Сообщение
MaxiMuz79 »
Обновление цен и списка микросхем.
AD669BN [Monolithic 16-Bit DACPORT] 10шт по 1400р
AD7837AN [Dual 12-Bit MDACs] 10шт по 1000р
DAC8413 (PMI) [Quad, 12-Bit DAC Voltage Output with Readback] 26шт по 2200р
DAC8413 (Analog Devices) [Quad, 12-Bit DAC Voltage Output with Readback] 16шт по 2200р
AD676KD [16-Bit 100 kSPS Sampling ADC] 10шт по 2400р
AD7892ANZ [12-Bit 600 kSPS ADC] 10шт по 1100р
ADC0834CCN [ADC 8BIT SERIAL I/O] 24шт по 500р
OP27F [Low Noise, Precision Op.Amp] 1шт по 400р
OPA551PA [High-Voltage, High-Current OpAmp] 1шт по 400р
LT1012 [Picoamp Input Current, Microvolt Offset, Low Noise Op Amp] 88шт по 100р
UA741CN [General purpose single operational amplifier] 1шт. по 50р
OP484FPZ [OpAmp 4 Amplifier, 4.25MHz, 4V/µs, ± 1.5V..18V] 7шт. по 1000р
CD74HCT74E [Flip Flop D-Type Pos-Edge 2-Element] 7шт по 10р
SN74HCT00N [QUADRUPLE 2-INPUT POSITIVE-NAND GATES] 7шт по 10р
CD74HC00E [High-Speed CMOS Logic Quad 2-Input NAND Gate] 18шт по 10р
SN74HC00N [QUAD 2-INPUT NAND] 4шт по 5р
74HC30N [8-INPUT NAND GATE] 12шт по 10р
CD74HCT30E [High Speed CMOS Logic 8-Input NAND Gate] 7шт по 5р
SN74LS07N [HEX BUFFERS/DRIVERS WITH OPEN-COLLECTOR HIGH-VOLTAGE OUTPUTS] 2шт по 10р
74HCT245N [Octal 3-State Noninverting Bus Transceiver with LSTTL-Compatible Inputs] 22шт. по 10р
SN74HC245N [OCTAL BUS TRANSCEIVERS WITH 3-STATE OUTPUTS] 161шт по 5р
74HCT139N [DUAL 2-LINE TO 4-LINE DECODERS/DEMULTIPLEXERS] 28шт по 5р
CD74HC154EN [4-TO-16 DECODER/DEMUX] 1шт по 50р
74HCT191N [Presettable synchronous 4-bit binary up/down counter] 28шт по 10р
SN74LS83AN [4-BIT BINARY FULL ADDER WITH FAST CARR] 20шт по 10р
74HC688N [8-BIT IDENTITY COMPARATORS] 23шт по 40р
74HCT688N [8-BIT IDENTITY COMPARATORS] 14шт по 40р
LM393N [2x Low-Offset Voltage comparator] 10шт по 30р
AD6581 [Ultrafast 7 ns Single Supply Comparator] 3шт по 400р
AD8561 [Ultrafast 7 ns Single Supply Comparator] 2шт по 400р
MAX378CPE [High-Voltage, Fault-Protected Analog Multiplexers] 10шт по 200р
ICL7556IPD [OSC TIMER DUAL 500KHZ 14-DIP] 5шт по 100р
TL7705ACP [SUPPLY VOLTAGE SUPERVISORS] 12шт по 20р
ICL7665S CPA [IC VOLT PROTECT OVER/UNDER] 8шт по 150р
AD688BQ [High Precision 10 V Reference] 6шт по 400р
AD586 [High Precision 5 V Reference] 1шт по 600р
AD588BQ [High Precision Reference] 1шт по 600р
UNC5801A [BiMOS II LATCHED DRIVERS] 25шт по 30р
UCN5841A [BiMOS II 8-bit serial-input, latched drivers] 27шт по 50р
GAL16V8B (15LP) [High Performance E2CMOS PLD Generic Array Logic] 25шт по 80р
GAL18V10 [High Performance E2CMOS PLD Generic Array Logic] 7шт по 60р
PALCE22V10H-25PC/4 [Flash-erasable Reprogrammable CMOS PAL] 20шт по 100р
Atmel ATV750 [High Density UV Erasable PLD] 20шт по 50р
NEC D43256 AC-85LL [256k-bit Cmos Static Ram 32k-word By 8-bit] 16шт по 50р
HY62256A [32Kx8bit CMOS SRAM] 12шт по 50р
INTEL P87C52EBFFA [CMOS single-chip 8-bit microcontrollers] 6шт по 100р
INTEL D87C51 [CMOS single-chip 8-bit microcontrollers] 5шт по 50р
DH321 [PWM controller] 20шт по 100р
LNK364PN [PWM controller] 14шт по 80р
MAX774CPA [PWM controller] 10шт по 80р
