Iam from Macedonia and I get this diode from my teacher.He had a lot of diodes like this one.
Diode КД2026
Hi there to every one,i want to ask you is there a datasheet from this diode КД2026.What kind of diode is this and do you have datasheet for it?Thx
- diods_.pdf
- (242.98 КБ) 261 скачивание
Последний раз редактировалось leonid62 Чт май 26, 2011 17:35:15, всего редактировалось 2 раза.
This is probably КД202Б
http://d-vt.ru/index.php?d=data&mark=kd202b
ууу, прямо краснеешь, когда иностранцы про наши детали интересуются. А то лмки да тлки...
Forward Voltage at 3.5A DC - 0,9 V
Full Load Reverse Current - 0,8mA
Maximum Average Forward Rectified Current - 3,5 А
Maximum Recurrent Peak Reverse Voltage - 50 V
Maximum DC Blocking Voltage - 35 V
Peak Forward Surge Current 1500ms - 9 А
Frequency - 5 кHZ
Frequency - 5 кHZ
Успех - императив!
Yes,that is.Its with Б not 6
can I use it to make diode bridge?And how amper can I get from this diodes?
Tnx for the fast answer
its rectifier diode, so yes.can I use it to make diode bridge?
3A, but beforе 4кHz. Otherwise - babahAnd how amper can I get from this diodes?
Успех - императив!
wow,how you mean 4kHz?What is that,sorry for that I can't understand you
In Macedonia we have Macedonian forum for electronics,visit as at elektronika-mk.net/forum/
frequency AC voltage must be lower than 5kHz. Best below.wow,how you mean 4kHz?
thxIn Macedonia we have Macedonian forum for electronics,visit as at elektronika-mk.net/forum/
Успех - императив!
