Есть ли в нем защита от КЗ ?
=======13. Output short circuit protection : yes, constant current.
Как на нем выставить ток заряда для авто-аккумулятора?
=======21. The potentiometer (CV) closed to the input voltage is used to regulate voltage, the potentiometer (CC) closed to output voltage is used to regulate current (CC).
Battery charge:
1. Make sure of the battery float voltage and charging current that you need, as well as the input voltage of the module.
2. Adjust the constant voltage potentiometer and adjust the output voltage to about 5V.
3.Use the multimeter in 10A current scale to measure output short-circuit current, and adjust the current potentiometer to make the output current to the expected charging current value.
4. Adjust the constant voltage potentiometer to make the output voltage reaches the float voltage.
5. Connected to the battery, try to charge.
(1,2,3,4 steps to connect the power module input,output no-load does not connect battery.)
