"Перенести" код на другой МК
Сообщение korob »
Здравствуйте! Требуется помощь в небольшой правке, и переносе кода на другой МК. :oops:
Имеется код под ATtiny2313 (ШИМ генератор синуса).
.CSEG
 .INCLUDE "2313def.inc"
 .org 0
 		rjmp reset
 .DEF Step=r30
 .DEF Data=r0
 .DEF SSREG=r23
 .EQU Set_Tabl=16
 .EQU Offset=Set_Tabl<<1
 .EQU END_Tabl=Offset+196
 .org OC1addr
  	rjmp TIM1_COMP
 .org OVF1addr
  	rjmp TIM1_OvF
 .CSEG
 .org 16
 SinTab:
 .db 5,8,12,16,20,24,28,32,36,40,44,48,52,56,60,64
 .db 67,71,75,79,83,86,90,94,98,101,105,109,112,116,119,123
 .db 126,130,133,136,140,143,146,150,153,156,159,162,165,168,171,174
 .db 177,180,183,185,188,191,193,196,198,201,203,206,208,210,212,214
 .db 217,219,221,223,224,226,228,230,231,233,234,236,237,239,240,241
 .db 242,243,244,245,246,247,248,249,249,250,250,251,251,252,252,252
 .db 252,252,253,252,252,252,252,252,251,251,250,250,249,249,248,247
 .db 246,245,244,243,242,241,240,239,237,236,234,233,231,230,228,226
 .db 224,223,221,219,217,214,212,210,208,206,203,201,198,196,193,191
 .db 188,185,183,180,177,174,171,168,165,162,159,156,153,150,146,143
 .db 140,136,133,130,126,123,119,116,112,109,105,101,98,94,90,86
 .db 83,79,75,71,67,64,60,56,52,48,44,40,36,32,28,24
 .db 20,16,12,8,5,255,255,255,255,255,255,255,255,255,255,255
 TIM1_COMP:
 	in	SSREG, SREG
 	lpm
 	out	OCR1AL, Data
 	out	SREG, SSREG
 	reti
 TIM1_OvF:
 	in	SSREG, SREG
 	inc	Step
 	out	SREG, SSREG
 	reti
 reset:
 	clr	r31
 	ldi	Step, Offset
          ldi	r20, 0xdf
          out	SPL, r20
          ldi	r20, 0xfc
          out	DDRB, r20
          ldi	r20, 0xf0
          out	PORTB, r20
          ldi	r20, 0x72
          out	DDRD, r20
          ldi	r20, 0x3f
          out	PORTD, r20
          ldi	r20, 0x00
          out	MCUCR, r20
          ldi	r20, 0x00
          out	GIFR, r20
          ldi	r20, 0x00
          out	OCR1AL, r20
          ldi	r20, 16
          out	OCR1AL, r20
          ldi	r20,0xC0
          out	TIMSK, r20
          ldi	r20, 0xB1
          out	TCCR1A, r20
          ldi	r20, 0x04
          out	PORTB, r20
          WDR
          ldi	r20, 0x00
          out	WDTCR, r20
          ldi	r20, 0x01
          out	TCCR1B, r20
          cbi	PORTD, 6
          cbi	PORTB, 3
          sei
 m1:
          cpi	Step, END_Tabl
          breq	m2
          rjmp	m1
 m2:
          cli
          wdr
          ldi	Step, Offset
          sbic	PORTB, 7
          rjmp	m3
          sbis	PORTB, 7
          rjmp	m4
 m3:
          cbi	PORTB, 7
          sei
          rjmp 	m1
 m4:
          sbi	PORTB, 7
          sei
          rjmp	m1
Программа "генерирует" на PB3 ШИМ последовательность импульсов частой следования 20кГц., огибающая которых представляет полуволну синуса частотой 50Гц. (инвертор в общем :) ), а на PB7 меандр частотой 50Гц. (для переключения полярности полуволн, по сути плеч моста).
Требуется перенести программу на МК ATtiny13 :oops: , и попутно избавится от сигнала переключения плеч/полярности, а вместо него вывести второй канал ШИМ (ну или выводить один канал ШИМ с двух выводов по очереди :roll: ). Т.е. одну полуволну гоним с одного канала, а вторую с другого (первый в это время молчит), и т.д. Для чего всё это? Что бы максимально упростить схему. :oops:
Примерная схема: :roll:
Критика принимается. :) :roll:
Скан программы из журнала с комментариями: :roll:
Сообщение Z_h_e »
Какую Вы помощь то просите? Что Вы попробовали, что почитали, что не поняли и что не получилось?
З.Ы. Код не читабельный. Одни магические цифры сплошным текстом.
З.З.Ы. В тини13 нет таймера1.
Добро всегда побеждает зло. Поэтому кто победил - тот и добрый.
Сообщение korob »
Z_h_e писал(а):Что Вы попробовали, что почитали, что не поняли и что не получилось?
Честно? Ничего не пробовал :oops: , так как ничего в этом не понимаю (для меня это что китайское традиционное письмо :? ). :oops:
Z_h_e писал(а):Одни магические цифры сплошным текстом.
Ниже спецом разместил с комментариями. :roll: Или всё равно не информативно?
Z_h_e писал(а):В тини13 нет таймера1.
Получается что никак? Или есть другой способ?
Сообщение Z_h_e »
Почему никак, думаю можно. Просто это не изменить программу, а сделать новую.
Сообщение korob »
Хорошо, хрен с этим ATtiny13. :tea: "Хотели как лучше, а получилось как всегда".©
Тогда можно просто избавиться от сигнала переключения полуволн (меандр 50Гц.)? А то в исходной схеме потом нехилая схемка на логике один хрен разделяет на 4 ключа с вводом мёртвого времени. Здесь же применён драйвер с общим сигналом управления для верхнего и нижнего ключа с вводом мёртвого времени (заменяющий всю схему на логике из исходной схемы).
Сообщение Z_h_e »
Вы начертите временные диаграммы, что должно выходить с обоих каналов тиньки13. Понятно что импульсы разной ширины, но думать какой точно и сколько их и в какую фазу вряд ли кому просто так захочется. Программа то не сложная, если будет точная временная диаграмма, может кто и сваяет. Я иногда так делаю (закидываю полностью рабочий код в форум), когда скучно, а мне сейчас очень не скучно :).
Ну в крайнем случае, закинете кому-нибудь на коньяк из виноградников Челябинской области ;).
akl
Сообщение akl »
Посмотрел в студии исходник. Не стал бы рисковать подключать силовую часть. Делал аналогичную программу генерации синуса 60,(0)Гц (512 точек/период) для FLIP часов и управлением IR4426(IR4427, IR4428 тоже можно подключать)
Сообщение korob »
akl писал(а):Посмотрел в студии исходник. Не стал бы рисковать подключать силовую часть.
Дело в том, что на этом задающем генераторе сделано овер 10 девайсов (не конкретно по этой схеме, а взята лишь задающая часть), и все работают беспроблемно. :wink: Тут вопрос в упрощении аппаратной части (в которой как раз я могу что-то сделать), и соответственно в правке программной (где я откровенно слаб :cry: ) :).
Сообщение pyzhman »
У этой статьи есть автор. Напишите ему.
Docendo discimus
Сообщение korob »
Прошло более 10 лет, и как часто это бывает - автор не отвечает. :cry: Собственно если я бы был в силах что либо сделать - не обращался бы за помощью. :) :tea: :roll:
Сообщение Oxford »
Здесь бы подключить к решению STM32, убрать логику и рулить напрямую драйверами.
А почему выбран ATtiny13?
http://we.easyelectronics.ru/STM32/2-x- ... 030f4.html
http://catethysis.ru/stm32-tim-dma-pwm-sin/
Инженер R@D
Сообщение korob »
Oxford писал(а):А почему выбран ATtiny13?
korob писал(а):Что бы максимально упростить схему.
Сообщение Oxford »
В чем это упрощение, у вас же готовая схема есть, с готовым кодом. В чем логика?
Инженер R@D
Сообщение korob »
Oxford писал(а):В чем логика?
:oops:
Такую простую задачу с успехом выполнит и ATtiny13 (уверен на 100%, и нет необходимости применять ATtiny2313, STM32, Intel Core i7 и т.д.) это во-первых, а во-вторых хочется избавится от "ненужной" в данном случае логики. :roll: :oops:
Сообщение Oxford »
Да в принципе то можно и на тини13. Просто у тини13 таймер слабоватый. А у стм32 таймера продвинутые + DMA
Последний раз редактировалось Oxford Сб апр 15, 2017 20:49:16, всего редактировалось 1 раз.
Инженер R@D
Сообщение korob »
Я в этом уверен :) , но к сожалению не знаю как реализовать. :cry: :cry: :cry: :oops: Поэтому и "завёл" тему. :)
Сообщение Oxford »
Нет смысла ограничиваться только тини13. Он устарел морально. Внешняя логика приколхозена из-за dead time. Посмотрите IR2111 у нее dead time внутри и в управлении проще. С ним тинька13 должна справиться.
Инженер R@D
Сообщение uk8amk »
Я думаю, что достаточно ШИМ-ить только один полумост, второй полумост пусть переключает направление тока(меандр 50Гц).
Сообщение korob »
Oxford писал(а):Внешняя логика приколхозена из-за dead time. Посмотрите IR2111 у нее dead time внутри и в управлении проще.
А я о чём? Мой первый пост со схемой прочли?
Z_h_e писал(а):Вы начертите временные диаграммы, что должно выходить с обоих каналов тиньки13.
Вот так примерно: :roll:
ARV
Сообщение ARV »
korob писал(а):Дело в том, что на этом задающем генераторе сделано овер 10 девайсов ..., и все работают беспроблемно.
девайс коммерческий, ясно-понятно.
обращайтесь в ЛС: за вознаграждение любой ваш каприз.
дорого. долго. качественно. © тёма лебедев
Вернуться в «AVR»
