This program was produced by the
CodeWizardAVR V1.25.7 beta 5 Standard
Automatic Program Generator
© Copyright 1998-2007 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date : 01.05.2011
Author : F4CG
Company : F4CG
Comments:
Chip type : ATmega8
Program type : Application
Clock frequency : 8,000000 MHz
Memory model : Small
External SRAM size : 0
Data Stack size : 256
#include <mega8.h>
#include <delay.h>
//#asm
//.equ_w1_port=0x15
//.equ_w1_bit=0
//#endasm
#include <1wire.h>
unsigned char led_table[]=
0x3f, //0
0x06, //1
0x5b, //2
0x4f, //3
0x66, //4
0x6d, //5
0x7d, //6
0x07, //7
0x7f, //8
0x6f //9
unsigned char led_seg=1; //номер сегмента индикатора
unsigned char key_flags=0;
int led_num;
int t_temp=0;
void showSegment(void) {
unsigned char d;
d=t_temp;
if (led_seg==1) PORTD=led_table[d];
PORTB=1<<led_seg;
if (led_seg==2) PORTD=led_table[d];
void incTemp (void) {
if (t_temp<100) t_temp++;
void decTemp (void) {
if (t_temp>-1) t_temp--;
void keyStatus(void) {
if (PINC.0==0&key_flags==0) {key_flags=1; incTemp();}
if (PINC.1==0&key_flags==0) {key_flags=2; decTemp();}
// Timer 0 overflow interrupt service routine
interrupt [TIM0_OVF] void timer0_ovf_isr(void)
// Place your code here
keyStatus();
showSegment();
// Declare your global variables here
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port B initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTB=0x00;
DDRB=0x00;
// Port C initialization
// Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
// State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=0
PORTC=0xff;
DDRC=0xfF;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
TCCR0=0x00;
TCNT0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// Mode: Normal top=FFh
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
MCUCR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x01;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
// Global enable interrupts
#asm("sei")
while (1)
DDRD=0xff;
DDRB=0x1e;
DDRC=0x08;
PORTC=0x03;
TCCR0=0x02;
TIMSK=0x01;
вот код переделывал...с программы и он не работает((
