Помогите С Ibutton(touch Memory)
Закрыто
Сообщение opv88 »
Нужно считать серийный номер с ibutton (ds1990A - стандартная таблетка, только серийный номер). Микроконтроллер AT89C2051.
Пользуюсь след. кодом от Dallas:
TOUCHRESET:
PUSH B ; Save the B register.
PUSH ACC ; Save the accumulator.
MOV A, #4 ; Load outer loop variable.
CLR DATA_BIT ; Start the reset pulse.
MOV B, #221 ; 2. Set time interval.
DJNZ B, $ ; 442. Wait with Data low.
SETB DATA_BIT ; 1. Release Data line.
MOV B, #6 ; 2. Set time interval.
CLR C ; 1. Clear presence flag.
WAITLOW:
JB DATA_BIT, WH ; Exit loop if line high.
DJNZ B, WAITLOW ; Hang around for 3360
DJNZ ACC, WAITLOW ; us if line is low.
SJMP SHORT ; Line could not go high.
WH:
MOV B, #111 ; Delay for presence detect.
HL:
ORL C, /DATA_BIT ; 222. Catch presence pulse.
DJNZ B, HL ; 222. Wait with Data high.
SHORT:
POP ACC ; Restore accumulator.
POP B ; Restore B register.
JMP DATA_IN
RET ; Return.
; Procedures Data_In and TouchByte
; The procedure TouchByte sends the byte in the accumulator
; to the Touch Memory, and the procedure Data_In returns a
; byte from the Touch Memory in the accumulator. Note that
; the NOPs in the following code are intended to give the
; optimum performance when using a 11.0592 MHz crystal.
; Their purpose is to make the pulses as long as
; possible consistent with the Touch Memory timing
; constraints. When using other crystal frequencies,
; the delays in this code should be adjusted to conform
; to the timing requirements of the Touch Memory.
BIT_IO:
RRC A ; Get bit to send in carry.
CALL TOUCHBIT ; Send bit.
RLC A ; Collect returned bit in ACC.
RET ; Return to caller.
DATA_IN:
MOV A, #033H ; Initialize for input.
TOUCHBYTE:
MOV B, #8 ; Setup for 8 bits.
BIT_LOOP:
RRC A ; 1. Get bit in carry.
CALL TOUCHBIT ; 2. Send bit.
DJNZ B, BIT_LOOP ; 2. Get next bit.
RRC A ; Get final bit in ACC.
TOUCHBIT:
CLR DATA_BIT ; 1. Start the time slot.
NOP ; 1. Delay to make sure
NOP ; 1. that the Touch Memory
NOP ; 1. sees a low for at
NOP ; 1. least 1 microsecond.
MOV DATA_BIT, C ; 2. Send out the data bit.
NOP ; 1. Delay to give the
NOP ; 1. data returned from
NOP ; 1. the Touch Memory
NOP ; 1. time to settle
NOP ; 1. before reading
NOP ; 1. the bit.
MOV C, DATA_BIT ; 1. Sample input data bit.
PUSH B ; 2. Save B register.
MOV B, #12H ; 2. Delay until the end
DJNZ B, $ ; 36. of the time slot.
SETB DATA_BIT ; Terminate time slot.
Сигнал RESET от микроконтроллера работает прекрасно, получаю в ответ PRESENCE от таблетки, посылаю команду считывания (33H) (вызываю процедуру DATA_IN), команда успешно передается, но никаких данных с таблетки не приходит (требуемых 64 бит серийного номера), таблетка никаких импульсов не выдает. Моделирую все это в протеусе, получаю следующие осциллограммы (файлы вложены, весь процесс считывания и команда 33H отдельно увеличен масштаб). Помогите пожалуйста, кто знаком с ibutton.
Полный цикл считывания (что получилось, 64 битов нет)
(49.17 КБ) 463 скачивания
Увеличенная осциллограмма кода команды
(48.48 КБ) 502 скачивания
Сообщение nictrace »
и в протеусе не отвечает таблетка? :shock:
Мои верные друзья - АМD и AVR
LM317 - атцтой, LM2576ADJ - форева! :)
Сообщение Pooher »
Научить нельзя, можно научиться. Пифагор.
Вставь недостающие буквы в слово *у*ня. Если у тебя получилось слово кухня, значит ты интеллигентный человек.
эти исходники - под AVR
Сообщение Pooher »
Переделать не долго.
Закрыто
