STM32L152CBU6
AD9288BSTZ-100
G6KU-2G-Y
CY7C1041DV33-10ZSXI
EPM570T144C5N
74HC4052 TSSOP16
74HC573 TSSOP16
74LVC1G3157
74HC4052D
дисплей Nokia 2760/2660/2670 внешний
Еще немного хотелок:
155ИД1 (SN74141)
ATTINY2313A-SU
IRF740S
ИНС-1
LC72131M
MP1593DN
CXA1691BM
HEF4052BT
MC3362P
KS-H-148
На обмен предлагаю тоже в небольших количествах детальки от:
Linear
LT1004IZ-2.5#PBF uP Volt Ref 2.5V 0.8% Tol TO-92LT1029CZ - 5V Bandgap Reference TO-92
LT1034BIZ-2.5#PBF 2.5V Ref, 20ppm/C Max TC TO-92
LT1074CT#PBF (MAX724) 5A Step-Down Switching Regulator TO-220-5
LT1086CT#PBF Adj 1.5A Low Dropout Positive Regulators TO-220
LT1086CT-5#PBF 1.5A Low Dropout Positive Regulators TO-220
LT1117CST-5#PBF
LT1117IST-3.3#PBF
LT1117IST-5#PBF
LT1210CT7#PBF 1.1A, 35MHz Current Feedback Amplifier (CFA) TO-220
LT1431IZ#PBF 5v Shunt Voltage References TO-92
LT1460GIZ-2.5#PBF Micropower Precision Series Reference Family TO-92
LT1460HCS3-2.5#TRMPBF Micropower Precision Series Reference Family SOT-23-3
LT1460HCS3-3.3#TRMPBF Micropower Precision Series Reference Family SOT-23-3
LT1510-5CGN#PBF Constant-Voltage Battery Charger NiCd, NiMH and Lithium-Ion Batteries SSOP16
LT1510CS8#PBF Constant-Current Battery Charger NiCd, NiMH and Lithium-Ion Batteries SO-8
LT1512IN8#PBF SEPIC Constant-Current/Constant-Voltage Battery Charger PDIP-8
LT1512IS8#PBF SEPIC Constant-Current/Constant-Voltage Battery Charger SO-8
LT1611CS5#PBF Inverting 1.4MHz Switching Regulator SOT-23-5
LT1613CS5#PBF 1.4MHz, Single Cell DC/DC Converter in 5-Lead SOT-23-5
LT1615IS5#PBF Micropower Step-Up DC/DC Converters Up to 34V SOT-23-5
LT1634ACS8-2.5#PBF Micropower Precision Shunt Voltage Reference SO8
LT1634BCMS8-2.5#PBF Micropower Precision Shunt Voltage Reference MSOP
LT1634CCZ-5#PBF 5v Shunt Voltage References TO-92
LT1761IS5-2.5#PBF 100mA, Low Noise, LDO Micropower Regulators in TSOT-23-5
LT1761IS5-3#PBF 100mA, Low Noise, LDO Micropower Regulators in TSOT-23-5
LT1790ACS6-1.25#PBF Micropower Low Dropout Reference Family SOT-23-3
LT1790ACS6-2.5#PBF Micropower Low Dropout Reference Family SOT-23-3
LT1806IS6#PBF - 325MHz, Single, Rail-to-Rail Input and Output, Low Distortion, Low Noise Precision Op Amps
LT1807IMS8 325MHz, Dual, Rail-to-Rail Input and Output, Low Distortion, Low Noise Precision Op Amps
LT1937ES5#PBF 350mA LED Driver
LT1961EMS8E#PBF 1.5A, 1.25MHz Step-Up Switching Regulator
LT1964ES5-5 200mA, Low Noise, Low Dropout Negative Micropower Regulator
LT1964IS5-5#PBF 200mA, Low Noise, Low Dropout Negative Micropower Regulator in TSOT-8
LT3010HMS8E#PBF Adj 50mA, 3V to 80V Low Dropout Micropower Linear Regulator MSOP-8
LT3010HMS8E-5#PBF 5V 50mA, 3V to 80V Low Dropout Micropower Linear Regulator MSOP-8
LT3090EMSE#PBF –36V, 600mA Negative Linear Regulator with Programmable Current Limit MSOP-12
LT3439EFE#PBF - Slew Rate Controlled Ultralow Noise 1A Isolated DC/DC Transformer Driver TSSOP-16
LT3462AES6#PBF Inverting 1.2MHz/2.7MHz DC/DC Converters with Integrated Schottky in TSOT-6
LT3465ES6#PBF - 1.2MHz White LED Step-Up Converters with Built-In Schottky TSOT-23-6
LT3483IS6#PBF - Inverting Micropower DC/DC Converters with Schottky SOT-23-6
LT3593ES6#PBF 1MHz White LED Driver with Output Disconnect and One Pin Current Programming SOT-23-6
LT5400AHMS8E-1#PBF Matched Resistor Network, Quad 10k MSOP-8
LT5400AHMS8E-2#PBF Matched Resistor Network, Quad 100k MSOP-8
LT5400AHMS8E-4#PBF Matched Resistor Network, Dual 1k/1k MSOP-8
LT6015HS5#PBF Single 3.2MHz, 0.8V/μs Low Power, Over-The-Top Precision Op Amps SOT-23-5
LT6016HMS8#PBF - Dual 3.2MHz, 0.8V/μs Low Power, Over-The-Top Precision Op Amps MSOP-8
LT6210IS6#PBF - Single Programmable Supply Current, R-R Output, Current Feedback Amplifiers
LT6230IS6 215MHz, Rail-to-Rail Output, 1.1nV/rtHz, 3.5mA Op Amp
LT6654AHS6-1.25#PBF Precision Wide Supply High Output Drive Low Noise Reference SOT-23-6
LT6654AHS6-2.048#PBF Precision Wide Supply High Output Drive Low Noise Reference SOT-23-6
LT6654AHS6-2.5#PBF Precision Wide Supply High Output Drive Low Noise Reference SOT-23-6
LT6654AHS6-3#PBF 2.5v 0.05% Precision Wide Supply High Output Drive Low Noise Reference SOT-23-6
LT6654AHS6-3.3#PBF Precision Wide Supply High Output Drive Low Noise Reference SOT-23-6
LT6654AHS6-5#PBF Precision Wide Supply High Output Drive Low Noise Reference SOT-23-6
LT6656AIS6-1.25#TRMPBF 1µA Precision Series Voltage Reference SOT-23-6
LT6656AIS6-2.5#TRMPBF 1µA Precision Series Voltage Reference SOT-23-6
LT6656AIS6-5#TRMPBF 1µA Precision Series Voltage Reference SOT-23-6
LT8300MPS5#PBF - 100VIN Micropower Isolated Flyback Converter with 150V/260mA Switch TSOT-23-5
LT8301HS5#PBF - 42VIN Micropower No-Opto Isolated Flyback Converter with 65V/1.2A Switch TSOT-23-5
LT8471IFE#PBF Dual Multitopology DC/DC Converters with 2A Switches and Synchronization TSSOP-20
LT8616HFE#PBF Dual 42V Synchronous Monolithic Step-Down Regulator with 6.5μA Quiescent Current TSSOP-28
LTC1099CSW#PBF - High Speed 8-Bit A/D Converter with Built-In Sample-and-Hold SO-20
LTC1406IGN#PBF - Low Power, 8-Bit, 20Msps, Sampling A/D Converter
LTC1410IG#PBF 12-Bit, 1.25Msps, Sampling A/D Converter with Shutdown SSOP-28
LTC1415IG#PBF - 12-Bit, 1.25Msps, 55mW Sampling A/D Converter SSOP-28
LTC1415ISW#PBF - 12-Bit, 1.25Msps, 55mW Sampling A/D Converter SO-28
LTC1605AIG#PBF (Improved 2nd Source to ADS7805 and AD976) 16-Bit, 100ksps, Sampling ADC SSOP-28
LTC1609IG#PBF (Improved 2nd Source to ADS7809 and AD977A) 16-Bit, 200ksps, Serial ADC with Multiple Input Ranges SSOP-28
LTC1609ISW#PBF (Improved 2nd Source to ADS7809 and AD977A) 16-Bit, 200ksps, Serial ADC with Multiple Input Ranges SO-20
LTC1732-8.4 Complete Linear Charger Controller for 2-Cell Lithium-Ion Batteries MSOP-10
LTC1732EMS-4.2#PBF Complete Linear Charger Controller for 1-Cell Lithium-Ion Batteries
LTC1799HS5#PBF 1kHz to 33MHz Resistor Set SOT-23 Oscillator SOT-23-5
LTC1864AIMS8#PBF µPower, 16-Bit, 250ksps 1-Channel ADCs in MSOP-8
LTC1865IS8#PBF µPower, 16-Bit, 250ksps 2-Channel ADCs in SO-8
LTC2312HTS8-14#PBF 14-Bit, 500ksps Serial Sampling ADC in TSOT23-8
LTC2313HTS8-14#PBF 14-Bit, 2.5Msps Serial Sampling ADC in TSOT23-8
LTC2314HTS8-14#PBF 14-Bit, 4.5Msps Serial Sampling ADC in TSOT-23-8
LTC3108IGN#PBF Ultralow Voltage Step-Up Converter and Power Manager
LTC3114IFE-1#PBF - 40V, 1A Synchronous Buck-Boost DC/DC Converter with Programmable Output Current TSSOP-16
LTC3122IMSE#PBF 15V, 2.5A Synchronous Step-Up DC/DC Converter with Output Disconnect MSOP-12
LTC3215EDD#PBF 700mA Low Noise High Current LED Charge Pump 3x3mm DFN-10
LTC3216EDE#PBF 1A Low Noise High Current LED Charge Pump with Independent Torch/Flash Current Control 3x4mm DFN-12
LTC3218EDDB#PBF 400mA Single Wire Camera LED Charge Pump 3x2mm DFN-10
LTC3454EDD#PBF Synch Buck-Boost High Power LED Driver in 10 3x3 DFN
LTC3626#PBF - 20V, 2.5A Synchronous Monolithic Step-Down Regulator with Current and Temperature Monitoring
LTC3646EMSE#PBF -2 - 40V, 1A Synchronous Step-Down Converter
LTC4070IMS8E#PBF - Li-Ion/Polymer Shunt Battery Charger System MSOP-8
LTC4120IUD#PBF Wireless Power Receiver and 400mA Buck Battery Charger QFN-16
LTC6090HS8E#PBF 140V CMOS Rail-to-Rail Output, Picoamp Input Current Op Amp SO-8
LTC6252HS6#TRMPBF - 720MHz, 3.5mA Power Efficient Rail-to-Rail I/O Op Amps LTFRW 6-Lead Plastic TSOT-23 –40°C to 125°C
LTC6253HMS8#TRPBF - 720MHz, 3.5mA Dual Power Efficient Rail-to-Rail I/O Op Amps LTFRX 8-Lead Plastic MSOP –40°C to 125°C
LTC6253HTS8#TRPBF - 720MHz, 3.5mA Dual Power Efficient Rail-to-Rail I/O Op Amps LTFRY 8-Lead Plastic TSOT-23
LTC6905HS5#PBF 17MHz to 170MHz Resistor Programmable Oscillator SOT23-5
LTC6905HS5-100#PBF 100MHz Fixed Frequency Oscillator SOT23-5
LTC6905HS5-80#PBF 80MHz Fixed Frequency Oscillator SOT23-5
LTC6907HS6#PBF - Micropower, 40kHz to 4MHz Resistor Set Oscillator SOT-23-5
LTC6992HS6-1#PBF TimerBlox: Voltage-Controlled Pulse Width Modulator (PWM) TSOT-23-6
LTC6992HS6-3#PBF TimerBlox: Voltage-Controlled Pulse Width Modulator (PWM) TSOT-23-6
LTC6992IS6-2#PBF TimerBlox: Voltage-Controlled Pulse Width Modulator (PWM) TSOT-23-6
LTC6992MPS6-4#TRMPBF TimerBlox: Voltage-Controlled Pulse Width Modulator (PWM) TSOT-23-6
LTC6993IS6-2#PBF - TimerBlox: Monostable Pulse Generator (One Shot)Pulse Width Range: 1?s to 33.6 Seconds SOT-23-6
LTC6995IS6-1#PBF TimerBlox: Long Timer, Low Frequency Oscillator Period Range: 1ms to 9.5 Hours SOT-23-6
LTC6995IS6-2#PBF TimerBlox: Long Timer, Low Frequency Oscillator Period Range: 1ms to 9.5 Hours SOT-23-6
Добавлено after 14 minutes 18 seconds:
Supertex (MICROCHIP)
HV9921N3-G 3-Pin Switch-Mode LED Lamp Driver IC TO-92HV9921N8-G 3-Pin Switch-Mode LED Lamp Driver IC SOT-89
HV9925SG-G Programmable-Current LED Lamp Driver IC with PWM Dimming SOIC-8
HV9961LG-G LED Driver with Average-Mode Constant Current Control SOIC-8
INTERSIL
EL7630IWTZ 6 LEDs DriverHIP4020 Full Bridge Driver with Integrated 0.5A Power FETs for Small 3V, 5V and 12V DC Motors
ICL7136 1/2 Digit LCD/LED, Low Power Display, A/D Converters with Overrange Recovery
ICL7660 Switched-Capacitor Voltage Converters =MAX1044
ICL7673CBAZA Automatic Battery Back-Up Switch
ISL54504 +1.8V to +5.5V, 2.5?, Single SPST Analog Switches
ISL6294IBZ High Input Voltage Charger
ISL78301FVEBZ 40V, Low Quiescent Current, 150mA Linear Regulator
ISL78301FVECZ 40V, Low Quiescent Current, 150mA Linear Regulator
ISL80103IRAJZ High Performance 3A Linear Regulator
ISL80138IVEAJZ 40V, Low Quiescent Current, 150mA Linear Regulator
ISL8204M Complete High Efficiency DC/DC Power Module
ISL8206MIRZ Complete High Efficiency DC/DC Power Module
ISL84051 Low Voltage, Single and Dual Supply, 8-to-1 Multiplexer, Dual 4-to-1 Multiplexer and a Triple SPDT Analog Switch
ISL8499 Ultra Low ON-Resistance, +1.65V to +4.5V, Single Supply, Quad SPDT (Dual DPDT) Analog Switch
ISL9003AIEJZ-T Low Noise LDO with Low IQ, High PSRR
ISL9111AEH50Z-T7A Low Input Voltage, High Efficiency Synchronous Boost Converter with 1A Switch
ISL97516 600kHz/1.2MHz PWM Step-Up Regulator
FREESCALE (TI)
FXTH870511DT1 TPMS 7X7 450kPa X&Z axisFXAS21002C 3axis MEMS Gyroscope
FXOS8700CQR1 6-Axis Sensor with Integrated Linear Accelerometer and Magnetometer QFN-16
FXTH870902DT1 TPMS 7X7 900kPa Z axis
MAG3110АСК1 Three-Axis, Digital Magnetometer QFN-10
MC34671AEPR2 High Input Voltage 600mA Charger for Single-cell Li-Ion Batteries UDFN-8
MC34673AEPR2 High Input Voltage 1.2A Charger for Single-cell Li-Ion Batteries QFN-EP 8
MK10DX256VLH7 =3 Kinetis K 32-bit MCU, ARM Cortex-M4 core, 256KB Flash, 72MHz, QFP 64
MMA6900KQ Digital Low g Accelerometer, 3.3V, XY, 3.5g, QFN 16
MMA690xQ=3 ±3.5g/±5.0g, Dual-Axis, Analog Acceleration Sensor QFN-16
MMA8451Q: ±2g/±4g/±8g, Low g, 14-bit Digital Accelerometer
MMA8452QT, Freescale MMA8452Q 3-Axis, 12-bit/8-bit Digital Accelerometer QFN 16
MMA8652FCR1 ±2g/±4g/±8g, 3-Axis, 12-Bit Digital Accelerometer DFN-10
MP3H6115A6U Pressure Sensor, 3V, 15/115kPa, SOP 8
MP3V5050VC6U Pressure Sensor, 3V, 0/50kPa, SOP 8, Vented Axial Por
MPL3115A2 Xtrinsic Pressure Sensor, 2.5V, 20/110kPa, LGA 8
MPXH6115A High Temperature Accuracy Integrated Silicon Pressure Sensor for Measuring Absolute Pressure, On-Chip Signal Conditioned, Temperature Compensated and Calibrated SOP-8, SSOP-8
MPXH6115A6U Pressure Sensor, 5V, 15/115kPa, SOP 8
MPXV6115V6U High Temperature Accuracy Integrated Silicon Pressure Sensor for Measuring Absolute Pressure, On-Chip Signal Conditioned, Temperature Compensated and Calibrated SOP-8
MPXV7025DP -25 to 25 kPa Integrated Silicon Pressure Sensor On-Chip Signal Conditioned,Temperature Compensated and Calibrated
MPXV7025GC6U Pressure Sensor, 5V, -25/25kPa, SOP 8, Axial Port
S9S08DZ60F2MLF 8-bit MCU, S08 core, 60KB Flash, 40MHz, -40/+125degC, Automotive Qualified, QFP 48
Добавлено after 14 minutes 44 seconds:
TI = NSC
74LVC1G125DBVRG4 SINGLE BUS BUFFER GATE WITH 3-STATE OUTPUT SOT23-5ADS831E 8-Bit, 80MHz Sampling Analog-To-Digital Converter SSOP-20
DCP010512DBP Miniature, 1W Isolated Unregulated DC/DC Converters 7PDIP
DCP010515DBP-U
DCP022405P
DCR012405P Miniature, 1W Isolated Regulated DC/DC Converters 10PDIP
DCR020515DP-U 2W Isolated Regulated DC/DC Converters PDIP-7
DCR021205P-U 2W Isolated Regulated DC/DC Converters SOP-10
DCR022405P-U 2W Isolated Regulated DC/DC Converters SOP-10
INA169NA High-Side Measurement CURRENT SHUNT MONITOR SOT23-5
LM2576HVS-ADJ/NOPB SIMPLE SWITCHER® 3A Step-Down Voltage Regulator DDPAK/TO-263
LM2576T-ADJ/NOPB SIMPLE SWITCHER® 3A Step-Down Voltage Regulator TO-220
LM2664M6 Switched Capacitor Voltage Converter SOT-23-6
LM2687MM Low Noise Regulated Switched Capacitor Voltage Inverter
LM2904DRG3 Dual Operational Amplifier
LM2940T-5.0/NOPB 1A Low Dropout Regulator TO-220
LM317LZ 100mA, Adjustable Output, Positive Voltage Regulator
LM3886TF/NOPB IC AMP AUDIO PWR 68W AB TO220-11
LM397MF/NOPB Single General Purpose Voltage Comparator SOT-23-5
LM4040A25IDBZR 0,1% PRECISION MICROPOWER SHUNT VOLTAGE REFERENCE SOT23-3
LM4132AMF-2.5/NOPB Precision Low Dropout Voltage Reference SOT-23-5
LM4780 Overture™ Audio Power Amplifier Series Stereo 60W, Mono 120W Audio Power Amplifier with Mute TO-220-27
LM4780TA/NOPB Overture™ Audio Power Amplifier Series Stereo 60W, Mono 120W Audio Power Amplifier with Mute TO-220-27
LMR64010 SIMPLE SWITCHER® 40Vout, 1A Step-Up Voltage Regulator in SOT-23-5
LP2985A-28DBVR Micropower 150 mA Low-Noise Ultra Low-Dropout Regulator in SOT-23
LP2985A-29DBVR Micropower 150 mA Low-Noise Ultra Low-Dropout Regulator in SOT-23
LP2985A-30DBVR Micropower 150 mA Low-Noise Ultra Low-Dropout Regulator in SOT-23
LP2985A-33DBVR Single Output LDO, 150mA, Fixed(3.3V), 1.5% Tolerance, Low Quiescent Current, Low Noise SOT23-5
LP5907MFX-2.8/NOPB ULTRA LOW NOISE, 250-mA LINEAR REGULATOR FOR RF AND ANALOG CIRCUITS - REQUIRES NO BYPASS CAPACITOR SOT-23-5
LP5907MFX-3.0/NOPB 250mA, Ultra-Low Noise Low-Dropout Regulator SOT-23-5
LP5907MFX-3.3/NOPB ULTRA LOW NOISE, 250-mA LINEAR REGULATOR FOR RF AND ANALOG CIRCUITS - REQUIRES NO BYPASS CAPACITOR SOT-23-5
OPA2350EA/250 High-Speed, Single-Supply, Rail-to-Rail Operational Amplifier
OPA2350UA High-Speed, Single-Supply, Rail-to-Rail Operational Amplifier
OPA2369AIDCNT 1.8V, 700nA, Zero-Crossover Rail-To-Rail I/O Operational Amplifier
OPA2369AIDGKT 1.8V, 700nA, Zero-Crossover Rail-To-Rail I/O Operational Amplifier VSSOP-8
OPA2830ID Dual, Low-Power, Single-Supply, Wideband Operational Amplifier
OPA369AIDCKT 1.8V, 700nA, Zerø-Crossover RAIL-TO-RAIL I/O OPERATIONAL AMPLIFIER
PTN04050A 6-W, 3.3/5-V Input, Wide Adjust Output Positive-to-Negative Converter
PTN04050CAD 12-W, 3.3/5-V Input, Wide Adjust Output Boost Converter модуль
REF3125AIDBZT 2,5V 0.2% 15ppm/°C Max, 100µA, SOT23-3 Series Voltage Reference SOT23-3
SN74GTL2010PWR
SN74HC4060DBR 14-Stage Asynchronous Binary Counters And Oscillators SSOP-16
SN74LVC1G14DBVR Single Schmitt-Trigger Inverter SOT23-5
SN74LVC1G17 Single Schmitt-Trigger Buffer SOT23-5
SN74LVC1GX04DBVR Crystal Oscillator Driver SOT23-6
SN74LVC2G04 Dual Inverter Gate SOT23-6
SN74LVC2G14 Dual Schmitt-Trigger Inverter SOT23-6
TLC7135CDW 41/2 Digit, BCD Output, A/D Converter DIP
TLC7135CDW 41/2 Digit, BCD Output, A/D Converter SO-28
TLE2072ID Excalibur Low-Noise High-Speed JFET-Input Op Amps SOIC8
TPS60400 unregulated 60mA charge pump voltage inverter SOT-23
TPS60403DBVT Unregulated 60-mA Charge Pump Voltage Inverters SOT-23-5
TPS61041DBVR LOW-POWER DC/DC BOOST CONVERTER to 28V IN SOT-23
TPS61220DCK Adj Low input voltage step-up converter in 6 PIN SC-70 package
TPS61221DCK 3.3 В Low input voltage step-up converter in 6 PIN SC-70 package
TPS61222DCK 5 В Low input voltage step-up converter in 6 PIN SC-70 package
TPS62736RGYT Programmable Output Voltage Ultra-Low Power Buck Converter with up to 50mA / 200 mA QFN-14
TPS78330DDCT(TPS78330DDCR) 500nA IQ, 150mA, Ultra-Low Quiescent Current Low-Dropout Linear Regulator
TPS7A3301KC –36-V, –1-A, Ultralow-Noise Negative Voltage Regulator TO-220-7
TPS7A4700RGWT Low Noise (4.17µVrms), 1A, High Voltage Low-Dropout Linear Regulator VQFN-20
Добавлено after 2 hours 4 minutes 40 seconds:
MAXIM
DS1307Z+DS2406+
DS2438Z+
DS2480B+ Serial to 1-Wire Line Driver
DS2762AE+025 High-Precision Li+ Battery Monitor With Alerts
DS9503P+ ESD Protection Diode with Resistors
ICL7662CBA+ CMOS Voltage Converter
LM4050AEM3-5.0+ Precision Micropower Shunt Voltage References
MAX1678EUA+ 1 Cell to 2 Cell, Low-Noise, High-Efficiency, Step-Up DC-DC Converter µmax 8 pin
MAX1709=1 4A, Low-Noise, High-Frequency, Step-Up DC-DC Converter
MAX1724EZK50+ 1.5мA IQ, Step-Up DC-DC Converters
MAX1811ESA+ USB-Powered Li+ Charger
MAX44009EDT+ Цифровые датчики освещенности
MAX4466EXK+ Low-Cost, Micropower, Microphone Preamplifiers with Complete Shutdown SC70/SOT23-8
MAX660ESA+ Switched Capacitor Voltage Converter
MAX7044AKA+ 300MHz to 450MHz High-Efficiency, Crystal-Based +13dBm ASK Transmitter SOT23-8
MAX743EWE DC/DC Uвх=+5.0V Uвых=±12(15)V Iвых=±125mA
MAX756ESA+ 3.3V/5V/Adjustable-Output,Step-Up DC-DC Converters
MAX764ESA+ -5V High-Efficiency, Low IQ DC-DC Inverters SO-8
MAX8571EUT+ High-Efficiency LCD Boost with True Shutdown SOT23-6
SILABS
TS1005IJ5T ONLY 0.8V TO 5.5V, 1.3µA, 20kHz RAIL-TO-RAIL SINGLE OP AMPTS1002IM8T THE ONLY DUAL 0.8V/0.6µA RAIL-TO-RAIL OPERATIONAL AMPLIFIER
TS1003IG5TP THE ONLY 0.8V TO 5.5V, 0.6µA RAIL-TO-RAIL SINGLE OP AMP
TS100IJ5T 0.8V/0.6µA RAIL-TO-RAIL OPERATIONAL AMPLIFIER
TS1103-200 2V to 25V, 1µa, 200µV VOS bidirectional Precision Current-Sense Amplifier SOT23-6
TS3001=3 1V/1μA Easy-to-Use Resistor-Tuned Silicon Oscillator/Timer
TS6001A-2.5 +2.5V LOW-POWER/LOW-DROPOUT 7ppm/°C PRECISION VOLTAGE REFERENCE SOT23-3
TSM6025A(MAX6025) +2.5V LOW-POWER PRECISION VOLTAGE REFERENCE SOT23-3
AMS
AS1322A-BTTT DC-DC Step-Up Converter Low Voltage, 1.2 MHz with Automatic PowersaveAS1322B-BTTT DC-DC Step-Up Converter Low Voltage, 1.2 MHz with Automatic Powersave with Continuous Switching
AS1323-BTTT-30 TSOT23-5 3.0V DC-DC Step-Up Converter 1.6µA Quiescent Current
AS1324-BTTT-18 TSOT23-5 1.8V DC-DC Step-Up Converter 1.6µA Quiescent Current
AS1329A-BTTT TSOT23-6 DC-DC Step-Up Converter Low Voltage, 1.2 MHz
AS1329B-BTTT TSOT23-6 DC-DC Step-Up Converter Low Voltage, 1.2 MHz
AS1329C DC-DC Step-Up Converter Low Voltage, 1.2 MHz
AS1356-25-T 150mA Low Dropout Regulator, Reverse Battery Protection
AS1356-27-T 150mA Low Dropout Regulator, Reverse Battery Protection, Power-OK Flag
AS1356-30-T 150mA Low Dropout Regulator, Reverse Battery Protection
AS1358-BTTT-28 TSOT23-5 2.8V 150mA 9µVrms Ultra-Low-Noise, 92dB High-PSRR - LDO
AS1358-BTTT-285 TSOT23-5 2.85V 150mA 9µVrms Ultra-Low-Noise, 92dB High-PSRR - LDO
AS1358-BTTT-30 TSOT23-5 3.0V 150mA 9µVrms Ultra-Low-Noise, 92dB High-PSRR - LDO
AS1358-BTTT-33 TSOT23-5 3.3V 150mA 9µVrms Ultra-Low-Noise, 92dB High-PSRR - LDO
AS1359-BTTT-27 300mA 9µVrms Ultra-Low-Noise, 92dB High-PSRR - LDO
AS1359-BTTT-28 300mA 9µVrms Ultra-Low-Noise, 92dB High-PSRR - LDO
AS1359-BTTT-285 300mA 9µVrms Ultra-Low-Noise, 92dB High-PSRR - LDO
AS1359-BTTT-30 300mA 9µVrms Ultra-Low-Noise, 92dB High-PSRR - LDO
AS1359-BTTT-31 300mA 9µVrms Ultra-Low-Noise, 92dB High-PSRR - LDO
AS1359-BTTT-33 300mA 9µVrms Ultra-Low-Noise, 92dB High-PSRR - LDO
AS1363-BSTT-15 500mA Ultra-Low-Dropout Linear Regulator
AS1363-BSTT-18 500mA Ultra-Low-Dropout Linear Regulator
AS1363-BSTT-30 TSOT23-6 500mA Ultra-Low-Dropout Linear Regulator
AS1363-BSTT-33 TSOT23-6 500mA Ultra-Low-Dropout Linear Regulator
AS1363-BSTT-45 TSOT23-6 500mA Ultra-Low-Dropout Linear Regulator
AS1500-T-Z SOIC8 Digital Potentiometer
AS1710A-ASCT Single Rail to rail Op Amp with shutdown SC70-6
AS1710B-ASCT High-Output-Drive, 10MHz, 10V/µs, Rail-to-Rail I/O Op Amp with Shutdown
AS1712A-AQFT High-Output-Drive, 10MHz, 10V/мs, Rail-to-Rail I/O Op Amps with Shutdown TQFN-16
AS1741H-T-Z SOT23-8 High-Speed, Low-Voltage, Single-Supply, 0.8Ω, Dual SPST Analog Switches
AS1742H-T-Z SOT23-8 Dual 0.8? SPST Switch
AS1743H-T-Z SOT23-8 Dual 0.8? SPST Switch SPST NO/NC
AS1753S-T-Z TSSOP14 Quad 0.9? SPST Switch SPST NO/NC
AS5000-MD6H-1 Magnet for Rotary Position Sensor D6x2.5mm
AS5030 8-bit Rotary Position Sensor with Digital Angle(Interface) and PWM output TSSOP16
AS5040 10-bit Rotary Position Sensor with Digital Angle(Interface), ABI, UVW and PWM output Output SSOP16
AS5045-ASST SSOP16 12 Bit Programmable Magnetic Rotary Encoder
Analog Devices
AD590KRZ 2-TERMINAL IC TEMPERATURE TRANSDUCER SOIC-8AD592ANZ CURRENT OUTPUT – PRECISION IC TEMPERATURE TRANSDUCER
AD712JRZ (TL082CD) Precision, Low Cost, High Speed, BiFET Dual Op Amp SO-8
AD7176-2BRUZ 24-BIT, 250 kSPS SIGMA DELTA ADC WITH 20 µS SETTLING
AD7401AYRWZ: ISOLATED SIGMA-DELTA MODULATOR
AD7495ARZ 1 MSPS, 12-Bit A/D Converter in MSOP-8 or SOIC-8
AD7705BRUZ 3 V/5 V, 1 mW, 2-Channel, 16-Bit, Sigma-Delta ADCs TSSOP-16
AD7705BRZ 3 V/5 V, 1 mW, 2-Channel, 16-Bit, Sigma-Delta ADCs SO-16
AD7790BRMZ 16-Bit, Single-Channel, Ultra Low Power, Sigma Delta A/D Converter MSOP-10
AD7793BRUZ 3-Channel, Low Noise, Low Power, 24-Bit Sigma Delta ADC with On-Chip In-Amp and Reference 16 ld TSSOP
AD7822BRUZ 3V/5V, 2 MSPS, 8-Bit, 1-Channel Sampling ADCs TSSOP-20
AD7825BRUZ 3V/5V, 2 MSPS, 8-Bit, 4-Channel Sampling ADCs TSSOP-24
AD7825BRZ 3V/5V, 2 MSPS, 8-Bit, 4-Channel Sampling ADCs SOIC-24
AD7829BRUZ 3V/5V, 2 MSPS, 8-Bit, 8-Channel Sampling ADCs TSSOP-28
AD7829BRZ 3V/5V, 2 MSPS, 8-Bit, 8-Channel Sampling ADCs SOIC-28
AD8032ARZ 2.7 V, 800 µA, 80 MHz RAIL-TO-RAIL I/O DUAL AMPLIFIER SO-8
AD8038AKSZ Low Power, 350 MHz Voltage Feedback Amplifiers SC70-5
AD8038ARZ Low Power, 350 MHz Voltage Feedback Amplifiers SOIC-8
AD8051ARTZ Low Cost, High Speed, Rail-to-Rail Amplifier SOT-23-5
AD8052ARMZ Low Cost, High Speed, Rail-to-Rail Amplifier MSOP-8
AD8052ARZ Low Cost, High Speed, Rail-to-Rail Amplifier SOIC-8
AD8065ART High Performance, 145 MHz FastFET Op Amps
AD8065ARTZ High Performance, 145 MHz FastFET Op Amps SOT-23-5
AD8066ARMZ High Performance, 145 MHz FastFET™ Op Amp MSOP-8
AD8066ARZ High Performance, 145 MHz FastFET™ Op Amp SOIC-8
AD8067ARTZ High Gain Bandwidth Product, Precision FastFET™ Op Amp SOT-23-5
AD8129ARMZ Low Cost 200 MHz Differential Receiver Amplifier MSOP-8
AD8129ARZ Low Cost 200 MHz Differential Receiver Amplifier SO8
AD8211 High Voltage Current Shunt Monitor SOT23-5
AD8230YRZ 16 V Rail-to-Rail, Zero-Drift, Precision Instrumentation Amplifier SO8
AD8231ACPZ Zero Drift, Digitally Programmable Instrumentation Amplifier LFCSP_VQ-16
AD823AARZ 17 MHz, Rail-to-Rail FET Input Dual Amplifier SO8
AD827JNZ HIGH SPEED, LOW POWER DUAL OP AMP PDIP-8
AD827JRZ-16 HIGH SPEED, LOW POWER DUAL OP AMP SOIC-16
AD830ANZ High Speed, Video Difference Amplifier PDIP-8
AD830ARZ High Speed, Video Difference Amplifier SOIC-8
AD8468WBKSZ-R7 Rail-to-Rail, Fast, Low Power 2.5 V to 5.5 V, Single-Supply TTL/CMOS Comparator 6 ld SC70
AD8510ARMZ Low Noise, Low Input Bias Current, Wide Bandwidth JFET, Precision Op Amp MSOP-8
AD8510ARZ Low Noise, Low Input Bias Current, Wide Bandwidth JFET, Precision Op Amp SOIC-8
AD8541ARTZ GENERAL-PURPOSE CMOS RAIL-TO-RAIL AMPLIFIER SOT23-5
AD8542ARMZ GENERAL-PURPOSE CMOS DUAL RAIL-TO-RAIL AMPLIFIER SO-8
AD8551ARZ ZERO-DRIFT, SINGLE-SUPPLY, RRIO SINGLE OP AMP SOIC-8
AD8552ARUZ Zero-Drift, Single-Supply, Rail-to-Rail Input/Output Operational Amplifiers TSSOP-8
AD8552ARZ Zero-Drift, Single-Supply, Rail-to-Rail Input/Output Operational Amplifiers SOIC-8
AD8561ARZ ULTRAFAST 7 NS SINGLE SUPPLY COMPARATOR
AD8610ARMZ Precision, Low Input Bias Current, Wide BW JFET Single Op Amp MSOP-8
AD8628ARTZ Zero-Drift, Single-Supply, Rail-to-Rail Input/Output Operational Amplifier SOT-23-5
AD8652ARMZ 50 MHz, PRECISION LOW DISTORTION, LOW NOISE CMOS DUAL OP AMP MSOP-8
AD8652ARZ 50 MHz, PRECISION LOW DISTORTION, LOW NOISE CMOS DUAL OP AMP SOIC-8
AD8655ARMZ Low Noise,Precision CMOS Amplifier MSOP-8
AD8655ARZ Low Noise,Precision CMOS Amplifier SOIC-8
AD8656ARMZ Low Noise, Precision CMOS Dual Amplifier MSOP-8
AD8656ARZ Low Noise, Precision CMOS Dual Amplifier MSOP-8
AD9281ARSZ DUAL CHANNEL 8-BIT RESOLUTION CMOS ADC
AD9833BRMZ Low Power, 12.65 mW, 2.3 V to +5.5 V, Programmable Waveform Generator MSOP-10
AD9834CRUZ 20 mW Power, 2.3 V to 5.5 V, 75 MHz Complete DDS TSSOP
AD9835BRUZ 50 MHz Direct Digital Synthesizer, Waveform Generator 16 ld TSSOP
ADA4817-1: LOW NOISE, 1 GHz FastFET OP AMPS
ADA4841-2YRMZ DUAL LOW POWER, LOW NOISE AND DISTORTION, RAIL-TO-RAIL OUTPUT AMPLIFIER MSOP-8
ADA4841-2YRZ DUAL LOW POWER, LOW NOISE AND DISTORTION, RAIL-TO-RAIL OUTPUT AMPLIFIER SOIC-8
ADA4851-1WYRJZ-R7 Low Cost, High Speed, Rail-to-Rail, Output Op Amp (Single) SOT-23-6
ADA4851-2YRMZ Low Cost, High Speed, Rail-to-Rail, Output Op Amp (Dual)
ADA4851-4WYRUZ-R7 Low Cost, High Speed, Rail-to-Rail, Output Op Amp (Quad)
ADA4870ARRZ HIGH SPEED, HIGH VOLTAGE, 1 A OUTPUT DRIVE AMPLIFIER PSOP3-20
ADCMP361WYRJZ-RL7 Single 0.275% Comparator and Reference with Dual Polarity Outputs 5 ld SOT-23
ADF7012BRUZ MULTICHANNEL ISM BAND FSK/GFSK/OOK/GOOK/ASK TRANSMITTER TSSOP-24
ADF7025 High Performance ISM Band Transceiver IC 48-Lead Lead Frame Chip Scale Package [LFCSP_WQ]
ADG1401BRMZ 1 ? On Resistance, ±15 V/+12 V/±5 V, iCMOS SPST Switches
ADG3301BKSZ-REEL7 Low Voltage 1.15 V to 5.5 V, Single-Channel Bidirectional Logic Level Translator SC70-6
ADG3304BRUZ Low Voltage 1.15 V to 5.5 V, 4 Channel, Bidirectional, Logic Level Translator 14 ld TSSOP
ADG4612BRUZ Power Off Protection ±5 V, +12V, Quad SPST Switches with 5? On Resistance 16 ld TSSOP
ADG4613BRUZ Power Off Protection ±5 V, +12V, Quad SPST Switches with 5? On Resistance 16 ld TSSOP
ADG5401BRMZ HIGH VOLTAGE LATCH-UP PROOF, SINGLE SPST SWITCH MSOP-8
ADG819BRTZ 0.5 ? CMOS 1.8 V to 5.5 V 2:1 Mux/SPDT Switch with BBM Switching Action
ADM2582EBRWZ 2.5 kV Signal and Power Isolated, ±15 kV ESD Protected, Full/Half Duplex RS-485 Transceiver (16Mbps)
ADM3202ANZ High-Speed, 2-Channel RS232/V.28 Interface Devices 16 ld PDIP
ADM3202ARNZ High-Speed, 2-Channel RS232/V.28 Interface Devices 16 ld SOIC
ADM3202ARUZ High-Speed, 2-Channel RS232/V.28 Interface Devices TSSOP-16
ADM3222ANZ High-Speed, +3.3V, 2-Channel RS232/V.28 Interface Device with 460kBPS Data Rate and Shutdown and Enable Pins PDIP-18
ADM3222ARUZ High-Speed, +3.3V, 2-Channel RS232/V.28 Interface Device with 460kBPS Data Rate and Shutdown and Enable Pins TSSOP-20
ADM3222ARWZ High-Speed, +3.3V, 2-Channel RS232/V.28 Interface Device with 460kBPS Data Rate and Shutdown and Enable Pins 18 ld SOIC - Wide
ADM3251EARWZ ISOLATED SINGLE CHANNEL RS-232 LINE DRIVER/RECEIVER SO-20
ADM3260ARSZ HOT SWAPPABLE, DUAL I2C ISOLATORS WITH INTEGRATED DC-TO-DC CONVERTER SSOP-20
ADM7151ARDZ 800 mA Ultralow Noise, High PSRR, RF Linear Regulator SOIC-EP-8
ADM823LYRJ-R7 4.7v Supervisory Circuits with Watchdog and Manual Reset and SOT-23-5
ADM824SYRJZ-REEL7 Supervisory Circuits with Watchdog and Manual Reset in 5-Lead SC70 and SOT-23
ADM825LYRJ-R7 Supervisory Circuits with Watchdog and Manual Reset in 5-Lead SC70 and SOT-23
ADM8828ARTZ Switched-Capacitor Voltage Inverter with Shutdown SOT-23-6
ADP1111ARZ-12 Micropower, Step-Up/Step-Down SW Regulator; Adjustable and Fixed 3.3 V, 5 V, 12 V 8 ld SOIC
ADP123AUJZ 5.5 V Input, 300 mA, Low Quiescent Current, CMOS Linear Regulator, Adjustable Output Voltage TSOT-5
ADP162AUJZ-2.5 ULTRALOW QUIESCENT CURRENT, 150 MA, CMOS LINEAR REGULATORS TSOT-5
ADP162AUJZ-2.8 V Input, 300 mA, Low Quiescent Current, CMOS Linear Regulator, Adjustable Output Voltage TSOT-5
ADP162AUJZ-3.0 V Input, 300 mA, Low Quiescent Current, CMOS Linear Regulator, Adjustable Output Voltage TSOT-5
ADP162AUJZ-3.3 V Input, 300 mA, Low Quiescent Current, CMOS Linear Regulator, Adjustable Output Voltage TSOT-5
ADP162AUJZ-4.2 V Input, 300 mA, Low Quiescent Current, CMOS Linear Regulator, Adjustable Output Voltage TSOT-5
ADP1710AUJZ-3.3-R7 150 mA, Low Dropout, CMOS Linear Regulator SOT23-6
ADP2108AUJZ-2.5-R7 Compact, 600 mA, 3 MHz, Step-Down DC-to-DC Converter TSOT-5
ADP2108AUJZ-3.0 Compact, 600 mA, 3 MHz, Step-Down DC-to-DC Converter TSOT-5
ADP2108AUJZ-3.3 Compact, 600 mA, 3 MHz, Step-Down DC-to-DC Converter TSOT-5
ADP2301AUJZ 1.2 A, 20 V, 1.4 MHz non-synchronous step-down switching regulator TSOT-6
ADP2303ARDZ-2.5 3A, 700KHz NonSynchronous Step-Down DC-DC Switching Regulator 8 ld SOIC
ADP2303ARDZ-3.3 3A, 700KHz NonSynchronous Step-Down DC-DC Switching Regulator 8 ld SOIC
ADP2303ARDZ-5.0 3A, 700KHz NonSynchronous Step-Down DC-DC Switching Regulator 8 ld SOIC
ADP2441ACPZ-R7 36 V,1 A, Synchronous,Step-Down DC-to-DC Regulator 12-lead, 3х3 mm LFCSP
ADP7104ARDZ-1.8-R7 20 V, 500 mA, LOW NOISE, CMOS LDO 8 ld SOIC-EP
ADP7104ARDZ-2.5-R7 20 V, 500 mA, LOW NOISE, CMOS LDO 8 ld SOIC-EP
ADP7104ARDZ-3.0-R7 20 V, 500 mA, LOW NOISE, CMOS LDO 8 ld SOIC-EP
ADP7104ARDZ-3.3-R7 20 V, 500 mA, LOW NOISE, CMOS LDO 8 ld SOIC-EP
ADP7104ARDZ-5.0-R7 20 V, 500 mA, LOW NOISE, CMOS LDO 8 ld SOIC-EP
ADP7104ARDZ-9.0-R7 20 V, 500 mA, LOW NOISE, CMOS LDO 8 ld SOIC-EP
ADP7105ARDZ-5.0 20 V, 500 mA, Low Noise LDO Regulator with Soft Start SO-8
ADP7142AUJZ-2.5-R7 40 V, 200 mA, Low Noise, CMOS LDO Linear Regulator TSOT-23-5
ADP7142AUJZ-3.3-R7 40 V, 200 mA, Low Noise, CMOS LDO Linear Regulator TSOT-23-5
ADP7142AUJZ-5.0-R7 40 V, 200 mA, Low Noise, CMOS LDO Linear Regulator TSOT-23-5
ADR291GT9Z Low Noise Micropower Precision Voltage Reference (2.5 V) TO-92
ADR3425ARJZ-R7 Micro-Power, High-Accuracy 2.5V Voltage Reference SOT23-6
ADR361AUJZ-REEL7 LOW POWER, LOW NOISE VOLTAGE REFERENCE WITH SINK/SOURCE CAPABILITY, 2.5 VOUT TSOT-23-5
ADR391AUJZ-REEL7 2.5V Micropower, Low Noise Precision Voltage Reference with Shutdown TSOT-5
ADR421ARZ
ADR421BR
ADR440ARMZ Ultralow Noise, LDO XFET Voltage References with Current Sink and Source MSOP-8
ADR441ARZ Ultralow Noise, LDO XFET Voltage References with Current Sink and Source SOIC-8
ADR445ARMZ Ultralow Noise, LDO XFET Voltage References with Current Sink and Source MSOP-8
ADR445ARZ Ultralow Noise, LDO XFET Voltage References with Current Sink and Source SOIC-8
ADR4520BRZ Ultralow Noise, High Accuracy Voltage References SOIC8
ADR4525BRZ Ultralow Noise, High Accuracy Voltage References SOIC8
ADR4530 Ultralow Noise, High Accuracy Voltage References SOIC8
ADR4533BRZ Ultralow Noise, High Accuracy Voltage References SOIC8
ADR4540BRZ Ultralow Noise, High Accuracy Voltage References SOIC8
ADR4550ARZ Ultra-Low-Noise, High-Accuracy 5.0V Voltage Reference SOIC-8
ADR5041WARTZ-R7 Precision Micropower Shunt Mode Voltage Reference Applications (2.5 Vout)Pin compatible with LM4040/LM4050 SOT-23-3
ADR5045ARTZ-REEL7 Precision Micropower Shunt Mode Voltage Reference Applications (5.0 Vout)Pin compatible with LM4040/LM4050 SOT-23-3
ADT6401SRJZ-RL7 Low Cost, 2.7 V to 5.5 V, Pin-Selectable Temperature Switch in SOT-23 (Open Drain Output)
ADT6402SRJZ-RL7 Low Cost, 2.7 V to 5.5 V, Pin-Selectable Temperature Switches in SOT-23 (Push-Pull Output)
ADT6501SRJZP085RL71 +85°C ±6°C Low Cost, 2.7 V to 5.5 V, Micropower Temperature Switches Open-drain output SOT-23-5
ADT6501SRJZP095RL7 +95°C ±6°C Low Cost, 2.7 V to 5.5 V, Micropower Temperature Switches Open-drain output SOT-23-5
ADT6501SRJZP115RL7 +115°C ±6°C Low Cost, 2.7 V to 5.5 V, Micropower Temperature Switches Open-drain output SOT-23-5
ADT7320UCPZ-RL7 ±0.25°C ACCURATE, 16-BIT DIGITAL SPI TEMPERATURE SENSOR
ADUM1100BRZ Single Channel Digital Isolator
ADUM1100URZ Single Channel Digital Isolator
ADUM1201AR Dual-Channel Digital Isolators
ADUM1201CRZ Dual-Channel Digital Isolators
ADUM1201WURZ Dual-Channel Digital Isolators
ADUM1285CRZ 3kV rms, Default Low, Dual-Channel Digital Isolators (2/0 Channel Directionality) SOIC-8
ADUM1400CRWZ Quad-Channel Digital Isolator (4/0 Channel Directionality)
ADUM1402CRWZ Quad-Channel Digital Isolator (2/2 Channel Directionality)
ADUM1510BRWZ 5-Channel, Unidirectional Digital Isolator
ADUM2285CRIZ 5 kV RMS Dual Channel Digital Isolators (Default Low, 2/0 Channel Directionality)
ADUM3070ARQZ ISOLATED SWITCH REGULATOR WITH INTEGRATED FEEDBACK QSOP-16
ADUM3123ARZ Isolated Precision Gate Driver, 4 A Output SOIC-8
ADUM3123BRZ Isolated Precision Gate Driver, 4 A Output SOIC-8
ADUM3123CRZ Isolated Precision Gate Driver, 4 A Output SOIC-8
ADUM3160BRWZ Full/Low Speed 2.5 kV USB Digital Isolator SO-16
ADUM3200WCRZ Dual-Channel, Digital Isolator, Enhanced System-Level ESD Reliability SOIC-8
ADUM3224WARZ 3kV rms Isolated Precision Half-Bridge Driver, 4A Output for Automotive SOIC-16
ADUM3440CRWZ QUAD CHANNEL, HIGH SPEED DIGITAL ISOLATORS SO-16 CNC
ADUM3442CRWZ QUAD CHANNEL, HIGH SPEED DIGITAL ISOLATORS
ADUM4150BRIZ 5kV, DEDICATED ISOLATORS FOR HIGH-SPEED SPI INTERFACES (WITH 1/1 AUX CHANNEL DIRECTIONALITY) SOIC-20
ADUM4160BRIZ Full/Low Speed USB Digital Isolator 16 ld SOIC
ADUM4160BRWZ FULL/LOW SPEED USB DIGITAL ISOLATOR SO-16
ADUM4472CRIZ=2 ISOLATED SWITCH REGULATOR WITH QUAD-CHANNEL ISOLATORS (2/2 CHANNEL DIRECTIONALITY)
ADUM5000ARWZ ISOLATED DC/DC CONVERTER SO-16
ADUM5201CRWZ DUAL-CHANNEL ISOLATORS WITH INTEGRATED DC-TO-DC CONVERTER (1/1 CHANNEL DIRECTIONALITY) SO-16
ADuM5241ARZ Dual-Channel Isolators with isoPower Integrated DC-to-DC Converter, 50 mW SO-8 Развязка гальваническая для 1- Wire устройств
ADUM5401CRWZ QUAD-CHANNEL ISOLATORS WITH INTEGRATED DC/DC CONVERTER (3/1 CHANNEL DIRECTIONALITY) SO-16
ADUM5402CRWZ QUAD-CHANNEL ISOLATORS WITH INTEGRATED DC/DC CONVERTER (2/2 CHANNEL DIRECTIONALITY) SO-16
ADUM5403ARWZ QUAD-CHANNEL ISOLATORS WITH INTEGRATED DC/DC CONVERTER (1/3 CHANNEL DIRECTIONALITY) SO-16
ADUM5404CRWZ QUAD-CHANNEL ISOLATORS WITH INTEGRATED DC/DC CONVERTER (0/4 CHANNEL DIRECTIONALITY) SO-16
ADUM6010ARSZ 3.75KV RMS ISOLATED DC/DC CONVERTER SSOP-20
ADUM6200CRIZ DUAL-CHANNEL, 5 kV ISOLATORS WITH INTEGRATED DC/DC CONVERTER (2/0 CHANNEL DIRECTIONALITY) SO-16
ADUM6201CRIZ DUAL-CHANNEL, 5 kV ISOLATORS WITH INTEGRATED DC/DC CONVERTER (1/1 CHANNEL DIRECTIONALITY) SO-16
ADUM6400CRWZ Quad-Channel, 5 kV Isolators with Integrated DC-to-DC Converter SOIC-16
ADUM6402CRWZ QUAD-CHANNEL ISOLATORS WITH INTEGRATED DC/DC CONVERTER (2/2 CHANNEL DIRECTIONALITY) SOIC-16
ADUM7234 Isolated Precision Half-Bridge Driver, 4 A Output SO-16
ADUM7510BRQZ 5-CHANNEL, 1 KV UNIDIRECTIONAL DIGITAL ISOLATOR QSOP-16
ADXRS290BCEZ Ultralow Noise, Dual-Axis Gyroscope 4.5 mm × 5.8 mm × 1.2 mm cavity laminate package
OP777ARMZ Precision Micropower Single-Supply Operational Amplifiers SOIC8
SSM2305RMZ-REEL7 Filterless High Efficiency Mono 2.8 W Class-D Audio Amplifier MSOP-8
TMP01FPZ Low Power, Programmable Temperature Controller (Temperature Sensor) DIP-8
TMP06BRTZ-500RL7 ±0.5°C Accurate PWM Temperature Sensor SOT-23-5
TMP35GT9Z Voltage Output Temperature Sensors TO-92
TMP36FSZ Voltage Output Temperature Sensors SO-8
TMP36GRTZ-REEL7 Voltage Output Temperature Sensors SOT-23-5
TMP37 Low Voltage Temperature Sensor Vo=500 TO-92
EXAR
LP2950ACN-L-3-3 100mA Low Dropout Voltage Regulators TO−92LP2950ACN-L-5-0 100mA Low Dropout Voltage Regulators TO−92
SP34063 1.5A Boost/Buck/Inverting Regulator
SP6201EM5-L-1-5 Micropower 200mA CMOS LDO Regulators SOT-23-5
SP6201EM5-L-2-85 Micropower 200mA CMOS LDO Regulators SOT-23-5
SP6201EM5-L-3-0 Micropower 200mA CMOS LDO Regulators SOT-23-5
SP6201EM5-L-3-3 Micropower 200mA CMOS LDO Regulators SOT-23-5
SP6201EM5-L-5-0 Micropower 200mA CMOS LDO Regulators SOT-23-5
SP6203EM5-L-2-5 Very Low Dropout Low Noise 300mA CMOS LDO Regulators SOT-23-5
SP6203EM5-L-2-8 Very Low Dropout Low Noise 300mA CMOS LDO Regulators SOT-23-5
SP6203EM5-L-3-0 Very Low Dropout Low Noise 300mA CMOS LDO Regulators SOT-23-5
SP6205EM5-L-1-8 Very Low Dropout Low Noise 500mA CMOS LDO Regulators SOT-23-5
SP6205EM5-L-2-8 Very Low Dropout Low Noise 300mA CMOS LDO Regulators SOT-23-5
SP6205EM5-L-3-0 Very Low Dropout Low Noise 500mA CMOS LDO Regulators SOT-23-5
SP6260AEK-L/TR 200mA RF Ultra Low Dropout Regulator (LDO) SOT-23-5
SP6260BEK-L/TR Micropower 200mA CMOS LDO Regulators SOT-23-5
SP6260CEK-L/TR Micropower 200mA CMOS LDO Regulators SOT-23-5
SP6260GEK-L/TR Micropower 200mA CMOS LDO Regulators SOT-23-5
SP6650EU-L High Efficiency 600mA Synchronous Buck Regulator
SP6660EN-L 200mA Charge Pump Inverter or Doubler NSOIC8
SP6660EP-L 200mA Charge Pump Inverter or Doubler PDIP8
SP6686ER-L 400mA Buck/Boost Charge Pump LED Driver DFN10
SP6699EK-L/TR Step-up White LED Converter SOT-23-6
SP7650ER-L Wide Input Voltage Range 3A, 300kHz, Buck Regulator
SP7656EN2-L 3A 600kHz Step-Down DC/DC Voltage Regulator NSOIC8
SPX1117M3-L-3-3 800mA Low Dropout Voltage Regulator
SPX1117M3-L-5-0 800mA Low Dropout Voltage Regulator TO263
SPX1521M3-L-3-3 300mA Low Dropout Voltage Regulator
SPX1521M3-L-5-0 300mA Low Dropout Voltage Regulator
SPX1587AT-L-3-3 3A Low Dropout Voltage Regulator TO-263-3
SPX1587T-L-5-0 3A Low Dropout Voltage Regulator TO-263-3
SPX1587U-L-3-3 3A Low Dropout Voltage Regulator TO-220-3
SPX1587U-L-5-0 =6 3A Low Dropout Voltage Regulator TO-220-3
SPX29152U5-L 1.5A Adjustable Low Dropout Voltage Regulator TO-220-3
SPX29302U5-L 3A Adjustable High Current, Low Dropout Voltage Regulator TO-220-5
SPX2940T-L-5-0/TR 1A Low Dropout Voltage Regulator TO-263
SPX2945M3-L-5-0 400mA Vin MAX 30V Low Dropout Voltage Regulator with Shutdown SOT-223-3
SPX29502U5-L 5A Adjustable Low Dropout Voltage Regulator TO-220-5
SPX2954M3-L-3-3
SPX3819M5-L-1-8 500mA, Low-Noise LDO Voltage Regulator
SPX3819M5-L-2-5 500mA, Low-Noise LDO Voltage Regulator
SPX3819M5-L-3-0 500mA, Low-Noise LDO Voltage Regulator
SPX3819M5-L-3-3 500mA, Low-Noise LDO Voltage Regulator
SPX3819M5-L-5-0 500mA, Low-Noise LDO Voltage Regulator SOT-23-5
SPX3940AM3-L-3-3 1.0A Low Dropout Voltage Regulator SOT-223-3
SPX3940AM3-L-5-0 1.0A Low Dropout Voltage Regulator SOT-223-3
SPX3940AT-L-3-3 1.0A Low Dropout Voltage Regulator TO-263-3
SPX3940AT-L-5-0 1.0A Low Dropout Voltage Regulator TO-263-3
SPX5205M5-L-2-5 150mA, Low-Noise LDO Voltage Regulator SOT-23-5
SPX5205M5-L-3-0 150mA, Low-Noise LDO Voltage Regulato
SPX5205M5-L-3-3 150mA, Low-Noise LDO Voltage Regulato
SPX5205M5-L-5-0 150mA, Low-Noise LDO Voltage Regulato
XR8051AST5X Single, Low Cost, High Speed Rail-to-Rail Amplifier TSOT5
XR8052AMP8X Dual, Low Cost, High Speed Rail-to-Rail Amplifier MSOP-8
XR8052ASO8X Dual, Low Cost, High Speed Rail-to-Rail Amplifier NSOIC8
XR8054ASO14X Quad, Low Cost, High Speed Rail-to-Rail Amplifier NSOIC14
XR8054ATP14X Quad, Low Cost, High Speed Rail-to-Rail Amplifier TSSOP14
XRP29302ETB-L =6 3A Adjustable Low Dropout Voltage Regulator TO-263
XRP7659ISTR-F 1.5A 18V 1.4MHz Non Synchronous Step-Down Regulator SOT-23-6
А что вы хотите?
