komp@admin-dektop:~$ wine D://WorldOfTanks.exe
err:winediag:wined3d_dll_init The GLSL shader backend has been disabled. You get to keep all the pieces if it breaks.
fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0x32fce8 63 C) semi-stub
fixme:msvcp:locale__Locimp__Makexloc (0x32fce8 63 0x157bb8 (nil)) semi-stub
fixme:msvcp:locale__Locimp__Makewloc (0x32fce8 63 0x157bb8 (nil)) semi-stub
fixme:msvcp:locale__Locimp__Makeushloc (0x32fce8 63 0x157bb8 (nil)) semi-stub
fixme:win:EnumDisplayDevicesW ((null),0,0x1201bf8,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),1,0x1201bf8,0x00000000), stub!
fixme:thread:start_thread Started native thread 00000024
fixme:win:EnumDisplayDevicesW ((null),0,0x32e9a8,0x00000000), stub!
fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0x32e944 1 C) semi-stub
fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0x32e764 1 C) semi-stub
fixme:toolhelp:CreateToolhelp32Snapshot Unimplemented: heap list snapshot
fixme:toolhelp:Heap32ListFirst : stub
fixme:win:EnumDisplayDevicesW ((null),0,0x32e288,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),0,0x32e098,0x00000000), stub!
fixme:dxgi:dxgi_output_GetDesc iface 0x3d7d328, desc 0x32e628 stub!
fixme:ole:CoInitializeSecurity ((nil),-1,(nil),(nil),0,3,(nil),0,(nil)) - stub!
fixme:wbemprox:client_security_SetBlanket 0xf50db2a0, 0x3f38738, 10, 0, (null), 3, 3, (nil), 0x00000000
fixme:wbemprox:client_security_Release 0xf50db2a0
fixme:win:EnumDisplayDevicesW ((null),0,0x32dfa8,0x00000000), stub!
fixme:d3d:swapchain_init The application requested more than one back buffer, this is not properly supported.
Please configure the application to use double buffering (1 back buffer) if possible.
fixme:d3d:wined3d_swapchain_set_gamma_ramp Ignoring flags 0x1.
fixme:d3d9:d3d9_device_CheckDeviceState iface 0x3f38738, dst_window 0x20060 stub!
fixme:d3d:resource_check_usage Unhandled usage flags 0x8.
fixme:winediag:AUDDRV_GetAudioEndpoint Winepulse is not officially supported by the wine project
fixme:winediag:AUDDRV_GetAudioEndpoint For sound related feedback and support, please visit http://ubuntuforums.org/showthread.php?t=1960599
fixme:avrt:AvSetMmThreadCharacteristicsW (L"Audio",0x965e968): stub
fixme:msctf:ThreadMgrSource_AdviseSink (0x81c5dc8) Unhandled Sink: {71c6e74e-0f28-11d8-a82a-00065b84435c}
fixme:msvcrt:type_info_name_internal_method type_info_node parameter ignored
ImportError: No module named BWAutoImport
fixme:win:EnumDisplayDevicesW ((null),0,0x32bfa4,0x00000000), stub!
fixme:win:EnumDisplayDevicesW (L"\\\\.\\DISPLAY1",0,0x32c2ec,0x00000000), stub!
fixme:win:EnumDisplayDevicesW (L"\\\\.\\DISPLAY1",1,0x32c2ec,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),1,0x32bfa4,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),0,0x32ed18,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),0,0x32eb18,0x00000000), stub!
fixme:dxgi:dxgi_output_GetDesc iface 0xd20d2e8, desc 0x32f0b4 stub!
fixme:wbemprox:client_security_SetBlanket 0xf50db2a0, 0xd20f830, 10, 0, (null), 3, 3, (nil), 0x00000000
fixme:win:EnumDisplayDevicesW ((null),0,0x32ea38,0x00000000), stub!
fixme:imm:ImmReleaseContext (0x20060, 0x121cdcc8): stub
fixme:win:EnumDisplayDevicesW ((null),0,0x32e818,0x00000000), stub!
fixme:d3d9:Direct3DShaderValidatorCreate9 stub
fixme:thread:NtQueryInformationThread Cannot get kerneltime or usertime of other threads
fixme:win:RegisterDeviceNotificationA (hwnd=0x20070, filter=0x160be930,flags=0x00000000) returns a fake device notification handle!
err:winsock:interface_bind Failed to bind to interface, receiving broadcast packets will not work on socket 0600.
fixme:d3d:buffer_internal_preload Too many declaration changes or converting dynamic buffer, stopping converting
fixme:win:EnumDisplayDevicesW ((null),0,0x32cb94,0x00000000), stub!
fixme:win:EnumDisplayDevicesW (L"\\\\.\\DISPLAY1",0,0x32cedc,0x00000000), stub!
fixme:win:EnumDisplayDevicesW (L"\\\\.\\DISPLAY1",1,0x32cedc,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),1,0x32cb94,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),0,0x32cacc,0x00000000), stub!
fixme:win:EnumDisplayDevicesW (L"\\\\.\\DISPLAY1",0,0x32ce14,0x00000000), stub!
fixme:win:EnumDisplayDevicesW (L"\\\\.\\DISPLAY1",1,0x32ce14,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),1,0x32cacc,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),0,0x32e314,0x00000000), stub!
fixme:win:EnumDisplayDevicesW (L"\\\\.\\DISPLAY1",0,0x32e65c,0x00000000), stub!
fixme:win:EnumDisplayDevicesW (L"\\\\.\\DISPLAY1",1,0x32e65c,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),1,0x32e314,0x00000000), stub!
fixme:d3d_draw:draw_primitive Using software emulation because manual fog coordinates are provided.
fixme:msvcrt:MSVCRT__set_abort_behavior _WRITE_CALL_REPORTFAULT unhandled
fixme:msvcrt:__clean_type_info_names_internal (0x2751894) stub
err:ntdll:RtlpWaitForCriticalSection section 0x3b64760 "file.c: file_crit.crit" wait timed out in thread 0009, blocked by 0031, retrying (60 sec)
