Ошибка recipe for target 'main.o' failed Atmel Studio7
Сообщение Land »
Не собирается проект. Ошибку recipe for target 'main.o' failed. Makefile выглядит так:
Спойлер################################################################################
# Automatically-generated file. Do not edit!
SHELL := cmd.exe
RM := rm -rf
USER_OBJS :=
LIBS :=
PROJ :=
O_SRCS :=
C_SRCS :=
S_SRCS :=
S_UPPER_SRCS :=
OBJ_SRCS :=
ASM_SRCS :=
PREPROCESSING_SRCS :=
OBJS :=
OBJS_AS_ARGS :=
C_DEPS :=
C_DEPS_AS_ARGS :=
EXECUTABLES :=
OUTPUT_FILE_PATH :=
OUTPUT_FILE_PATH_AS_ARGS :=
AVR_APP_PATH :=$$$AVR_APP_PATH$$$
QUOTE := "
ADDITIONAL_DEPENDENCIES:=
OUTPUT_FILE_DEP:=
LIB_DEP:=
LINKER_SCRIPT_DEP:=
# Every subdirectory with source files must be described here
SUBDIRS :=
# Add inputs and outputs from these tool invocations to the build variables
C_SRCS += \
../main.c \
../MicroMenu.c
PREPROCESSING_SRCS +=
ASM_SRCS +=
OBJS += \
main.o \
MicroMenu.o
OBJS_AS_ARGS += \
main.o \
MicroMenu.o
C_DEPS += \
main.d \
MicroMenu.d
C_DEPS_AS_ARGS += \
main.d \
MicroMenu.d
OUTPUT_FILE_PATH +=Menu.elf
OUTPUT_FILE_PATH_AS_ARGS +=Menu.elf
OUTPUT_FILE_DEP:= ./makedep.mk
LIB_DEP+=
LINKER_SCRIPT_DEP+=
# AVR32/GNU C Compiler
./main.o: .././main.c
@echo Building file: $<
@echo Invoking: AVR/GNU C Compiler : 5.4.0
$(QUOTE)C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe$(QUOTE) -x c -funsigned-char -funsigned-bitfields -DDEBUG -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.6.364\include" -Og -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega88a -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.6.364\gcc\dev\atmega88a" -c -std=gnu99 -MD -MP -MF "$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -MT"$(@:%.o=%.o)" -o "$@" "$<"
@echo Finished building: $<
./MicroMenu.o: .././MicroMenu.c
# AVR32/GNU Preprocessing Assembler
# AVR32/GNU Assembler
ifneq ($(MAKECMDGOALS),clean)
ifneq ($(strip $(C_DEPS)),)
-include $(C_DEPS)
endif
endif
# All Target
all: $(OUTPUT_FILE_PATH) $(ADDITIONAL_DEPENDENCIES)
$(OUTPUT_FILE_PATH): $(OBJS) $(USER_OBJS) $(OUTPUT_FILE_DEP) $(LIB_DEP) $(LINKER_SCRIPT_DEP)
@echo Building target: $@
@echo Invoking: AVR/GNU Linker : 5.4.0
$(QUOTE)C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe$(QUOTE) -o$(OUTPUT_FILE_PATH_AS_ARGS) $(OBJS_AS_ARGS) $(USER_OBJS) $(LIBS) -Wl,-Map="Menu.map" -Wl,--start-group -Wl,-lm -Wl,--end-group -Wl,--gc-sections -mmcu=atmega88a -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.6.364\gcc\dev\atmega88a"
@echo Finished building target: $@
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objcopy.exe" -O ihex -R .eeprom -R .fuse -R .lock -R .signature -R .user_signatures "Menu.elf" "Menu.hex"
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objcopy.exe" -j .eeprom --set-section-flags=.eeprom=alloc,load --change-section-lma .eeprom=0 --no-change-warnings -O ihex "Menu.elf" "Menu.eep" || exit 0
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objdump.exe" -h -S "Menu.elf" > "Menu.lss"
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objcopy.exe" -O srec -R .eeprom -R .fuse -R .lock -R .signature -R .user_signatures "Menu.elf" "Menu.srec"
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-size.exe" "Menu.elf"
# Other Targets
clean:
-$(RM) $(OBJS_AS_ARGS) $(EXECUTABLES)
-$(RM) $(C_DEPS_AS_ARGS)
rm -rf "Menu.elf" "Menu.a" "Menu.hex" "Menu.lss" "Menu.eep" "Menu.map" "Menu.srec" "Menu.usersignatures"
Если кто-то может разъяснить, в чем может быть причина -- буду очень благодарен.
Сообщение Land »
Собственно проблема оказалась в подключении #include. Тема закрыта.
Вернуться в «AVR»
