Ветка микроконтроллеры и плис закрыта (уж не знаю что тут без меня произошло).
не пашет openocd c j-link
дебаг
кто сталкивался ? заранее спасибо
me@Victoria:~/workspace/test2$ openocd -f openocd.cfg
Open On-Chip Debugger 0.6.1 (2012-12-06-17:15)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.sourceforge.net/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'jtag'
adapter speed: 1000 kHz
adapter_nsrst_delay: 100
jtag_ntrst_delay: 100
cortex_m3 reset_config sysresetreq
Info : J-Link initialization started / target CPU reset initiated
Info : J-Link ARM-OB STM32 compiled Dec 15 2010 11:30:03
Info : J-Link caps 0x88ea5833
Info : J-Link hw version 70000
Info : J-Link hw type J-Link
Info : J-Link max mem block 10328
Info : J-Link configuration
Info : USB-Address: 0xff
Info : Kickstart power on JTAG-pin 19: 0xd1e22e00
Info : Vref = 3.300 TCK = 1 TDI = 0 TDO = 1 TMS = 0 SRST = 0 TRST = 0
Info : J-Link JTAG Interface ready
Error: usb_bulk_read failed (requested=1, result=0)
Error: jlink_tap_execute, wrong result -107 (expected 1)
Info : clock speed 1000 kHz
in procedure 'transport'
in procedure 'init'
Debug: 219 312 libusb1_common.c:140 jtag_libusb_get_endpoints(): usb ep in 81
Debug: 220 312 libusb1_common.c:140 jtag_libusb_get_endpoints(): usb ep out 02
Info : 221 312 jlink.c:516 jlink_init(): J-Link initialization started / target CPU reset initiated
Info : 222 322 jlink.c:892 jlink_get_version_info(): J-Link ARM-OB STM32 compiled Dec 15 2010 11:30:03
Info : 223 326 jlink.c:905 jlink_get_version_info(): J-Link caps 0x88ea5833
Info : 224 330 jlink.c:923 jlink_get_version_info(): J-Link hw version 70000
Info : 225 330 jlink.c:928 jlink_get_version_info(): J-Link hw type J-Link
Info : 226 334 jlink.c:942 jlink_get_version_info(): J-Link max mem block 10328
Info : 227 340 jlink.c:785 jlink_config_dump(): J-Link configuration
Info : 228 340 jlink.c:744 jlink_config_usb_address_dump(): USB-Address: 0xff
Info : 229 340 jlink.c:753 jlink_config_kickstart_dump(): Kickstart power on JTAG-pin 19: 0xd1e22e00
Info : 230 344 jlink.c:712 jlink_get_status(): Vref = 3.300 TCK = 1 TDI = 0 TDO = 1 TMS = 0 SRST = 0 TRST = 0
Info : 231 352 jlink.c:539 jlink_init(): J-Link JTAG Interface ready
Debug: 232 352 jlink.c:667 jlink_reset(): trst: 0, srst: 0
Error: 233 362 jlink.c:1548 jlink_usb_message(): usb_bulk_read failed (requested=1, result=0)
Error: 234 362 jlink.c:1431 jlink_tap_execute(): jlink_tap_execute, wrong result -107 (expected 1)
Debug: 235 362 core.c:1592 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 236 362 core.c:1595 adapter_khz_to_speed(): have interface set up
Debug: 237 364 core.c:1592 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 238 364 core.c:1595 adapter_khz_to_speed(): have interface set up
Info : 239 364 core.c:1399 adapter_init(): clock speed 1000 kHz
Debug: 240 364 openocd.c:132 handle_init_command(): Debug Adapter init complete
Debug: 241 364 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_transport init
Debug: 242 364 command.c:145 script_debug(): command - ocd_transport ocd_transport init
Debug: 244 364 transport.c:240 handle_transport_init(): handle_transport_init
Debug: 245 364 jlink.c:667 jlink_reset(): trst: 0, srst: 0
Debug: 246 368 core.c:719 jtag_add_reset(): SRST line released
Debug: 247 368 core.c:743 jtag_add_reset(): TRST line released
Debug: 248 368 core.c:323 jtag_call_event_callbacks(): jtag event: TAP reset
Debug: 250 571 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_jtag arp_init
Debug: 251 571 command.c:145 script_debug(): command - ocd_jtag ocd_jtag arp_init
Debug: 252 571 core.c:1412 jtag_init_inner(): Init JTAG chain
Debug: 253 571 core.c:323 jtag_call_event_callbacks(): jtag event: TAP reset
Error: 254 573 jlink.c:1548 jlink_usb_message(): usb_bulk_read failed (requested=1, result=0)
Error: 255 573 jlink.c:1431 jlink_tap_execute(): jlink_tap_execute, wrong result -107 (expected 1)
Debug: 256 573 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_jtag arp_init-reset
Debug: 257 573 command.c:145 script_debug(): command - ocd_jtag ocd_jtag arp_init-reset
Debug: 258 573 core.c:1520 jtag_init_reset(): Initializing with hard TRST+SRST reset
Debug: 259 573 core.c:732 jtag_add_reset(): JTAG reset with TLR instead of TRST
Debug: 260 573 core.c:323 jtag_call_event_callbacks(): jtag event: TAP reset
Error: 261 577 jlink.c:1548 jlink_usb_message(): usb_bulk_read failed (requested=1, result=0)
Error: 262 577 jlink.c:1431 jlink_tap_execute(): jlink_tap_execute, wrong result -107 (expected 1)
Debug: 263 577 command.c:631 run_command(): Command failed with error code -4
User : 264 577 command.c:669 command_run_line(): in procedure 'transport'
Debug: 265 577 command.c:631 run_command(): Command failed with error code -4
User : 266 577 command.c:669 command_run_line(): in procedure 'init'
RETI ;рети-рети интеррапт, через шины данных тракт, через память, через порт, возвращайся в главный код
@hobbyelectronics
@hobbyelectronics
