VKOT, интересно, печатка уже соответствует.
Добавлено after 1 minute 43 seconds:
И контроллер был ILI9806G стал ILI9806E
Добавлено after 2 hours 16 minutes 22 seconds:
The ILI9806G supports parallel MPU 8-/9-/16-/18-/24-bit data bus interfaces and a 3-line serial peripheral interface
to input commands. The ILI9806G supports a RGB (16-/18-/24-bit) data bus for video image display. For
high-speed serial interface, the MIPI DSI and MDDI (Mobile Display Digital Interface) interface mode, the ILI9806G
supports two data lanes and one clock lane for high-speed and low power transmission in both directions with low
EMI noise.
The ILI9806E supports 3-line serial peripheral interface to input commands. The ILI9806E supports a RGB
(16-/18-/24-bit) data bus for video image display. For high-speed serial interface, the MIPI DSI interface mode,
the ILI9806E supports two data lanes and one clock lane for high-speed and low power transmission in both
directions with low EMI noise.
ему команды только по SPI можно давать. В новом архиве все примеры также RGB + SPI. Смело можно спор открывать, так как нет параллельной шины.
Старый
Display interface types:
MPU mode:
MIPI-DBI Type B (Display Bus Interface, 80 System) interface, 8/9/16/18/24-bit bus
MIPI-DBI Type C (Serial data transfer interface, 3-line SPI) interface
MIPI-DSI (Display Serial Interface) interface:
Supports one data lane/maximum speed 850Mbps or
Supports two data lanes/maximum speed 500Mbps
Supports DSI version 1.01.00
Supports D-PHY version 1.00.00
Supports DCS version 1.02.00
MDDI (Mobile Display Serial Interface):
Supports one data lane/maximum speed 800Mbps or
Supports two data lanes/maximum speed 400Mbps
Supports MDDI V1.2 1 strobe
MIPI-DPI (Display Pixel Interface) interface:
16 bit/pixel (R: 5-bit, G: 6-bit, B: 5-bit)
18 bit/pixel (R: 6-bit, G: 6-bit, B: 6-bit)
24 bit/pixel (R: 8-bit, G: 8-bit, B: 8-bit)
новый
Interface types
Supports one data lane / maximum speed 850Mbps or
Supports two data lanes / maximum speed 500Mbps
Supports DSI version 1.02.00
3 line-9bit SPI (Serial Peripheral Interface) interface
Добавлено after 21 second:
https://yadi.sk/d/6oufZF_NZbyqwg
Добавлено after 45 seconds:
Не спроста перемычки стояли на RGB...
