Не прошивается usbasp через AVRISP mkII
Сообщение tutvam »
Прошу помочь разобраться почему не прошивается usbasp через AVRISP mkII
Приобрел usbasp.ю индикатор горит красным цветов, пишет необходимо апгрейд софта.
avrdude -p m8 -c usbasp -P usb -v -U flash:r:/tmp/flash_dump.hex:i
avrdude: Version 6.3
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/home/petr/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : usbasp
AVR Part : ATmega8
Chip Erase delay : 10000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 4 20 128 0 no 512 4 0 9000 9000 0xff 0xff
flash 33 10 64 0 yes 8192 64 128 4500 4500 0xff 0x00
lfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
lock 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : usbasp
Description : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: error: program enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
Подключил к AVRISP mkII - usbasp
dmesg
usb 1-1.1: new full-speed USB device number 49 using ehci-pci
usb 1-1.1: New USB device found, idVendor=03eb, idProduct=2104, bcdDevice= 2.00
usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.1: Product: AVRISP mkII
usb 1-1.1: Manufacturer: ATMEL
usb 1-1.1: SerialNumber: 000200055103
#lsusb
Bus 001 Device 049: ID 03eb:2104 Atmel Corp. AVR ISP mkII
Примеры брал отсюда
https://ph0en1x.net/77-avrdude-full-how ... linux.html
Тест не проходит связки не проходит.
Что я делаю не так?
# avrdude -c avrisp2 -p m8
avrdude: stk500v2_command(): command failed
avrdude: stk500v2_program_enable(): bad AVRISPmkII connection status: Target not detected
this check.
avrdude done. Thank you.
avrdude -c avrisp2 -p m8 -U -P usb flash:w:1/usbasp.atmega8.2011-05-28.hex -v
Using Port : usb
Using Programmer : avrisp2
avrdude: usbdev_open(): Found AVRISP mkII, serno: 000200055103
AVR Part : ATmega8
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Programmer Type : STK500V2
Description : Atmel AVR ISP mkII
Programmer Model: AVRISP mkII
Hardware Version: 1
Firmware Version Master : 1.17
Vtarget : 0.0 V
SCK period : 8.00 us
this check.
Сообщение mickbell »
Насколько я ни хрена не помню, надо там на плате что-то с чем-то замкнуть на время программирования. К сожалению, я не сохранил ссылок на тот сайт. Сам успешно справился, правда, не авр-дюдей, а через среду AVR Studio. Да и AVRISP у меня не настоящий, клон оного.
И хрюкотали зелюки,
Как мюмзики в мове.
На каждый РКН
Найдётся VPN.
Сообщение NStorm »
JP2 на USBASP замкните на время прошивки, это ж перемычка для программирования.
Сообщение tutvam »
NStorm писал(а):JP2 на USBASP замкните на время прошивки, это ж перемычка для программирования.
В данном случае здесь перемычка для программирования JP1, JP21 выбор питания 3.3V или 5 V. JP3 понижение частоты.
Сообщение NStorm »
В оригинальном USBASP на программирование именно JP2 сделано.
Китайцы вроде раньше также и подписывали... может поменялось что. Покажите фото вашего аспа поближе, сверху и в нормальном разрешении.
Сообщение tutvam »
Да, конечно.
Сообщение NStorm »
Кхм. Вроде всё верно. Может на 5V надо соединить перемычку на JP21?
Сообщение tutvam »
Смущает, что
Vtarget : 0.0 V
Когда поставил перемычку, получул ошибку.
И красный индикатор начал моргать на AVRISPmkII
avrdude: stk500v2_program_enable(): bad AVRISPmkII connection status: RST fail, Target not detected
this check.
Сообщение NStorm »
tutvam, всё ясно, оказывается AVRISP mkII не умеет сам подавать питание на целевой МК. По Vcc он только определяет питание, для выставления нужного уровня на выходах. Подавайте на Vcc+GND USBAsp'а питание 5В и прошьется всё, в USB воткнуть наверное не получится - D+ / D- на линии могут мешать прошивке. Это не точно, но лучше чисто питание отдельно подать.
Сообщение tutvam »
Попробую, а пока так.
Как-то раз проскочило, больше не повторялось
~/usbasp/1$ avrdude -c avrispmkII -p m8 -U -P usb flash:w:1/usbasp.atmega8.2011-05-28.hex -v
Using Port : usb
Using Programmer : avrispmkII
avrdude: usbdev_send(): wrote 0 out of 1 bytes, err = could not detach kernel driver from interface 0: No data available
avrdude: stk500_send_mk2(): failed to send command to serial port
avrdude: stk500v2_getsync(): error communicating with programmer: (0)
AVR Part : ATmega8
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
avrdude: usbdev_send(): wrote 0 out of 2 bytes, err = could not detach kernel driver from interface 0: No data available
Hardware Version: 0
Firmware Version Master : 0.00
Vtarget : 20.7 V
SCK period : 0.00 us
avrdude: usbdev_send(): wrote 0 out of 12 bytes, err = could not detach kernel driver from interface 0: No data available
avrdude: AVR device initialized and ready to accept instructions
Reading | | 0% 0.00savrdude: usbdev_send(): wrote 0 out of 6 bytes, err = could not detach kernel driver from interface 0: No data available
Reading | ################# | 33% 0.01savrdude: usbdev_send(): wrote 0 out of 6 bytes, err = could not detach kernel driver from interface 0: No data available
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x303030
avrdude: Expected signature for ATmega8 is 1E 93 07
Double check chip, or use -F to override this check.
avrdude: usbdev_send(): wrote 0 out of 3 bytes, err = could not detach kernel driver from interface 0: No data available
Сообщение NStorm »
Попробуйте от root'а запустить (через sudo).
Если не поможет - кабель другой попробовать или на другом ПК.
Добавлено after 2 minutes 12 seconds:
Команда кстати правильно вот так должна писаться:
sudo avrdude -c avrispmkII -p m8 -P usb -U flash:w:1/usbasp.atmega8.2011-05-28.hex -v
Т.е. после -U должна следовать инструкция для прошивки.
Сообщение tutvam »
Благодарю, NStorm!
Похоже начало получаться :)
Я из под рута выполнял, с питанием да , промахнулся и с синтаксисом.
Но индикатор после отключения JP1 и от avrispmkII, все же горит красным. Может у него и другого нетю
User configuration file is "/root/.avrduderc"
Using Port : usb
AVR Part : ATmega8
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 1
Vtarget : 5.1 V
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9307 (probably m8)
avrdude: safemode: hfuse reads as D9
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "1/usbasp.atmega8.2011-05-28.hex"
avrdude: input file 1/usbasp.atmega8.2011-05-28.hex auto detected as Intel Hex
avrdude: writing flash (4700 bytes):
Writing | ################################################## | 100% 1.76s
avrdude: 4700 bytes of flash written
avrdude: verifying flash memory against 1/usbasp.atmega8.2011-05-28.hex:
avrdude: load data flash data from input file 1/usbasp.atmega8.2011-05-28.hex:
avrdude: input file 1/usbasp.atmega8.2011-05-28.hex contains 4700 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 1.41s
avrdude: verifying ...
avrdude: 4700 bytes of flash verified
avrdude: safemode: Fuses OK (E:FF, H:D9, L:EF)
Сообщение NStorm »
Вроде всё прошилось у вас нормально, судя по логу уже без проблем. У вас 2 обычных LED стоит там, может красный всегда и должен гореть, просто питание показывает? Вы попробуйте уже через USBAsp прошить что-нибудь.
Сообщение tutvam »
Вполне возможно, питание показывает.
Пытаюсь поверить связь с ATMega-32A-AU, пока не получается, может опять что-то не то делаю, микросхема на плате.
avrdude -c usbasp -p m32 -P usb
this check.
Сообщение NStorm »
А МК целевой случаем не прошит уже? Может там фьюзами отключено что-то, что мешает прошивке. И подключение проверьте, каждый провод, распиновку.
Сообщение tutvam »
МК новый был, с фьэюзами дело не имел пока, подключение проверял , 5V на плату с usbasp подается.
Сообщение NStorm »
"Новый" - случаем не с AliExpress? Там сплошь и рядом фуфло БУшное и бракованное продают, имейте в виду. В 1ом посте кстати у вас, где попытка прошить atmega8 тоже проблема не в прошивке была в общем-то, а в том, что целевой МК не виделся.
Как подключаете? Плата с мегой32 у вас самодельная? Какие пины выводили, как подключаете? Надо MOSI->MISO, MISO->MOSI, SCK->SCK, RESET->RESET и питание.
Сообщение tutvam »
понизил частоту на программаторе JP3, пошло!
avrdude -c usbasp -p m32 -U lfuse:w:0xc3:m -U hfuse:w:0x99:m
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9502 (probably m32)
avrdude: reading input file "0xc3"
avrdude: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xc3:
avrdude: load data lfuse data from input file 0xc3:
avrdude: input file 0xc3 contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "0x99"
avrdude: writing hfuse (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0x99:
avrdude: load data hfuse data from input file 0x99:
avrdude: input file 0x99 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: safemode: Fuses OK (E:FF, H:99, L:C3)
Теперь другой вопрос как выставить эти параметры в avr8 Burn-O-Mat?
или через avrdude, нужно залить eeprom и flash
Сообщение NStorm »
С новой прошивкой кстати скорость можно ключиком -B выставлять, не меняя перемычку.
В смысле выставить фьюзы так? Или всё-таки flash & eeprom зашить?
Если фьюзы, то почти также, как выше для меги32:
avrdude -c usbasp -p m8 -B 10 -U lfuse:w:0x62:m -U hfuse:w:0xDF:m
Если флэш и EEPROM:
avrdude -c usbasp -p m8 -B 10 -U flash:w:file.hex -U eeprom:w:file.eep
Толкьо имена файлов правильные напишите.
Сообщение tutvam »
не ту картинку скинул, но не важно а extended fuse куда?
Вернуться в «AVR»
