To Igor_67 вы по предоставленным Вам ссылкам переходить пробовали и хотябы обращять внимание на ссылки типа "Download source code in Bas" и посмотреть что под ней???
вот по первой сылке:
'------------------- AN 11 -----------------------------
' Copyright 1999 MCS Electronics
' CLOCK.BAS
'This AN shows how to use the PCF8583 I2C clock device
'The PCF8583 is a PHILIPS device. Look at the datasheet for more details
'I used a prototype board from dontronics with the hardware
'simulator to test the program
'declare used subs
Declare Sub Settime(s As Byte , M As Byte , H As Byte , D As Byte , Month As Byte)
Declare Sub Gettime
'declare vairables
Dim S As Byte , M As Byte , H As Byte , D As Byte , Month As Byte
Dim Wm As Byte , Yd As Byte
Call Settime(0 , 0 , 0 , 29 , 11) 'set time
Do
Call Gettime 'get time
Loop
End
Sub Gettime
Dim Dum As Byte
I2cstart 'generate start
I2cwbyte &HA0 'write addres of PCF8583
I2cwbyte 2 'select second register
I2cstart 'generate repeated start
I2cwbyte &HA1 'write address for reading info
I2crbyte S , Ack 'read seconds
I2crbyte M , Ack 'read minuts
I2crbyte H , Ack 'read hours
I2crbyte Yd , Ack 'read year and days
I2crbyte Wm , Nack 'read weekday and month
I2cstop 'generate stop
Print "Time " ; Print Bcd(h) ; ":" ; Bcd(m) ; ":" ; Bcd(s)
Print "Day : " ; Bcd(yd) ; " Month : " ; Bcd(wm)
Rem You Could Also Use The Lcd Statement For Displaying The
Rem Time On The Lcd Display
End Sub
'values are stored as BCD values so convert the values first
S = Makebcd(s) 'seconds
M = Makebcd(m) 'minuts
H = Makebcd(h) 'hours
D = Makebcd(d) 'days
Month = Makebcd(month) 'months
I2cwbyte &HA0 'write address
I2cwbyte 0 'select control register
I2cwbyte 8 'set year and day bit for masking
I2cwbyte &HA0 'write mode
I2cwbyte 2 'select seconds Register
I2cwbyte S 'write seconds
I2cwbyte M 'write minuts
I2cwbyte H 'write hours
I2cwbyte D 'write days
I2cwbyte Month 'write months
I2cstop
End Sub
по моему это именно то что вы ищите...
