Имеется код под ATtiny2313 (ШИМ генератор синуса).
.CSEG
.INCLUDE "2313def.inc"
.org 0
rjmp reset
.DEF Step=r30
.DEF Data=r0
.DEF SSREG=r23
.EQU Set_Tabl=16
.EQU Offset=Set_Tabl<<1
.EQU END_Tabl=Offset+196
.org OC1addr
rjmp TIM1_COMP
.org OVF1addr
rjmp TIM1_OvF
.CSEG
.org 16
SinTab:
.db 5,8,12,16,20,24,28,32,36,40,44,48,52,56,60,64
.db 67,71,75,79,83,86,90,94,98,101,105,109,112,116,119,123
.db 126,130,133,136,140,143,146,150,153,156,159,162,165,168,171,174
.db 177,180,183,185,188,191,193,196,198,201,203,206,208,210,212,214
.db 217,219,221,223,224,226,228,230,231,233,234,236,237,239,240,241
.db 242,243,244,245,246,247,248,249,249,250,250,251,251,252,252,252
.db 252,252,253,252,252,252,252,252,251,251,250,250,249,249,248,247
.db 246,245,244,243,242,241,240,239,237,236,234,233,231,230,228,226
.db 224,223,221,219,217,214,212,210,208,206,203,201,198,196,193,191
.db 188,185,183,180,177,174,171,168,165,162,159,156,153,150,146,143
.db 140,136,133,130,126,123,119,116,112,109,105,101,98,94,90,86
.db 83,79,75,71,67,64,60,56,52,48,44,40,36,32,28,24
.db 20,16,12,8,5,255,255,255,255,255,255,255,255,255,255,255
TIM1_COMP:
in SSREG, SREG
lpm
out OCR1AL, Data
out SREG, SSREG
reti
TIM1_OvF:
in SSREG, SREG
inc Step
out SREG, SSREG
reti
reset:
clr r31
ldi Step, Offset
ldi r20, 0xdf
out SPL, r20
ldi r20, 0xfc
out DDRB, r20
ldi r20, 0xf0
out PORTB, r20
ldi r20, 0x72
out DDRD, r20
ldi r20, 0x3f
out PORTD, r20
ldi r20, 0x00
out MCUCR, r20
ldi r20, 0x00
out GIFR, r20
ldi r20, 0x00
out OCR1AL, r20
ldi r20, 16
out OCR1AL, r20
ldi r20,0xC0
out TIMSK, r20
ldi r20, 0xB1
out TCCR1A, r20
ldi r20, 0x04
out PORTB, r20
WDR
ldi r20, 0x00
out WDTCR, r20
ldi r20, 0x01
out TCCR1B, r20
cbi PORTD, 6
cbi PORTB, 3
sei
m1:
cpi Step, END_Tabl
breq m2
rjmp m1
m2:
cli
wdr
ldi Step, Offset
sbic PORTB, 7
rjmp m3
sbis PORTB, 7
rjmp m4
m3:
cbi PORTB, 7
sei
rjmp m1
m4:
sbi PORTB, 7
sei
rjmp m1
Требуется перенести программу на МК ATtiny13
Примерная схема:
Критика принимается.
Скан программы из журнала с комментариями:
