Котуинко
BOB51
Re: Котуинко
Сообщение BOB51 »
УПС...
:shock:
Вот это новинка, Ёжли не врут (не очередной фуфристор):
https://techcrunch.com/2020/08/25/self- ... customers/
Self-charging, thousand-year battery startup NDB aces key tests and lands first beta customers
Darrell Etherington@etherington / 3:00 pm MSK•August 25, 2020
СпойлерPleasanton-based green energy startup NDB, Inc. has reached a key milestone today with the completion of two proof of concept tests of its nano diamond battery (NDB) . One of these tests took place at the Lawrence Livermore National Laboratory and saw NDB’s battery tech manage a 40% charge, which is a big improvement over the 15% charge collection efficiency (effectively energy lossiness relative to maximum total possible charge) of standard commercial diamond.
NDB’s innovation is in creating a new, proprietary nano diamond treatment that allows for more efficient extraction of electric charge from the diamond used in the creation of the battery. Their goal is to ultimately commercialize a version of their battery that can self-charge for up to a maximum lifespan of 28,000 years, created from artificial diamond-encased carbon-14 nuclear waste.
This battery doesn’t generate any carbon emissions in operation, and only requires access to open air to work. And while they’re technically batteries, because they contain a charge which will eventually be expended, they provide their own charge for much longer than the lifetime of any specific device or individual user, making them effectively a charge-free solution.
NDB ultimately hopes to turn their battery into a viable source of power for just about anything that consumes it — including aircraft, EVs, trains and more, all the way down to smartphones, wearables and tiny industrial sensors. The company is currently now at work creating a prototype of its first commercial battery in order to make that available sometime later this year.
It has also just signed its first beta customers, who will actually be receiving and making use of those first prototypes. While it hasn’t named them specifically, it did say that one is “a leader in nuclear fuel cycle products and services,” and the other is “a leading global aerospace, defense and security manufacturing company.” Obviously, this kind of tech has appeal in just about every sector, but defense and power concerns are likely among the deepest-pocketed.
Ну а по-русски я на то в ВК наскочил - там звучит так:
Arduino & Радиолюбитель | GeeK | Технари | ПК IT
30 авг в 11:30
Батарейка
"Стартапер" Nano Diamond Battery представил прототип батареи, которая способна проработать тысячи лет. Разработка представляет собой корпус из синтетических алмазов, внутрь которого помещен радиоактивный сердечник. В батарее рассеивание бета-излучение изотопов преобразуется в электрический ток. В качестве топлива используются переработанные ядерные отходы углерода-14.
Разработчик утверждает, что батарейки безопасны для человека и окружающей среды.
Сейчас разработку переводят на коммерческую основу в разных форм-факторах, включая привычные АА, AAA, 18650, CR2032 и другие. Срок "работы" внутреннего стержня батареи до 28 000 лет.
:roll:
Upgrader
Re: Котуинко
Сообщение Upgrader »
Даже если оно существует, власти не дадут использовать такое. Или придумают налог с нереальной ценой. :)))
Тут даже литиевые аккумуляторы постоянно сокращают срок службы, до года уже дошли... куда уж меньше. Выгодно делать хуйню. Хотя раньше десяток лет спокойно отрабатывали. :write:
BOB51
Re: Котуинко
Сообщение BOB51 »
Это не "власти", а чистая коммерческая ЖАБА.
8)
Кстати... пора старые книжи по самодельным аккумуляторам конца 18 - начала 19 веков доставать и с пристрастием изучать...
:twisted:
BOB51
Re: Котуинко
Сообщение BOB51 »
Зачесались когти чуток базовую платку КОТУИНКи модернизировать...
http://img.radiokot.ru/files/20529/2be33mlczp.GIF
KOTUINO_M_U5xmp_m0.pdf
(134.14 КБ) 168 скачиваний
Добавка позволит в перспективе один вывод Р3 освободить...
Возможно немного "иллюминации" и софтово управляемый системный сброс железка (помимо BOD)...
Пока схемка да изменения в железе сделаны.
С начинкой/прожкой тиньки еще работа предстоит.
:write:
BOB51
Re: Котуинко
Сообщение BOB51 »
Наконец испекся вариант прошивки вышеуказанного монитора сброса...
Делалось абсолютно без вдохновения - абы работало в минимальном режиме с простейшей индикацией.
И таки работает...
mpr_t13.zip
(59.65 КБ) 245 скачиваний
Теперь надо платку базового модуля чуток привести в порядок и можно о более интеллектуальном расширении/изменениях биоса помудрить...
:sleep:
BOB51
Re: Котуинко
Сообщение BOB51 »
Вышла в свет очередная версия симулятора ардуино - 2.8.2
V2.8.2 Release V2.8.2 contains some minor bug fixes, and extends the parameters of the DC MOTOR device (you can now specify motor load, and load inertia -- see the Full Help ...
Posted Sep 30, 2020, 3:01 PM by Prof Simmons
https://www.sites.google.com/site/unoardusim/services
:hunger:
BOB51
Re: Котуинко
Сообщение BOB51 »
Базовый сайт ардуино начинает потихоху "портиться"...
Итогом на сегодня архив старых (и не очень) версий установщиков можно найти по ссылке:
https://www.arduino.cc/en/Main/Software
а вот докопаться войдя на главную страничку https://www.arduino.cc уже весьма муторно - ибо там запустили нечто новое -
https://www.arduino.cc/pro - что из себя этот вариант представляет - Х/З - ибо требуется ХР Х64 (т.е. не ниже 7-10ки)...
А экспериментировать что-то не охота...
Тем более после последнего "прокола" с попыткой "обновления платформ" на 1.8.9 под ХР - хорошо что у меня резервная копия всех каталогов была... (и на сегодня специально хранится)...
:twisted:
Вобщем как всегда - за раскруткой следует "уход в ограничения к доступу".
:wink:
главный колбасист
Re: Котуинко
Сообщение главный колбасист »
смотрели ролики Тимофея Хирьянова ? понравилось,прикольный чувак...
BOB51
Re: Котуинко
Сообщение BOB51 »
Нее...
Я к видеороликам отношусь с "долей скептицизма".
8)
Другое дело книжи, фотоматериалы и схемки - то хош можно распечатать и неспешно просмотреть "с карандашиком" в лапках.
:write:
главный колбасист
Re: Котуинко
Ну мы обычно скачиваем ролики,и под настроение смотрим. всегда можно отмотать назад,если что непонятно.
хотя книги есть книги.
з.ы. А открывашку автоматических шлагбаумов сделать слабо ?
BOB51
Re: Котуинко
Сообщение BOB51 »
А мне она зачем??
Пешком ни один шлагбаум не помеха...
:tea:
А в наших краях ко шлагбауму ешшо и рыло с минимум автоматом прилагается...
:wink:
главный колбасист
Re: Котуинко
Я понимаю,что не нужно. и опасно для здоровья.
а просто для куража ?
а если такое сделать? :))
BOB51
Re: Котуинко
Сообщение BOB51 »
Это удел тех, у кого финансирование "от куража".
Да возраст времен "самоутверждения".
8)
В учебном смысле ничего особого нового там в алгоритмах нету, а в прикладном (для хозяйства) не применимо...
Посему ни на финансовое обеспечение ни на выделение времени разрешения не последует (от домашнего "бюджетного комитета").
8)
BOB51
Re: Котуинко
Сообщение BOB51 »
КОГДА НЕЧЕГО ДЕЛАТЬ
или вариант контроллера программируемого таймера из подручных средств да еще "в рамках референса" адуринки...
(навеяно https://radiokot.ru/forum/viewtopic.php ... 6&start=40 ).
Итогом появилось поползновение попробовать соорудить подобное устройство.
База - atmega8/8a в DIP28 и "платформы" установленные в IDE
arduino NG o older
DIY atmega8/8A
mcu dude mini core atmega8
причем именно на самодельной платке, а не с применением хотя бы той же ардуино-про-мини...
Садомазохизьм, но интересно - удастся ли все желаемое туда впихнуть.
:twisted:
примерный набросок схемы:
http://img.radiokot.ru/files/20529/2c6hhkltbu.GIF
Дальше вероятно будут и изменения/дополнения...
Насчет реал-макета - скорее проверка алгоритмов на основе ардуино-UNO R3 в симуляторе UnoArduSim 2.8.2 проверять кусками буду - реальный макет набросать весьма ЛЕНЬ... разве что интерес к его реализации во железе у кого-то появится.
А вот кой-чего из вопросов отработать по программным решениям "с ограничениями" - пригодится.
:write:
Niks13
Re: Котуинко
Сообщение Niks13 »
Так может, пока не начали, поменять дс1307 на дс3231. Решать конечно Вам, но мне, для испытаний на макетке, будет проще приткнуть платку 3231, чем городить микросхему, держатель батарейки и кварц. Впрочем, я ни чего не обещаю. Сейчас, слава Богу, у меня на работе есть свободное время и я могу заниматься, а что будет завтра...
главный колбасист
Re: Котуинко
https://memoclub.ru/2020/07/pervyiy-zvy ... ektroniki/
мож.интересно будет...
Niks13
Re: Котуинко
Сообщение Niks13 »
[uquote="главный колбасист",url="/forum/viewtopic.php?p=3908341#p3908341"]мож.интересно будет...[/uquote]Очень интересно! Только фамилий много :)
BOB51
Re: Котуинко
Сообщение BOB51 »
Для таймеров/будильников в "свободном формате" именно 1307 более удобна - в ней 64 байтовое ОЗУ как раз для
различных уставок и счетчиков применимо.
А у 3231 только пара будильников, да еще и с довольно большим количеством настроек.
Она хороша под литиевую кормежку всего устройства (кухонна таймерюга с часами к примеру).
8)
Доработанная под удобство раскладки схемка (выводилось под самый примитивный вариант, но без перегруза МК током индикатора):
http://img.radiokot.ru/files/20529/2c7srk0s12.GIF
ptrt2.pdf
(163.45 КБ) 168 скачиваний
вот под нее и прожку в адуриньевом формате неспешно пилить буду.
Для начала проверимс можно ли автономный КонтроллерКлавиатурыДисплея без значительных потерь соорудить.
Кстати те же прожки и раскладка будут и для ардуино-нано и для ардуино-про-мини и под тест-прогон на UnoArduSim 2.8.2.
Как бы еще один учебно-тренировочный вариант под ардуино IDE.
:roll:
Платка с макеткой под RTC типа 1307
http://img.radiokot.ru/files/20529/dtg3kkk1v.jpg
из старого комплекта макеток
http://img.radiokot.ru/files/20529/il5b9fo1r.jpg
8)
oleg110592
Re: Котуинко
Сообщение oleg110592 »
[uquote="BOB51",url="/forum/viewtopic.php?p=3908748#p3908748"]Для таймеров/будильников в "свободном формате" именно 1307 более удобна - в ней 64 байтовое ОЗУ как раз для..[/uquote]
а может пилюлька удобнее - в ней часы внутри кристалла, только батарейку подцепить, и ОЗУ побольше будет 8)
BOB51
Re: Котуинко
Сообщение BOB51 »
У топикстартера по исходной теме "не до пилюлек".
8)
Посему и выбран именно САДОМАЗОХИЗМ - попытка вписаться с имеющимися ограничениями.
Да и мне покопать ККД на том примитиве интересно - может таки чего путнего и получится.
:dont_know:
:write:
