Источник тока TML15515C
1900 рублей
Находится в Нижнем Новгороде
MTBF 660000 h
Operating Temperature Max. 60 °C
Operating Temperature Min. -25 °C
Output Current 1 2 A
Output Current 2 150 mA
Output Current 3 150 mA
Output Type Fixed
Output Voltage 1 5 V
Output Voltage 2 15 V
Output Voltage 3 -15 V
Output Voltage Nominal 1 5 V
Output Voltage Nominal 2 15 V
Output Voltage Nominal 3 -15 V
Outputs 3
Rated Power 15 W
Ripple & Noise (%) 1%
Termination Type Terminal Block
Width 54 mm
Вес, г 187
1900 рублей
MTBF 660000 h
Output Type Fixed
Outputs 3
Rated Power 15 W
Width 54 mm
Вес, г 187
