Модели цифровых микросхем серий 74ALSxx, 74ASxx, 74Sxx, 74Fxx для Proteus Pro
Сообщение Fizik_S »
Всем привет!
Делюсь некоторыми моделями цифровых микросхем для Proteus Pro.
Модели симулируемые, поэтому теперь возможно просимулировать цифровые схемы с применением указанных серий цифровых микросхем. Коллекция будет пополняться.
Список готовых моделей:
74ALS00, 74ALS00.DM, 74ALS00.IEC, 74ALS01, 74ALS01.DM, 74ALS01.IEC, 74ALS02, 74ALS02.DM, 74ALS02.IEC
74ALS03, 74ALS03.IEC, 74ALS04, 74ALS04.DM, 74ALS04.IEC, 74ALS08, 74ALS08.DM, 74ALS08.IEC
74ALS32, 74ALS32.DM, 74ALS32.IEC, 74ALS20, 74ALS20.DM, 74ALS20.IEC, 74ALS74, 74ALS74.IEC,
74ALS138, 74ALS138.IEC, 74ALS139, 74ALS139.IEC, 74ALS245, 74ALS245.IEC, 74ALS244, 74ALS244.IEC
74ALS257, 74ALS257.IEC, 74ALS153, 74ALS153.IEC, 74ALS373, 74ALS373.IEC, 74ALS374, 74ALS374.IEC
74ALS573, 74ALS573.IEC, 74ALS574, 74ALS574.IE, 74ALS175, 74ALS175.IE, 74ALS86, 74ALS86.IEC
74ALS161, 74ALS161.IE, 74ALS151, 74ALS151.IEC
74AS00, 74AS00.DM, 74AS00.IEC, 74AS02, 74AS02.DM, 74AS02.IEC, 74AS04, 74AS04.DM, 74AS04,IEC
74AS08, 74AS08.DM, 74AS08.IEC, 74AS32, 74AS32.DM, 74AS32.IEC, 74AS20, 74AS20.DM, 74AS20.IEC
74AS74, 74AS74.IEC, 74AS138, 74AS138.IEC, 74AS139, 74AS139.IEC, 74AS245, 74AS245.IEC,
74AS244, 74AS244.IEC, 74AS257, 74AS257.IEC, 74AS153, 74AS153.IEC, 74AS373, 74AS373.IEC,
74AS374, 74AS374.IEC, 74AS573, 74AS573.IEC, 74AS574, 74AS574.IE, 74AS175, 74AS175.IE,
74AS161, 74AS161.IE, 74AS151, 74AS151.IEC
74S00, 74S00.DM, 74S00.IEC, 74S02, 74S02.DM, 74S02.IEC, 74S03, 74S03.IEC, 74S04.IEC
74S08, 74S08.DM, 74S08.IEC, 74S32, 74S32.DM, 74S32.IEC, 74S20, 74S20.DM, 74S20.IEC
74S74, 74S74.IEC, 74S138, 74S138.IEC, 74S139, 74S139.IEC, 74S244, 74S244.IEC,
74S257, 74S257.IEC, 74S153, 74S153.IEC, 74S373, 74S373.IEC, 74S374, 74S374.IEC,
74S175, 74S175.IEC, 74S86, 74S151, 74S151.IEC, 74S86.IEC
74F00, 74F00.DM, 74F00.IEC, 74F02, 74F02.DM, 74F02.IEC, 74F04, 74F04.DM, 74F04.IEC
74F08, 74F08.DM, 74F08.IEC, 74F32, 74F32.DM, 74F32.IEC, 74F20, 74F20.DM, 74F20.IEC
74F74, 74F74.IEC, 74FI38, 74F138.IEC, 74F139, 74F139.IEC, 74F245, 74F245.IEC,
74F244, 74F244.IEC, 74F257, 74F257.IEC, 74F153, 74F153.IEC, 74F373, 74F373.IEC,
74F374, 74F374.IEC, 74F573, 74F573.IEC, 74F574, 74F574.IE, 74F86, 74F86.IEC,
74F161, 74F161.IEC
74HCT03, 74HCT03.IEC, 74HCT153, 74HCT153.IE, 74HCT175, 74HCT175.IEC, 7486, 7486.IEC
74HCT161, 74HCT161.IEC
Компьютер Орион-128, собранный в Proteus на этих моделях, симулируется корректно.
Установка:
Распаковать содержимое архива в каталог с установленной программой.
Модели будут с течением времени добавляться (по мере появления новых, не регулярно).
DATA.zip
(383.7 КБ) 42 скачивания
Сообщение Призрачный Суслик »
Эххх, вот бы SN7497.....
А что существует работоспособная модель 8080/Z80 ?
Сообщение Fizik_S »
Модель SN7497 я делал для симулятора SimulIDE. Если не нужна прецизионная точность, то могу слепить по быстрому и для Proteus. Добавить ее в библиотеку стандартных моделей, теоретически тоже можно... Попробую.
Рабочие модели Z80, 8080, 8085, 8086, 8088 и много другого полезного есть здесь: http://www.nedopc.org/forum/viewtopic.php?t=19632
Для SimulIDE есть модели Z80 + ULA ZX48K, MC6502 + периферия.
Вопрос к матерым котанам: как сюда картинки добавить без геморроя?
Сообщение Fizik_S »
Модельку слепил. Реальные задержки не учитываются. Для экспериментов, думаю, достаточно.
В архиве 2 файла с проектами: SN7497 - содержит модель, SN7497_test - тестовая схема.
Проект создан в Proteus 8.17 SP5.
Для создания своих схем нужно открыть проект SN7497 и добавить в него нужные компоненты. Если нужно несколько микросхем SN7497, то клонируем их из схемы.
SN7497.zip
(304.22 КБ) 28 скачиваний
Fizik_S писал(а): Ср авг 19, 2026 10:40:52 Если не нужна прецизионная точность
Что вы понимаете под "прецизионной точностью" ? Задержки ?
Fizik_S писал(а): Ср авг 19, 2026 13:25:14 Модельку слепил.
У меня 8.6 SP2 не открывает
Вообще не очень понимаю, как Орион - 128 целиком работает. У меня на 50 корпусе уже всё падало. Хотя там соизмеримо. да и небось узел регенерации ОЗУ можно проредить. ВВ55ые убрать, кроме "клавиатурной" и заменить регистрами по "жёстким" адресам.
Интересно еще как видеовывод реализован был, а загрузка ПО через ROM диск ?
(18.27 КБ) 202 скачивания
Сообщение Fizik_S »
Нужен Proteus именно 8.17 SP5. У них проблема: старые версии не открывают проекты, созданные в более новых версиях. Я пользуюсь этим: https://disk.yandex.ru/d/vuraPCFnQFLrbg (ссылка на мой я-диск)
Ссылки на рабочую схему Орион: http://www.nedopc.org/forum/viewtopic.php?t=23931 (для Протеуса 8.6)
Мои доработки с моими моделями: http://www.nedopc.org/forum/viewtopic.php?t=24258 (Протеус 8.17 ) Доработки продолжаются. Хочу сделать VGA выход в Орион.
Самое смешное, что по логике версия 8.6 SP2 старше, чем 8.17 SP5. Странно как-то. Но начал качать.
Сообщение Fizik_S »
Небольшое обновление библиотек моделей Proteus.
Добавлено:
74ALS21, 74ALS21.DM , 74ALS21.IEC , 74ALS166 , 74ALS166.IEC , 74ALS193 , 74ALS193.IEC , 74ALS241 , 74ALS241.IEC
74AS21, 74AS21.DM, 74AS21.IEC, 74AS241, 74AS8241,IEC
74S241, 74S241.IEC
74F166, 74F166.IEC, 74FI93, 74F193.IEC
74HCT21, 74HCT121.DM, 74HCT21.IEC, 74HCT166, 74HCT166.IEC, 74HCT393, 74HC93, 74HCT93, 74HCT390, 74HCT193
Установка моделей описана в топике
(129.68 КБ) 36 скачиваний
Результаты симуляции:
(50.83 КБ) 29 скачиваний
(123.83 КБ) 32 скачивания
DATA.zip
(484.46 КБ) 27 скачиваний
Сообщение Halex07 »
Призрачный Суслик писал(а): Ср авг 19, 2026 16:21:51 Самое смешное, что по логике версия 8.6 SP2 старше, чем 8.17 SP5
Что то у Вас со счётом совсем туговато!!! С каких пор 17 стало меньше, чем 6??? Вот если бы стояло через точку 8.1.7 (но такой я не видел), то это была бы версия 8.1 ... 7-й релиз. У Лабцентра так "считается"! Ну и далее по сервис пакам, чем выше SP в одной версии, тем свежее. Так что 8.17 - более поздняя версия чем 8.6.
Думал 8.6 это типа 8.60
Сообщение Fizik_S »
Добавлю еще немного моделей:
74ALS174 74ALS174.IEC 74ALS05
74ALS05.DM 74ALS05.IEC
74ALS09 74ALS09.DM 74ALS09.IEC
74ALS10 74ALS10.DM 74ALS10.IEC
74ALS109 74ALS109.IEC
74ALS11 74ALS11.DM 74ALS11.IEC
74ALS12 74ALS12.DM 74ALS12.IEC
74AS174 74AS1774,IEC
74AS10 74AS10.DM 74AS10.IEC
74AS109 74AS109.IEC
74AS11 74AS11.DM 74AS11.IEC
74S174 74S174.IEC
74S05.IEC
74S09 74S09.DM 74S09.IEC
74S10.IEC
74S11 74S11.DM 74S11.IEC
74S22.IEC
74F06 74F06.DM 74F06.IEC
74F07 74F07.DM 74F07.IEC
74F10 74F10.DM
74F10.IEC
TA4F109 74F109.IEC
74F11 74F11.DM 74F11.IEC
74HCT10 74HCT10.DM 74HCT10.IEC
74HCT109 74HCT109.IEC
(56.89 КБ) 33 скачивания
Внимание!
Архив в каждом новом сообщении содержит все ранее выложенные модели. Т.е. для установки всех моделей, в том числе и новых, достаточно скачать архив в последнем сообщении!
DATA.zip
(492.01 КБ) 27 скачиваний
Сообщение Fizik_S »
Еще немного новых моделей и исправление нескольких из предыдущих постов.
Добавлено:
74ALS28 74ALS28.DM 74ALS28.IEC
74ALS30 74ALS30.DM 74ALS30.IEC
74ALS33 74ALS33.DM 74ALS33.IEC
74ALS38 74ALS38.IEC
74ALS40 74ALS40.DM 74ALS40.IEC
74ALS112 74ALS112.IEC
74ALS113 74ALS113.IEC
74ALS114 74ALS114.IEC
74ALS133 74ALS133.DM 74ALS133.IEC
74AS30 74AS30.DM 74AS30.IEC
74S30.IEC
74S38 74S38.IEC
74S40 74S40.DM 7AS40.IEC
74S112 74S112.IEC
74S113.IEC 74S114.IEC
74S133.IEC
74F30 74F30.DM 74F30.IEC
74F38 74F38.IEC
74F112 74F112.IEC
7428 7428.DM 7428.IEC
74HCT30 74HCT30.DM 74HCT30.IEC
74HCT112 74HCT112.IEC
(52.54 КБ) 31 скачивание
DATA.zip
(500.15 КБ) 30 скачиваний
Сообщение Fizik_S »
Очередное пополнение новых моделей.
Добавлено:
74ALS136 74ALS136.IEC 74ALS137 74ALS137.IEC 74ALS156 74ALS156.IEC
74ALS157 74ALS157.IEC 74ALS158 74ALS158.IEC 74ALS160 74ALS160.IEC
74ALS162 74ALS162.IEC 74ALS163 74ALS163.IEC 74ALS164 74ALS164.IEC
74ALS165 74ALS165.IEC 74ALS169 74ALS169.IEC 74ALS190 74ALS190.IEC
74ALS191 74ALS191.IEC 74ALS192 74ALS192.IEC
74AS136 74AS136.IEC 74AS137 74AS137.IEC 74AS157 74AS157.IEC
74AS158 74AS158.IEC 74AS160 74AS160.IEC 74AS162 74AS162.IEC
774AS163 74AS163.IEC 74AS169 74AS169.IEC 74AS194 74AS194.IEC
74AS195 74AS195.IEC
74S132.IEC 74S157 74S158 74S158.IEC 74S162 74S162.IEC
74S163 74S169 74S169.IEC 74S194 74S195 74S195.IEC
74S196 74S197
74F132 74F132.DM 74F132.IEC 74F125 74F125.DM 74F125.IEC
74F14 74F14.DM 74F14.IEC 74F157 74F157.IEC 74F160 74F160.IEC
74F163 74F163.IEC 74F164 74F164.IEC 74F169 74F169.IEC 74F189
74F191 74F191.IEC 74F195 74F195.IEC
74HCT132 74HCT132.DM 74HCT132.IEC 74HCT125 74HCT125.DM 74HCT125.IEC
74HCT14 74HCT14.DM 74HCT14.IEC 74HCT151 74HCT151.IEC 74LS151 74LS151.IEC
74HCT160 74HCT160.IEC 74HCT163 74HCT163.IEC 74HCT190 74HCT190.IEC
74HCT191 74HCT191.IEC
(147.45 КБ) 36 скачиваний
DATA.zip
(537.96 КБ) 30 скачиваний
Сообщение Ariadna-on-Line »
Не улавливаю, зачем симулятору одно-хренственные модели ? Например типа 74LS174, 74ALS174, 74F174, 74S174 и тп 74xx174x !!! Это одна и та же схема в разном технологическом исполнении, но с одной и той же логикой ? То что у них разные временнЫе параметры, корпуса и токопотребление - симулятору нафиг не здалось. Он ЛОГИЧЕСКИЙ анализатор в первую очередь. Программеры Протеуса именно мудро поступили избавившись от повторов.
Сообщение Fizik_S »
Именно из-за такой "мудрости" программеров Протеуса мне и приходится дорабатывать эти модели. Например, компьютер Орион 128 изначально сделан на микросхемах К155 серии. Он будет работать, если все микросхемы заменить на 555 серию. Если заменить на КР1533 серию, то он работать не будет. Логика работы этих серий микросхем абсолютно одинакова, отличаются только быстродействием. Благодаря новым моделям, я, например, понял, какие микросхемы нельзя менять в схеме на быстродействующие, и какие желательно заменить на более быстрые.
Это действует тн эффект "гонки фронтов" - эффект экономии на спичках, когда не хотят расходовать элементы для создания задержек. Такое было в схеме Синклера (Ленинградской версии вроде как). Но эти тонкие и редкие проблемы не заслуживют кратного "распухания" библиотек.
ПС. Да абстрагирование от временнЫх параметров временами выходит боком и самому Протеусу. Иногда не правильно работает симуляция схем нормально работающих в реале. Такое у меня было при симуляции работы ATmega128 с внешним ОЗУ. Очень давно писАл об этом в Радиокоте.
Сообщение Fizik_S »
1. Насчет распухания библиотек: стандартные библиотеки без симуляции обозначенных в топике серий микросхем занимают объем 4842439 байт (округлим до 4.8 Мбайт). Мои, доработанные на сегодняшний момент занимают объем 6489431 байт (округлим до 6.5 Мбайт). Итого "распухание 6.5/4.8=1.35. Это совсем не кратное распухание, а всего лишь на 35%. Если считать объем всех библиотек (около 230 мегабайт), то распуханием можно пренебречь - так, небольшой прыщик...
2. Вы сами написали что некоторые модели кривые у Протеуса. Многих вообще нет (например ретро процессоров). Приходится создавать их с нуля. На сайте NEDOPC есть несколько полезных моделей, благодаря которым можно симулировать и дорабатывать некоторые винтажные компьютеры. Разве устранять недостатки программы это не совсем хорошее дело? На сайте kazus есть тема, посвященная разработке новых моделей и она пользуется достаточно большой популярностью. Цифровыми микросхемами в таком объеме никто не занимается.
3. Даже если не нужна симуляция микросхем. Я переделываю УГО этих самых микросхем. Теперь УГО, например, регистра, отличается от счетчика по внешнему виду и схемы выглядят более опрятно. Можете сравнить на скриншоте models_50.png, который над первым вашим сообщением.
4. Стоит ли тратить время на доработку моделей этих микросхем? Для меня - однозначно стоит (думаю и тем разрабам, которым эти самые микросхемы нужны). Мне понадобилась симуляция микросхем 74ALS, пришлось разбираться, как делать модели.... Оказалось все намного проще, чем я думал. Поэтому решил сделать "до кучи" и другие серии. Если попадаются несимулируемые микросхемы серий 74HC и 74HCT, то делаю и их... Дабы не пропадать "добру", делюсь наработками со всеми. Возможно сделаю несколько микросхем времен СССР. Например К176ИЕ13, 564ИК2 - я их делал для симулятора SimulIDE, можно и сюда портировать...
Как-то так...
Ariadna-on-Line писал(а): Чт сен 10, 2026 09:58:37 Это действует тн эффект "гонки фронтов" - эффект экономии на спичках, когда не хотят расходовать элементы для создания задержек. Такое было в схеме Синклера (Ленинградской версии вроде как). Но эти тонкие и редкие проблемы не заслуживют кратного "распухания" библиотек.
За рубежом в те годы были похожие проблемы с "гонками фронтов" и доработки на платах в виде конденсаторов и RC цепочек встречались в "серьёзной" аппаратуре. Всё шло от экономии элементов.
А так, дело полезное, хоть кто библиотеки делает и то хорошо. Интересно, а новые модели приборов в "Протеусе" сделать и подключить можно ? Очень не хватает генератора заданного числа импульсов с входами запуска, остановки и сброса счётчика. Такой генератор хорошо подойдёт для проверки корректности работы всяких пересчётных схем.
Сообщение Dmitry Dubrovenko »
Fizik писал(а):есть здесь
А чего это НедоПС перестал открываться?
Или это только у меня?
:roll:
