтому я и не писал функции работа с файловой системой...
а просто писать/читать на флешку картинки и звук... и даже видео... можно и без файловой системы))
я так и сделал))
тупо взял ATmega8 и подключил к ней флешку и Ethernet модуль...
сижу... пишу с ПК на флешку... картинки и звук и видео...
сижу... читаю с флешки на ПК... картинки и звук и видео...
и т.д.
:tea:[/uquote]
мы что будем переписывать весь форум по новой ? ))
Сообщение Morroc »
Ага, пока диктофон на меге8 не заработает)
[uquote="olegue",url="/forum/viewtopic.php?p=4240675#p4240675"]вот здесь интересно сделано.[/uquote]
как работает еепром на Ардуине уже проверил ?))
/////////////////////////////////////////////////////////////////////////////////////////// код для Ардуино
// запись EEPROM Ардуино:
EEAR = 1; // пишем адрес ячейки куда хотим записать 1
EEDR = 1; // пишем данные которые хотим записать 1
EEAR = 2; // пишем адрес ячейки куда хотим записать 2
EEDR = 2; // пишем данные которые хотим записать 2
EEAR = 3; // пишем адрес ячейки куда хотим записать 3
EEDR = 3; // пишем данные которые хотим записать 3
/////////////////////////////////////////////////////////////////////////////////////////// END
//потом читаем...
// читаем EEPROM Ардуино:
EEAR = 1; // пишем адрес ячейки которую хотим прочитать 1
EECR |= 0b00000001; // пишем команду "чтение EEPROM"
Serial.println(EEDR); // выводим в последовательный порт... или куда мы там обычно выводим... ))
// в буфере EEDR находятся считанные данные
EEAR = 2; // пишем адрес ячейки которую хотим прочитать 2
EEAR = 3; // пишем адрес ячейки которую хотим прочитать 3
можешь скопировать это всё в свою Ардуину ))
:tea:
Serial.println(" "); - это что за фигня какая-то ? )) типа терминала какого то...
наподобие этого... System.out.println(" ");
не знаю... куда вы там всё выводите... лично я всё вывожу сразу... в Интернет)) :)))
точнее в Ethernet...
а куда вы там всё выводите... я без понятия))
:tea:
Сообщение olegue »
roman.com писал(а):можешь скопировать это всё в свою Ардуину ))
и тогда мне не понадобится библиотека eeпром для Ардуино?
надо попробовать
но если я буду писать структуру данных в еепром, то мне потребуется еще и ручками написать сколько памяти заняла та или иная переменная и т.д.
короче геморно это все, поэтому и придумали ардуину
но по любому освоить запись ADC на влэшку надо обязательно.
Добавлено after 3 minutes 17 seconds:
[uquote="roman.com",url="/forum/viewtopic.php?p=4240717#p4240717"]мы что будем переписывать весь форум по новой ? ))[/uquote]
я обязательно вернусь к тому что Вы написал, но чуть позже,я сначала хочу завершить этот проек и довести его до приемлегого состояния.
olegue писал(а):и тогда мне не понадобится библиотека eeпром для Ардуино?
не понадобится.
:tea:
Ардуино умеет работать напрямую с регистрами: EEAR, EEDR, EECR, EECR... и т.д.
Это название регистров AVR... но которой собрано Ардуино.
Без всяких библиотек))
olegue писал(а):но если я буду писать структуру данных в еепром
:dont_know:
я не работаю со структурами... мне они не нужны))
это пустая трата драгоценного процессорного времени... ))
olegue писал(а):поэтому и придумали ардуину
поэтому ардуина такая тормознутая))
:tea:
Вернуться в «AVR»
