Aging OffsetThe aging offset register takes a user-provided value to
add to or subtract from the codes in the capacitance
array registers. The code is encoded in two’s comple-
ment, with bit 7 representing the sign bit. One LSB rep-
resents one small capacitor to be switched in or out of
the capacitance array at the crystal pins. The aging off-
set register capacitance value is added or subtracted
from the capacitance value that the device calculates
for each temperature compensation. The offset register
is added to the capacitance array during a normal tem-
perature conversion, if the temperature changes from
the previous conversion, or during a manual user con-
version (setting the CONV bit). To see the effects of the
aging register on the 32kHz output frequency immedi-
ately, a manual conversion should be started after each
aging register change.
Positive aging values add capacitance to the array,
slowing the oscillator frequency. Negative values
remove capacitance from the array, increasing the
The change in ppm per LSB is different at different
temperatures. The frequency vs. temperature curve is
shifted by the values used in this register. At +25°C,
one LSB typically provides about 0.1ppm change in
frequency.
Use of the aging register is not needed to achieve the
accuracy as defined in the EC tables, but could be
used to help compensate for aging at a given tempera-
ture. See the Typical Operating Characteristics section
for a graph showing the effect of the register on accu-
racy over temperature.
Стареющее смещение
Регистр смещения старения принимает предоставленное пользователями значение к
добавьте к или вычтите из кодов в емкости
регистры массива. Код закодирован в дополнении two с битом 7 представлений знакового бита. Один LSB представляет один маленький конденсатор, который будет переключен в или из
массив емкости в кристаллических контактах. Значение емкости регистра смещения старения добавлено или вычтено
от значения емкости, которое вычисляет устройство
для каждой температурной компенсации. Регистр смещения
добавлен к массиву емкости во время нормального температурного преобразования, если изменения температуры от
предыдущее преобразование, или во время ручного пользовательского преобразования (устанавливающий CONV укусил). Видеть эффекты
стареющий регистр на выходной частоте на 32 кГц сразу, ручное преобразование должно быть запущено после каждого
стареющее изменение регистра.
Положительные стареющие значения добавляют емкость к массиву,
замедление частоты осциллятора. Отрицательные величины
удалите емкость из массива, увеличившись
частота осциллятора.
Изменение в странице в минуту за LSB отличается в различном
температуры. Частота по сравнению с температурной кривой
смещенный на значения используется в этом регистре. В +25°C,
один LSB обычно обеспечивает изменение на приблизительно 0.1 страницы в минуту в
частота.
Использование стареющего регистра не необходимо, чтобы достигнуть
точность, как определено в таблицах EC, но мог быть
используемый, чтобы помочь компенсировать старение при данной температуре. Посмотрите раздел Typical Operating Characteristics
для графика, показывающего эффект регистра на точности по температуре.
Полезный лайфхак - чтобы увидеть картинку в оригинальном размере, удалите из адреса слово medium/
Например: http:///img.radiokot.ru/files/86369/medium/hi06i91ui.jpg
