TWI читать не хочет!!! 24C64
Закрыто
RadioLab
Сообщение RadioLab »
вот блин засада целый день разбираюсь никак не пойму в чём проблемма
вот так пишу
uint8_t EEWriteByte(uint16_t address,uint8_t data)
	do
		//Put Start Condition on TWI Bus
		TWCR=(1<<TWINT)|(1<<TWSTA)|(1<<TWEN);
		//Poll Till Done
		while(!(TWCR & (1<<TWINT)));
		//Check status
		if((TWSR & 0xF8) != 0x08)
			return FALSE;
		//Now write SLA+W
		//EEPROM @ 00h
		TWDR=TWI_SLA_24CXX;
		//Initiate Transfer
		TWCR=(1<<TWINT)|(1<<TWEN);
		//Poll Till Done
	}while((TWSR & 0xF8) != 0x18);
	//Now write ADDRH
	TWDR=(address>>8);
	//Initiate Transfer
	//Poll Till Done
	//Check status
	if((TWSR & 0xF8) != 0x28)
		return FALSE;
	//Now write ADDRL
	TWDR=(address);
	//Initiate Transfer
	//Poll Till Done
	//Check status
		return FALSE;
	//Now write DATA
	TWDR=(data);
	//Initiate Transfer
	//Poll Till Done
	//Check status
		return FALSE;
	//Put Stop Condition on bus
	TWCR=(1<<TWINT)|(1<<TWEN)|(1<<TWSTO);
	//Wait for STOP to finish
//	while(TWCR & (1<<TWSTO));
	//Wait untill Writing is complete
	_delay_ms(12);
	return TRUE;
вот так читаю
uint8_t EEReadByte(uint16_t address)
	uint8_t data;
	//Initiate a Dummy Write Sequence to start Random Read
	do
		//Poll Till Done
		//Check status
			return FALSE;
		//Now write SLA+W
		//EEPROM @ 00h
		TWDR=TWI_SLA_24CXX;
		//Initiate Transfer
		//Poll Till Done
	//Now write ADDRH
	TWDR=(address>>8);
	//Initiate Transfer
	//Poll Till Done
	//Check status
		return FALSE;
	//Now write ADDRL
	TWDR=(address);
	//Initiate Transfer
	//Poll Till Done
	//Check status
		return FALSE;
	//*************************DUMMY WRITE SEQUENCE END **********************
	//Poll Till Done
	//Check status
	if((TWSR & 0xF8) != 0x10)
		return FALSE;
	//Now write SLA+R
	//EEPROM @ 00h
	TWDR=TWI_SLA_24CXX+1;
	//Initiate Transfer
	//Poll Till Done
	//Check status
	if((TWSR & 0xF8) != 0x40)
		return FALSE;
	//Now enable Reception of data by clearing TWINT
	//Wait till done
	//Check status
	if((TWSR & 0xF8) != 0x58)
		return FALSE;
	//Read the data
	data=TWDR;
	//Return TRUE
	return data;
инициализация порта TWI
 	TWBR = 5;
	TWSR &= (~((1<<TWPS1)|(1<<TWPS0)));
тело программы
Init EEPROM
 uint8_t i;
EEWriteByte(1,5);
i=EEReadByte(1);
EEWriteByte(2,i);
записать получается а считать нет .
зависает на
//Check status
		return FALSE;
в чем пробмемма?
RadioLab
Re: TWI читать не хочет!!! 24C64
проверяю в протеусе .
ну уж это-то там должно работать!!!
extremisto
Сообщение extremisto »
Источник кода забыл указать:
http://avrlab.com/node/84
Закрыто
