Люди бодрые, что можете сказать о состоянии этого страдальца? Как я понимаю, все хорошо?
Не у всех возможно.Кот-Кот писал(а):Частоту парковки бы поправить.
Ха, может, пароль мне специально нужен. ))))Кот-Кот писал(а):И пароль снять
smartctl 6.4 2014-10-07 r4002 [i686-linux-4.1.0-1-586] (local build)
Copyright (C) 2002-14, Bruce Allen, Christian Franke, http://www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Red (AF)
Device Model: WDC WD20EFRX-68EUZN0
Serial Number: WD-WCC4M92NX9F6
LU WWN Device Id: 5 0014ee 20aaa599e
Firmware Version: 82.00A82
User Capacity: 2В 000В 398В 934В 016 bytes [2,00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sat Feb 13 16:08:31 2016 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (26940) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 272) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 175 169 021 Pre-fail Always - 4241
4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 1538
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 094 094 000 Old_age Always - 4929
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 672
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 91
193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 4106
194 Temperature_Celsius 0x0022 111 105 000 Old_age Always - 36
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Conveyance offline Completed without error 00% 4926 -
# 2 Extended offline Aborted by host 90% 4925 -
# 3 Short offline Completed without error 00% 4925 -
# 4 Short offline Completed without error 00% 4924 -
# 5 Extended offline Aborted by host 90% 4924 -
# 6 Short offline Aborted by host 30% 4924 -
# 7 Short offline Completed without error 00% 0 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.Поэтому я бы не переживал особо.S.M.A.R.T писал(а):SMART overall-health self-assessment test result: PASSED
Материнка ничего не "предсказывает". Она лишь обрабатывает данные, которые ей даёт S.M.A.R.T. диска, и возвращает stop-ошибку, если значения критические.Boreaz писал(а):может ли материнка предсказать отказ винчестера лучше чем его собственный контроллер
Элементарные: проверить работу диска на ином компьютере.Boreaz писал(а):а какие еще варианты?
Это я понимаю, но смарт Вы сами видели, что ей не понравилось? К тому же пишут что после ремонта диска например, материнки матерятся даже на чистый смарт, из за G-list-а, но к данному случаю это отношения не имеет, так как сейчас все работает без претензий. В общем буду подозревать либо материнку, либо контроллер диска, махну еще БП между компами, может там пульсации какие.Материнка ничего не "предсказывает". Она лишь обрабатывает данные, которые ей даёт S.M.A.R.T. диска, и возвращает stop-ошибку, если значения критические.
