Захотел я собрать счетчик десятично-двоичный на атмега16. Но счет идет через раз/такт.
Код и схема прилагается.
This program was produced by the
CodeWizardAVR V2.03.9 Evaluation
Automatic Program Generator
© Copyright 1998-2008 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date : 04.08.2016
Author : Freeware, for evaluation and non-commercial use only
Company :
Comments:
Chip type : ATmega16
Program type : Application
AVR Core Clock frequency: 8,000000 MHz
Memory model : Small
External RAM size : 0
Data Stack size : 256
#include <mega16.h>
#include <stdlib.h>
#define SET_B(x) |= (1<<x)
#define CLR_B(x) &=~(1<<x)
long int chislo,count1,chislo2,count2,count3,count;
// Declare your global variables here
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port A initialization
// Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
// State7=0 State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=0
PORTA=0x00;
DDRA=0xFF;
// Port B initialization
PORTB=0x00;
DDRB=0xFF;
// Port C initialization
PORTC=0x00;
DDRC=0xFF;
// Port D initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTD=0x00;
DDRD=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
count=0;
while (1)
if (PIND.2==1) { if (PIND.1==1) { while(PIND.1==1){}; count++;
count2=count; count3=0;
while(count2>0)
{count2=count2/2;
if(count2 & 0x01)
if (count3<8) { PORTA SET_B(count3);};
if (count3<16 && count3>7) { PORTB SET_B(count3);};
if (count3<22 && count3>15) { PORTC SET_B(count3);};
count3++;
//число нечетное
else
if (count3<8) { PORTA CLR_B(count3);};
if (count3<16 && count3>7) { PORTB CLR_B(count3);};
if (count3<22 && count3>15) { PORTC CLR_B(count3);};
count3++;
//число четное
if (PIND.0==1) { while(PIND.0==1){}; chislo = rand()&41893; chislo2=(chislo+50);
for (count1=chislo;count1<chislo2;count1++) {
count2=count1; count3=0;
while(count2>1)
{count2=count2/2;
if(count2 & 0x01)
//число нечетное
else
//число четное
count3++;
// Place your code here
- test.7z
- (50.12 КБ) 123 скачивания
